Introduction (DDF-Syntax) DMXC3
Introduction (DDF-Syntax) DMXC3 |
The Device Definition File (DDF for short) is an XML file in which all necessary information for DMXControl 3 is stored to intelligently control a device such as a moving head, scanner, or LED PAR. It tells DMXControl 3, for example, that in the case of an LED PAR, the colors red, green, and blue are on channels 2, 3, and 4, respectively, while dimmer and strobe are on channels 1 and 5. Furthermore, a DDF for DMXControl 3 contains all the information necessary for the GUI to automatically create the typical uniform user interface for all types of DDFs used in DMXControl 3.
Introduction
For DMXControl 3 to properly control a connected device with all the features available in DMXControl 3, exactly this information must be stored in the associated project. This information, which functions a device offers, is stored in a DDF. Since these functions vary from device to device, each device requires its own DDF. The second task of the DDF is to use the information in the DDF to automatically display the content of the Device Controls and the functionality of the individual controls for color, gobo, intensity, and possibly other controls. Designing the user interface for the DDFs as in DMXControl 2 is no longer necessary in DMXControl 3.
Whenever the functions of the devices change, a new DDF must be created. This means that the same DDF can be used for 20 identical dimmers (classic PAR cans on dimmer packs), whereas moving heads with different channel assignments (DMX modes[1]) require separate DDFs. In the latter case, it is important that the DDF matches the selected DMX mode to ensure proper control.
The DDF files for DMXControl 3 have a specific syntax. Using XML files from other applications, especially from DMXControl 2, is not possible. |
Storage Location
DDFs in DMXControl 3 are fundamentally divided into three categories, each with a different storage location and priority for loading and use in projects due to their definition. Through the icons, it is possible in the Add Device dialog to assign a DDF to a corresponding category.
DDF Categories
Explanations
- "{PROJECT-ZIP}" refers to the directories created within the project file. To see the contents of these directories, the project file must be opened with any compression program.
- "{PROGRAM DIRECTORY}" refers to the directory where DMXControl 3 is installed. If this was not changed during the installation of DMXControl 3, the path is usually "C:\Program Files (x86)\DMXControl3\"
- The directory "{APPDATA}" where various user-defined settings from many programs are stored can be found under the following path, replacing "{USERNAME}" with the name of the current user of the PC: "C:\Users\{USERNAME}\AppData\Roaming\DMXControl Projects e.V\DMXControl\".
Additional information on setting an environment variable to move user data to a separate directory can be found in the article System Configuration.
The directory can also be reached as a shortcut by entering the path "%AppData%\Roaming\DMXControl Projects e.V\DMXControl\" in the address bar of Windows Explorer. For easier access to the directory, the DMXControl 3 installer also creates a shortcut called Own DDFs in the Start menu. |
In all folders "{PROGRAM DIRECTORY}", "{APPDATA}" and also in the "{PROJECT-ZIP}" directory, there are two subdirectories under the "LibDevices" and "UserDevices" directories:
- "Images": Image for the device's icon in the Stage View, for example, a product image from the manufacturer
- "Icons": Icons for the gobos of the devices
DMXControl 3 searches for the image files from these directories specified in a DDF. The image files themselves are not stored in the DDF. Only references are contained here. Therefore, in addition to the DDF, the image files from both directories must always be copied if you want to use the DDF on another PC for a new project.
Footnotes
- ↑ Different number and assignment of DMX channels, adjustable on the device itself
