Effectwheel (DDF-Syntax) DMXC3
Effectwheel (DDF-Syntax) DMXC3 | Article describes DMXControl 3.2.0 |
The Prism divides the light beam into additional beams depending on its design. Control of the prism and its functions in DMXControl 3 is exclusively through the Device Control.
Contents
Prism
A prism divides the light beam multiple times. This function is commonly found in moving heads and scanners in various configurations, ranging from a simple static prism to multiple prisms with different numbers of facets that can rotate and be positioned.
Basic Functions
Variant | Code |
Standard | <prism dmxchannel="0">
<step type="prism" mindmx="64" maxdmx="127" caption="3-facets radial prism" val="3-facets radial.png" />
<step type="prism" mindmx="128" maxdmx="191" caption="6-facets linear prism" val="6-facets linear.png" />
<step type="prism" mindmx="192" maxdmx="255" caption="8-facets radial prism" val="8-facets radial.png" />
</prism>
Prism on DMX channel 1:
Attribute | range | mindmx | maxdmx | caption | val |
Description | Minimum DMX value for the corresponding prism | Maximum DMX value for the corresponding prism | Description of the prism | Filename of the prism icon | |
Allowed Attribute Value | open prism
0 to 255
0 to 255
Text
*.png files
Optional | X |
The associated files for the optional icons of the prisms must be stored in the same directory as the icons for the gobos. |
Additional Functions
For individual functions of the prism channel, the following additional functions are possible:
prismindex
: Positioning of the prism at any angle.prismrotation
: Continuous rotation of the prism in various directions.
These additional functions can be accessed in two different ways:
- For controlling the additional functions, one or more separate DMX channels are used.
- The additional functions are on the same DMX channel as the prism itself.
Prism Indexing
Variant | Code |
Separate DMX channel for prism indexing | <prism dmxchannel="0">
<prismindex dmxchannel="1">
</prismindex>
</prism>
Prism on DMX channel 1, prism indexing on DMX channel 2:
Prism indexing on the same DMX channel | <prism dmxchannel="0">
<prismindex />
<step type="open" mindmx="0" maxdmx="31" caption="Open" />
<step type="prism" mindmx="32" maxdmx="255" caption="3-facets radial prism">
<range range="360" handler="prismindex" mindmx="32" maxdmx="119" minval="0" maxval="360" />
</step>
</prism>
Prism with prism indexing on DMX channel 1:
Attribute | range | mindmx | maxdmx | minval | maxval | |
Description | Maximum rotation angle for prism indexing | DMX value for the start position | DMX value for the end position | Start position of the prism indexing | End position of the prism indexing | |
Allowed Attribute Value | 0° to 360°
0 to 255
0 to 255
0° to 360°
0° to 360°
Prism Rotation
Variant | Code |
Separate DMX channel for prism rotation | <prism dmxchannel="0">
</prismrotation>
</prism>
Prism on DMX channel 1, prism rotation on DMX channel 2:
Prism rotation on the same DMX channel | <prism dmxchannel="0">
<prismrotation />
<step type="stop" handler="prismrotation" mindmx="120" maxdmx="127" />
</step>
</prism>
Prism with prism rotation on DMX channel 1:
Attribute | handler | mindmx | maxdmx | minval | maxval |
Description | DMX value for the minimum rotation speed of the prism | DMX value for the maximum rotation speed of the prism | Minimum rotation speed of the prism | Maximum rotation speed of the prism | |
Allowed Attribute Value | prismrotation
0 to 255
0 to 255
0.05 1/s to 5 1/s
0.05 1/s to 5 1/s
Effect Wheel
The effect wheel combines several different effects on one wheel. These include various prisms, frost filters, or color correction filters that can be combined on a single effect wheel.
For compatibility reasons, it is recommended to represent prism and frost separately using their standalone functions. |
Variant | Code |
Standard | <effectwheel dmxchannel="0">
<step type="prism" mindmx="32" maxdmx="63" caption="3-facets prism" />
<step type="frost" mindmx="64" maxdmx="95" caption="Frost" />
<step type="macro" mindmx="96" maxdmx="103" caption="Macro 1" />
<step type="macro" mindmx="104" maxdmx="111" caption="Macro 2" />
<step type="macro" mindmx="112" maxdmx="119" caption="Macro 3" />
<step type="macro" mindmx="120" maxdmx="127" caption="Macro 4" />
</effectwheel>
Effect wheel on DMX channel 1:
Attribute | type | mindmx | maxdmx |
Description | Minimum DMX value for activating the function | Maximum DMX value for activating the function | |
Allowed Attribute Value | open prism frost macro
0 to 255
0 to 255
