Procedures functions (DDF-Syntax) DMXC3
With the help of Procedures, functions are called that are usually not needed during live operation. Saving these functions in Cues is also not usually necessary. These include, for example, the complete reset of a device or individual motors, the activation or deactivation of pan and tilt inversion, or turning the light source on and off.
These functions are accessed not through Device Control, but in the Stage View via the context menu of the respective device, through the Procedures submenu.
Structure
Procedures in DDFs for DMXControl 3 all have the same structure, which usually consists of four elements:
- Name of the function for the associated Procedure
set
: Specifies the DMX channel and the DMX valuehold
: Hold time for the DMX valuerestore
: Restoration of the initial state
If the restore
element is omitted in a Procedure, the DMX value entered under set
remains set.
Available Procedures
Currently, the following Procedures are already predefined in DMXControl 3, but Procedures with custom names can also be created. For the most common functions, unique symbols are automatically assigned to the names. The naming can be freely chosen since Procedures directly address DMX channels with DMX values. It is therefore possible to start a complete device reset with the Procedure for turning on the lamp. However, this approach is not recommended.
Procedure Name | Description | Note |
lamp_on
Turns on the lamp of the corresponding device. | |
lamp_off
Turns off the lamp of the corresponding device. | |
reset
Triggers a reset on the corresponding device. | |
reset_pan_tilt
Triggers a reset of the pan & tilt motors on the corresponding device. | The device moves to its reference points for pan & tilt. |
reset_pan
Triggers a reset of the pan motor on the corresponding device. | The device moves to its reference points for pan. |
reset_tilt
Triggers a reset of the tilt motor on the corresponding device. | The device moves to its reference points for tilt. |
reset_gobo
Triggers a reset of the gobo motor on the corresponding device. | The gobo wheel moves to its reference points. |
reset_gobo2
Triggers a reset of the gobo 2 motor on the corresponding device. | Gobo wheel 2 moves to its reference points. |
reset_color
Triggers a reset of the color motor on the corresponding device. | The color wheel moves to its reference points. |
reset_color2
Triggers a reset of the color 2 motor on the corresponding device. | Color wheel 2 moves to its reference points. |
reset_effects
Triggers a reset of the built-in effects on the corresponding device. | |
reset_zoom
Triggers a reset of the zoom function on the corresponding device. | |
reset_shutter
Triggers a reset of the shutter on the corresponding device. | |
reset_iris
Triggers a reset of the iris on the corresponding device. | |
reset_focus
Triggers a reset of the focus function on the corresponding device. | |
reset_prism
Triggers a reset of the prism wheel on the corresponding device. | |
pan_invert_on
Inverts the pan channel on the corresponding device. | |
pan_invert_off
Disables the inversion of the pan channel on the corresponding device. | |
tilt_invert_on
Inverts the tilt channel on the corresponding device. | |
tilt_invert_off
Disables the inversion of the tilt channel on the corresponding device. | |
pan_tilt_swap_on
Swaps pan and tilt on the corresponding device. | |
pan_tilt_swap_off
Disables the swapping of pan and tilt on the corresponding device. | |
display_on
Activates the display of the corresponding device. | |
display_off
Deactivates the display of the corresponding device. |
