Lesson 9 Tut3
From English DMXC-Wiki
DMXControl 3 lessons
The previous lession introduced into simple cues. In this lesson we explain some more sophisticated features of scenes, e.g. the fanning feature. With fanning you can create impressive effects with groups of lamps, e.g. rainbow effects or waves.
Lecture 9: Fanning, chasers and other effects
DMXControl 3 extends the scope of scenes in that way that dynamic effects can be included and that you can apply certain algorithms for the attributes (DMX values) of included devices resp. groups. This allows you to create highly complex scene with few mouse clicks. Don't believe it? Let's demonstrate how it works!
Fanning
The first mechanism is fanning.
Fanning means from technical point of view to split a value oder domain to a group of devices. We distinguish between linear and alternate fanning, see following tables explaining the syntax element.
linear fanning
Syntax Example Description
> 50 > 100 linear interpolation
<> 50 <> 100 linear interpolation: marginal devices: 100, central devices 50
>< 50 >< 100 contrary: marginal devices: 50, central devices 100
alternate fanning
# 50 # 100 alternate values 100/50/100/50 ...
# # 100 # 50 # 0 alternate values 100/50/0/100/50/0 ...
How does it work?
Lets assume we want to have a cue where the 8 RGB Pars have to be faded from red in the middle to blue at the ends.
Datei:DMXC3L09 Fanning pink.JPG
How many actions are needed for programming? 8? 16? 32? The answer is: three. We will apply linear fanning by "><" where we separate the marginal devices from central devices. The actions:
  • select the group "RGB pars"
  • Go to property grid panel and type in for red color "0<>255"
  • type for blue color "255<>0"
Here is the result in property grid:
Datei:DMXC3L09 Fanning pink programmer.JPG
Let's make another excercise with alternate fanning. The task is switching on each second lamp (i.e. setting dimmer to 100%).
Datei:DMXC3L09 Fanning alternate.JPG
There is a simple solution: Insert "0#100" into the dimmer value text field.
Datei:DMXC3L09 Fanning alternate programmer.JPG
Effects and attachables
With fanning you can create static cues. The attachables panels provides some effects that can be used for dynamic changes within a cue.
Let's have an example: You want to have a blinking effects with all frontlight lamps with lowest brightness for the central devices.
Here we will use the "attachable" pannel showing some effects such as "Sinus", Trapezoid", "Sawtooth" etc. Per drag&drop we can load the Sinus effect to the dimmer attribute within property grid.
Following settings are nessecary (the amplitude will varybetween 30 and 100 %):
Try it!
Hint: Press the Del key to remove the effect from the attribute.
Attribut Example Description
Amplitude 50 > 100 value interval for selected attribute
Offset [0..100] offset between group elements
Phase [0..1]  ?
Frequency [0..1]  ? frequency
Tipp: By fanning the offset you get interesting chasers.
to be added (by beta testers)
Excercise
  • Try to apply fanning to moving lights. That rocks! ;)
Certificate
I have understood the topics of this lecture and want to continue with next course: Lecture10: The programmer view
