DMXControl 3 lessons
Scene lists are the means to control your show. In this lesson we explain how to define the sequence and the flow of scenes by triggers.
Lecture 11: Trigger in scene lists
In previous lesson we learnt how to create cues and scene lists. Now we are familar with most of the attributes of scene list, but some more explanation about the trigger is nessecary. The default trigger is "follow", i.e. the next cue will be started after the previous one is finished.
But there are some other types of triggers, the following table informs you about its behaviour.
| Type | Example format | Description |
| rtc | ?? | ?? |
| timecode | 00:26:05 | expects external timecode information |
| wait | 5s | countdown starts when the previous scene fades is |
| follow | 5s | waits for fading in of the previous scene and then the countdown will start |
| beat | - | not yet supported? |
In case you type a wrong format into the trigger value field you will get some hints about the expected input. See the example for the "follow" type.
Hint: Type in combined time information without "blank" character, e.g. 1m20s
Datei:DMXC3L11 triggerhelpcontextfollow.JPG
Here is the example for the timecode selection.
Datei:DMXC3L11 triggerhelpcontext.JPG
- What about "rtc"?
- Example for external timecode usage
- How to configure "beat"?
Excercise
- Test a mix of "follow" and "wait" triggers in one scene list
- Use a tool providing timecodes (DE MediaCenter) and test a scenelist that is completely based on timecodes
Certificate
I have understood the topics of this lecture and want to continue with next course: Lecture12: XXXX
- preamble
- lesson 6: Output plugins
- lesson 11: Trigger concepts
- lesson 13: Presets
- lesson 16: Softpult
- lesson 17: Artnet
- lesson 21: free topic
- appendix2: Kernel menu tree
| Language: |
