Lesson 8 Tut3
From English DMXC-Wiki
DMXControl 3 lessons
Scenes (cues) are the most important elements of your show. Here we will explain the powerful scene concept of DMXControl 3. The terms "cue" and "scene" are used as synonym words.
Lecture 8: Scenes (cues) and scene lists
Each scene needs a "host container"- that's a scene list. Therefore you have to create at first one or more scene lists by clicking the button "Create scenelist" which you can find in the project explorer main menu. Of course, the created scene list will appear in the folder "Scene list".
600px
You can open this new scene list with a double click on the object in the project explorer or using the context menu item "open". Next step is to create a new scene. For creating a new cue we will change the color of the moving lights to "red" (please open the shutter too) and we turn on the two middle front lights.
Datei:DMXC3L08 changeLiveView.JPG
Return to the scene list panel and press the Store cue button. At first the programmer filter tool will appear where you can manually influence which devices and which attributes should be really taken over into the new scene. Typically you can confirm without modification.
Datei:DMXC3L08 programmerFilter.JPG
The result is your first cue (scene) in your scene list. You should change the name of the cue thus you can remember laterly what is the reason and target of this cue (e.g. "First Scene", "Start cue", "ML to red", etc.)
Datei:DMXC3L08 FirstScene.JPG
In following table we explain the meaning of cue attributes (which you can see in the scene list header:
Attribute Description Example
Progress shows status of scene during execution of scene list in percent
Trigger relation to predecessor cue, use "follow" as default see lesson 11
Trigger Value see lesson 11
Name free name of scene should explain the content of cue
Fade fade-in value in milli seconds
Delay delay ? ?
Act. is this cue active or should it be ignored? default: active
Ap. ? ?
Comment for free use, insert explaining words
In the same way you can create some more cues and store it in the scene list.
Datei:DMXC3L08 SecondScene.JPG
Excercise
  • Generate your own cues
  • Try the buttons "All", "Clear" and "Selected" in the programmer filter
  • Work with different fade times
Certificate
I have understood the topics of this lecture and want to continue with next course: Lecture9: Fanning and other effects
