Lesson 12 Tut3
From English DMXC-Wiki
Revision as of 12:06, 21 April 2011 by Frank Burghardt (talk | contribs)
DMXControl 3 lessons
In this lesson we explain advanced edit features for scenes and scene lists, e.g. for modification of already saved scenes.
Lecture 12: Editing scenes and scenelists
In lesson 8 we introduced the scene lists. In this lecture more advanced features are explained.
By default a new scene is added to an existing scene list by pressing the button "Store Cue". When you open the small dropdown arrow on right hand side of this button you see some more sophisticated capabilities with their short code. In most cases you have to mark a scene at first before applying this modification.
Hint: The following operations are related to the values in the programmer.
Datei:DMXC3L12 SL.JPG
Function short code Description Comment
Add Strg+A add a new scene to scenelist after marked scene default: at the end
Insert Strg+I insert a new scene to scenelist after marked scene
Replace Strg+R replace current scene attributes by the values in the programmer
Merge Strg+M add a new scene to scenelist after marked scene
Append Strg+P add a new scene to scenelist after marked scene
Subtract Strg+B subtract current scene attributes by the values in the programmer
Update Strg+U no function yet
Datei:DMXC3L12 SL storemenue.jpg
In similar way, there are also edit operations for the scene list itself. Like familar in EXCEL, you can copy, cut and delete whole rows.
Datei:DMXC3L12 SL editmenue.jpg
Cut Strg+X cut the selected scene
Copy Strg+C copy the selected scene
Paste Strg+V paste the selected scene
Delete Del(Entf) delete the selected scene
Copy content Strg+Alt+C ??
Paste content Strg+Alt+V ??
Datei:DMXC3L12 SL modemenue.jpg
Datei:DMXC3L12 SL optionmenue.jpg
Excercise
  • Try to generate
Certificate
I have understood the topics of this lecture and want to continue with next course: Lecture13: XXXX
