Lesson 4 Tut3
From English DMXC-Wiki
Revision as of 23:07, 19 June 2011 by Julien (talk | contribs)
Template:Hauptüberschrift
This lesson introduces into the liveview panel - a minimal visualisation tool which offers valueable support for programming your show.
Lecture 4: The live view
The liveView tool is one of the several tool in the tool menue. When creating devices and groups some (animated) icons are automatically generated in the liveview. You can shift these icon to a wanted place by mouse dragging. This way you can model your stage in 2D representation.
It could be helpful to load an background picture for better mapping your stage (right mouse context menue).
600px
The liveview distunguishes in "single lamp" icons and "group" icons. If you select an group icon all following operational actions are related to each group member.
You can select a set of devices by drawing a frame around them (this is a kind of temporary group - please do not confuse this with the default groups) or by single selection holding the "Strg" key. Marking such a set of device can also be helpful for positioning the icons.
Datei:DMXC3L04 liveView groups.jpg
There are some helpful shortcuts helping to improve the assignment of icons in the liveview (moving and alignment of symbols). At first you have to select the device icons by drawing a frame or pressing the "STRG/CTRL" key (windows style selection).
key action result
M ("Matrix") press key M and drag mouse a matrix is created from the selected icons
F ("Fanning") press key F and drag mouse icons are proportionally aligned (e.g. in a row)
C ("Circle") press key C and drag mouse icons are aligned in shape of circle
  • Welche Tasten sind in der Liveview interessant (Selektieren, Verschieben, automatisch anordnen, ...
  • Beschreiben, dass mehrere liveviews existieren
  • Wie kann ich Geräte in die verschiedenen liveviews bringen?
Excercise
  • Try to generate the same layout in the live view panel as shown above by shifting the icons
  • Mark a subset of devices and take place an operation with property panel
Certificate
I have understood the topics of this lecture and want to continue with next course: Lesson 5
