Lesson 12 Tut3
From English DMXC-Wiki
Revision as of 14:36, 17 April 2013 by Jmintenbeck (talk | contribs)
[[File:{{{Logo}}}|48px|link=]] {{{Pagetitle}}}
Template:NavigationTop-Tut3
In this lesson we explain advanced edit features for scenes and scene lists, e.g. for modification of already saved scenes. So you can copy and customize cues very effectively and almost EXCEL like.
Lecture 12: Editing scenes and scene lists
Figure 1:Menu of the Programmer
Figure 1: Menu of the Programmer
By default, a new scene is added to an existing scene list by pressing the button "Add Cue". When you open the small drop-down arrow on right hand side of this button, you see some more sophisticated capabilities with their keyboard shortcut. In most cases you will first select (i.e. highlight) a scene before modifying it.
Figure 2:View of the drop-down-menu of "Add Cue"
Figure 2: View of the drop-down-menu of "Add Cue"
 Important Hint The following operations are related to the values in the Programmer.
Function short code Description Comment
Add Ctrl+A add a new scene to scene list at the end default
Insert Ctrl+I insert a new scene to scene-list before selected scene
Replace Ctrl+R replace current scene attributes by the values in the Programmer
Merge Ctrl+M merges selected scene with Programmer values Programmer values with higher priority
Append Ctrl+P append new property from Programmer to the selected scene existing scene with higher priority, new values from Programmer are added
Subtract Ctrl+B removes a property from selected scene hint: modify the wanted property so that this appears in the Programmer
Sum (Special) Inserts current output of devices into Cue List
PSum (Special) Similar to Sum, but related to currently selected devices in Stage View
Preset (Special) Opens a window where you have the capability to add a Preset to Cue List
Scenelist (Special) Inserts (similar to commands in DMXControl 2) a entry to impact another cue list
In a similar way, there are also edit operations for the scene list itself. As known from EXCEL you can copy, cut and delete whole rows. With copy and paste you can take single values from one field or a cue to another field of other cues.
Figure 3:View of drop-down-menu of "Edit"
Figure 3: View of drop-down-menu of "Edit"
Here is the summarizing table for explanation again:
Edit in Programmer Selected cue is loaded into Programmer. Programmer Output Mode is set to All
Edit in Programmer Blind Selected cue is loaded into Programmer. Programmer Output Mode is set to Blind
Cut Ctrl+X cut the selected scene like EXCEL "cut row"
Copy Ctrl+C copy the selected scene like EXCEL "copy row"
Paste Ctrl+V paste the selected scene like EXCEL "paste row"
Delete Del delete the selected scene like EXCEL "delete row"
Renumber Cues Renumber Cues
Cue Timing Editor a separate editor is opened
Figure 4:View of drop-down-menu of "Options"
Figure 4: View of drop-down-menu of "Options"
Function Description Comment
Tracking If tracking is active a value remains active until it is overwritten by another cue (or the cue list is finished). If tracking is disabled, only the stored values ​​are active on output that are in the current cue. All others are faded out.
Reset when Released Cue List jumps to first entry, after last cue was executed
Use Cue Time as Back Time After a jump back in the Cue List, the times of the cues are used for the crossfade.
Use Cue Time as GoTo Time After a jump forward in the Cue List, the times of the cues are used for the crossfade.
Autoprepare DMXControl prepares headlights already automatically on the mission (color and gobo is selected in advance etc.). That way you will not need to worry about it. On active Autoprepare you can deactivate this function for single cues with the checkbox Ap.
Exercise
  • Test the append and subtract cue functions
