Lesson 6 Tut3
From English DMXC-Wiki
Revision as of 13:13, 14 April 2011 by Frank Burghardt (talk | contribs)
DMXControl 3 lessons
In order to control your lamps you need to send out "real" DMX signals to your universes. In this lesson we explain how to configure your output devices.
Lecture 6: Configuring the output plugins
In the menue "windows" you can find the panel "output devices". There you can select your DMX transmitter/sender by setting the hook.
Hint: in the current beta version only the DMX Interface from "Digital Enlightenment" is supported. But this is no blocking point for testing the software, if you are an owner of a different interface. On one hand the software also works without DMX-Interface, on the other hand you can use the Artnet-Interface to connect to a light control software supporting your interface, e.g. DMXControl 2.11.
Datei:DMXC3L06 DE IF plugin.JPG
Datei:DMXC3L06 DE IF plugin settings.JPG
Excercise
  • Try to generate the same layout in the live view panel as shown above
Certificate
I have understood the topics of this lecture and want to continue with next course: Lecture7: Summary and Details for SetUp
