Lesson 11 Tut3
From English DMXC-Wiki
Revision as of 10:31, 20 April 2011 by Frank Burghardt (talk | contribs)
DMXControl 3 lessons
Scene lists are the means to control your show. In this lesson we explain how to define the sequence and the flow of scenes by triggers.
Lecture 11: Trigger in scene lists
In previous lesson we learnt how to create cues and scene lists. Now we are familar with most of the attributes of scene list, but some more explanation about the trigger is nessecary. The default trigger is "follow", i.e. the next cue will be started after the previous one is finished.
But there are some other types of triggers, the following table informs you about its behaviour.
Datei:DMXC3L11 trigger.jpg
Type Example format Description
rtc ?? ??
timecode 00:26:05 expects external timecode information
wait - waits for manual triggering ("Go next" button)
follow 5s xx
beat - not yet supported?
In case you type a wrong format into the trigger value field you will get some hints about the expected input. See the example for the "follow" type.
Datei:DMXC3L11 triggerhelpcontextfollow.JPG
Here is the example for the timecode selection.
Datei:DMXC3L11 triggerhelpcontext.JPG
to be added (by beta testers)
Excercise
  • Test a mix of "follow" and "wait" triggers in one scene list
  • Use a tool providing timecodes (DE MediaCenter) and test a scenelist that is completely based on timecodes
Certificate
I have understood the topics of this lecture and want to continue with next course: Lecture12: XXXX
