Lesson 10 Tut3
From English DMXC-Wiki
Revision as of 23:25, 17 April 2011 by Phasm (talk | contribs)
DMXControl 3 lessons
This is an optional lesson for expert users. Here we explain the "programmer view" - a tool that helps to "debug" your show programming.
Lecture 10: The programmer view
The programmer is a helpful tool during programming your show. It logs all modifications you have made and shows the current content of the "cue buffer". Let's illustrate this by an example. We make following actions:
  • at first we open the moving lights shutters and select the color green
  • secondly, we set the group of front lights to 50% brightness
  • thirdly, all RGB Pars are set to color X
  • finally, the RGB Pars 3 and 6 are set to color Y
Datei:DMXC3L10 liveviewProgrammer.JPG
The result is shon in the programmer. Please be aware the the cue is not saved at this point of time, because further modification could follow.
In case you change your mindset on the current cue, you can press the Clear button in order to remove all settings und refresh the programmer.
Datei:DMXC3L10 Programmer.JPG
  • Are there further operations with programmer?
Excercise
  • Repeat the above scenario
Certificate
I have understood the topics of this lecture and want to continue with next course: Lecture11: XXXX
