Lesson 19 Tut3
From English DMXC-Wiki
Revision as of 18:28, 24 June 2011 by Julien (talk | contribs)
Template:Hauptüberschrift
In this lesson some additional clients are in focus. The client/server concept of DMXControl allows the connection to other clients (Smartphones, Tabs, etc.) in simple way.
Lecture 19: Further DMXControl clients
in development:
Both smartphone apps (clients) communicate via OSC with DMXControl 3. Therefore you have to enable the OSC plugin via "plugin manager", see following figure:
Now, you should define the IP connection in the panel "connection form". Press the "+" button to create a new connention. In the first approach we use unicast with UDP. Please let the IP address on 0.0.0.0, but set the correct port where your client sends the OSC messages. Now you can start (activate) this connection by a click to start button:
Excercise
  • Create ...
Certificate
I have understood the topics of this lecture and want to continue with next course: Lesson 20
