Lesson 1 Tut3
From English DMXC-Wiki
Revision as of 10:53, 12 April 2011 by Frank Burghardt (talk | contribs)
DMXControl 3 lessons
This lecture introduces into the distributed architecture of DMXControl 3.0. You will learn facts about the client and server communication and how to operate the kernel.
DMXControl 3.0 provides a distributed architecture, i.e. there is a kernel that can comminicate with several clients. The client runs basically on Windows operating system, but can also be launched on Linux (with Mono).
One or multiple clients can be started on different systems (Windows, iOS, Android). Thus, you can even work in teams for implementing and performing your show. DMXControl 3.0 supports also cooperation during the life cycle, i.e. you can execute scene lists during your mate is still programming the missing cues!
The kernel
At first, lets start the kernel, i.e. the DMXControl server. Currently this application is called "Lumos.exe".
Datei:DMXC3L01 kernel.JPG
During launching the kernel you can observe what is loaded by DMXControl. The kernel is the central master of all information about devices, cues, projects etc. that can be accessed by the clients.
The kernel provides a command shell. By typing "help" you get an overview about all supported commands.
Datei:DMXC3L01 konsole.JPG
The client
In next step you should start the Windows based GUI cient. This client will be explained in next lectures. At first you have to select the "Tools->Connection" panel in order to connect with the server.
Datei:DMXC3L01 connect.JPG
If you have installed a firewall you have to grant the communication between client and server.
Datei:DMXC3L01 startGUI.JPG
After establishing the connection you shoud see a small icon in the lower line of the client.
Excercise
2) Connect your client with DMXControl server.
I have understood the topics of this lecture and wnt to continue with next course: Lecture2
