DMXControl 3 lessons
In this lesson we explain advanced edit features for scenes and scene lists, e.g. for modification of already saved scenes.
Lecture 12: Editing scenes and scenelists
In lesson 8 we introduced the scene lists. In this lecture more advanced features are explained.
By default a new scene is added to an existing scene list by pressing the button "Store Cue". When you open the small dropdown arrow on right hand side of this button you see some more sophisticated capabilities with their short code. In most cases you have to mark a scene at first before applying this modification.
Hint: The following operations are related to the values in the programmer.
| Function | short code | Description | Comment |
| Add | Strg+A | add a new scene to scenelist after marked scene | default: at the end |
| Insert | Strg+I | insert a new scene to scenelist after marked scene | |
| Replace | Strg+R | replace current scene attributes by the values in the programmer | |
| Merge | Strg+M | add a new scene to scenelist after marked scene | |
| Append | Strg+P | add a new scene to scenelist after marked scene | |
| Subtract | Strg+B | subtract current scene attributes by the values in the programmer | |
| Update | Strg+U | no function yet |
Datei:DMXC3L12 SL storemenue.jpg
In similar way, there are also edit operations for the scene list itself. Like familar in EXCEL, you can copy, cut and delete whole rows.
Datei:DMXC3L12 SL editmenue.jpg
| Cut | Strg+X | cut the selected scene | |
| Copy | Strg+C | copy the selected scene | |
| Paste | Strg+V | paste the selected scene | |
| Delete | Del(Entf) | delete the selected scene | |
| Copy content | Strg+Alt+C | ?? | |
| Paste content | Strg+Alt+V | ?? |
Datei:DMXC3L12 SL modemenue.jpg
Datei:DMXC3L12 SL optionmenue.jpg
Excercise
- Try to generate
Certificate
I have understood the topics of this lecture and want to continue with next course: Lecture13: XXXX
- preamble
- lesson 6: Output plugins
- lesson 11: Trigger concepts
- lesson 13: Presets
- lesson 16: Softpult
- lesson 17: Artnet
- lesson 21: free topic
- appendix2: Kernel menu tree
| Language: |
