Lesson 1 Tut3
From English DMXC-Wiki
Revision as of 23:12, 25 April 2011 by Markus (talk | contribs)
DMXControl 3 lessons
This lecture introduces into the distributed architecture of DMXControl 3.0. You will learn facts about the client and server communication and how to operate the kernel.
DMXControl 3.0 provides a distributed architecture, i.e. there is a kernel that can communicate with several clients. The client runs basically on Windows operating system, but can also be launched on Linux (with Mono).
One or multiple clients can be started on different systems (Windows, iOS, Android). Thus, you can even work in teams for implementing and performing your show. DMXControl 3.0 supports also cooperation during the life cycle, i.e. you can execute scene lists during your mate is still programming the missing cues!
The separation of server and clients provides some benefits:
   * the kernel continues in case of malfunction in the user interface and continues DMX output
   * several users can share the kernel to work in a team
   * kernel and user interface could run on different computers
The kernel
At first, lets start the kernel, i.e. the DMXControl server. Currently this application is called "Lumos.exe". In future a default user don't have to be aware about the kernel process. It will be automatically started with DMXControl and is (hopefully) continuously running.
600px
During launching the kernel you can observe what is loaded by DMXControl. The kernel is the central master of all information about devices, cues, projects etc. that can be accessed by the clients.
The kernel provides a command shell. By typing "help" you get an overview about all supported commands.
600px
There are some command options in the command line mode for getting detailed information on the status of the kernel:
  • shutdown: Shut down the kernel.
  • status: Displays information about the status
  • menu: Access to control menu
  • clear: Clears the console
  • notification: Send a notification to all clients
  • width: Defines width of console (number of characters)
  • help: Help menu (also accessible via "?")
Additional second level menu commands exists for "menu" and "status".
The client
In next step you should start the Windows based GUI client (currently called "LumosGUI.exe". This client will be explained in next lectures. At first you have to select the "Tools->Connection" panel in order to connect with the server.
Datei:DMXC3L01 connect.JPG
If you have installed a firewall you have to grant the communication between client and server.
600px
After establishing the connection you should see a small icon in the lower line of the client.
Now you are able to load your project. DMXControl will provide a default demo project. You can oen it with menue point "Project".
topics to be added (by beta tester)
  • how to save a project
Excercise
  • menue
  • status
  • shutdown -> uups!
2) Restart kernel and GUI and connect your client with DMXControl server.
Assumptions for installation
DMXControl 3.0 requires following software to be installed before executing the setup program:
  • DirectX 9.0c
  • .NET Framework 3.5 SP1 or higher
  • XNA Framework 3.0(xnafx30_redist.msi)
  1. DirectX 9.0c
  2. .NET Framework 3.5
  3. .NET Framework 3.5 Service Pack 1
  4. XNA Framework 3.0
Certificate
I have understood the topics of this lecture and want to continue with next course: Lecture2: The panel concept
