Lesson 20 Tut3
From English DMXC-Wiki
Revision as of 15:03, 8 May 2011 by Frank Burghardt (talk | contribs) (Die Seite wurde neu angelegt: „<h2 style="{{Style:Hauptseite:Überschrift}}" align="center">DMXControl 3 lessons</h2> <div style="{{Style:Hauptseite:Box}} background-color:#ffffff"> <!-- Rechte…“)
In this lesson we will learn how to create and add new device definitions. You need to do this acivity only, if your device is not yet defined in the default set of DMXControl 3 device definitions.
Lecture 20: Create new device definitions
A device definition file (short: DDF) is used to inform DMXControl about the properties of a device. A DDF is wiritten in XML language and stored in the path
If you are familar with DDFs of DMXControl 2.0 you will see some important differences:
  • There is no GUI description part, because DMXControl 3 doesn't provide the device context menues
  • Sone syntax elements are very similar (esp. in information part), i.e. you can reuse the existing DDFs
  • The function part is much more abstract: You make the definition mainly by properties and not by DMX channels
Currently there is no "DDF creator" available fpr DMXControl 3, we recommend to use a text editor or XML editor tool. (Hint: We need support for adaption of an existing DMXControl 2 php tool towards DMXControl 3)
At first lets have a view to a very simple DDF ("Generic RGB Par"):
01 <?xml version="1.0" encoding="utf-8" ?>
03  <information>
04    <modell>Generic RGB PAR</modell>
05    <vendor>Generic</vendor>
06    <author>Arne Luedtke</author>
07  </information>
08  <functions>
09    <rgb>
10      <red dmxchannel="0" />
11      <green dmxchannel="1" />
12      <blue dmxchannel="2" />
13    </rgb>
14  </functions>
15 </device>
Line 01 is mandatory default line for describing the XML version. Lines 02 and 15 provide the frame for the device definition that contains of two parts:
  • information part (lines 03 to 07), no need for further explanation.
  • function(property) specification part (lines 08 to 14)
The example device posesses one property: RGB colar mode. The mapping to DMX channels is described in lines 10 to 12.
Thats all!
Following table shows the existing properties:
  • During the beta test there is no upload capability for new DDFs. This topic must be updated.
Excercise
  • Have a look into several device definitions before creating your own DDF.
  • Open the DDF for TS255. Separate the different properties by blank lines to get a better understanding.
  • Create the DDF for your own device.
Certificate
I have understood the topics of this lecture and want to continue with next course: Lecture21: XXXX
