DMXControl 3 lessons
This lecture introduces into the distributed architecture of DMXControl 3.0. You will learn some facts about the client and server communication and how to operate the kernel.
DMXControl 3.0 provides a distributed architecture, i.e. there is a kernel that can communicate with several clients. The kernel runs basically on Windows operating system, but can also be launched on Linux (with Mono).
One or multiple clients can be started on different systems (Windows, iOS, Android). Thus, you can even work in teams for implementing and performing your show. DMXControl 3.0 supports also cooperation during the life cycle, i.e. you can execute scene lists during your mate is still programming the missing cues!
The separation of server and clients provides some benefits:
- the kernel continues in case of malfunction in the user interface and continues DMX output
The kernel
At first, lets start the kernel, i.e. the DMXControl server. Currently this application is called "Lumos.exe" (hint: in the beta version you have to start the kernel as administrator when you have used the standard installation). In future a default user don't have to be aware about the kernel process. It will be automatically started with DMXControl and is (hopefully) continuously running.
During launching the kernel you can observe what is loaded by DMXControl. The kernel is the central master of all information about devices, cues, projects etc. that can be accessed by the clients. And it provides the DMX mixer engine and output system.
The kernel provides a command shell. By typing "help" you get an overview about all supported commands.
There are some command options in the command line mode for getting detailed information on the status of the kernel:
- shutdown: Shut down the kernel.
- status: Displays information about the status
- menu: Access to control menu
- clear: Clears the console
- notification: Send a notification to all clients
- width: Defines width of console (number of characters)
- help: Help menu (also accessible via "?")
Additional second level menu commands exists for "menu" and "status".
The client
In next step you should start the Windows based GUI client (currently called "LumosGUI.exe"). This client will be explained in next lectures. At first you have to select the "Tools->Connection" panel in order to connect with the server.
If you have installed a firewall you have to grant the communication between client and server.
After establishing the connection you should see a small icon in the lower line of the client indicating the existing connection.
Now you are able to load your project. DMXControl will provide a default demo project. You can open it with menue point "Project".
- how to save a project
Excercise
- menue
- status
- shutdown -> uups!
2) Restart kernel and GUI and connect your client with DMXControl server.
Assumptions for installation
DMXControl 3.0 requires following software to be installed before executing the setup program:
- DirectX 9.0c
- DirectX 9.0c
Known Issues
GUI Elements display glitches
This could look like shown below: Also if you move windows it happens that thay are not displayed correct.
This can occur if you have a NVidia graphics card an use an old driver version.
I experienced this issue with a GeForce G 103M Driver Version 258.96 + PhysX 09.10.0513 on Windows XP x86_64.
Consider updating the driver to the latest version. Version 266.58 + PhysX 09.10.0514 is known to work.
Certificate
I have understood the topics of this lecture and want to continue with next course: Lecture2: The panel concept
- preamble
- lesson 6: Output plugins
- lesson 11: Trigger concepts
- lesson 13: Presets
- lesson 16: Softpult
- lesson 17: Artnet
- lesson 21: free topic
- appendix2: Kernel menu tree
| Language: |
