- preamble
- lesson 6: Output plugins
- lesson 11: Trigger concepts
- lesson 13: Presets
- lesson 16: Softpult
- lesson 17: Artnet
- lesson 21: free topic
- appendix2: Kernel menu tree
In this lesson we explain advanced edit features for scenes and scene lists, e.g. for modification of already saved scenes.
Lecture 12: Editing scenes and scenelists
In lesson 8 we introduced the scene lists. In this lecture more advanced features are explained.
By default a new scene is added to an existing scene list by pressing the button "Store Cue". When you open the small dropdown arrow on right hand side of this button you see some more sophisticated capabilities with their short code. In most cases you have to mark a scene at first before applying this modification.
Datei:DMXC3L12 SL storemenue.jpg
Hint: The following operations are related to the values in the programmer.
| Function | short code | Description | Comment |
| Add | Strg+A | add a new scene to scene list at the end | default |
| Insert | Strg+I | insert a new scene to scenelist before selected scene | |
| Replace | Strg+R | replace current scene attributes by the values in the programmer | |
| Merge | Strg+M | merges selected scene with programmer values | programmer values with higher priority |
| Append | Strg+P | append new property from programmer to the selected scene | existing scene with higher priority, new values from programmer are added |
| Subtract | Strg+B | remove a property from selected scene | hint: modify the wanted property so that this appears in the programmer |
| Update | Strg+U | no function yet |
In similar way, there are also edit operations for the scene list itself. As known from EXCEL, you can copy, cut and delete whole rows. With the copy/paste content operations you can take over the value from single fields to other cues.
Datei:DMXC3L12 SL editmenue.jpg
Again, here is the summarizing table for explanation:
| Cut | Strg+X | cut the selected scene | like EXCEL "cut row" |
| Copy | Strg+C | copy the selected scene | like EXCEL "copy row" |
| Paste | Strg+V | paste the selected scene | like EXCEL "paste row" |
| Delete | Del(Entf) | delete the selected scene | like EXCEL "delete row" |
| Copy content | Strg+Alt+C | to copy single value | like EXCEL "copy cell" |
| Paste content | Strg+Alt+V | tp paste single value | like EXCEL "paste cell" |
Example: You have a scene list containing 10 cues. You set fade=2sec in first scene and want to take over thies value to the remaining cues:
- mark fade cell of first scene,
- select menue "copy content",
- mark the fade cells of other cues,
- select menue "paste content",
- ready!
Datei:DMXC3L12 SL optionmenue.jpg
Excercise
- Test the append and subtract scene functions
Certificate
I have understood the topics of this lecture and want to continue with next course: Lesson 13
