Lesson 7 Tut3
From English DMXC-Wiki
Revision as of 18:46, 25 December 2012 by Frank Burghardt (talk | contribs)
Template:Hauptüberschrift
In this lesson a final overview about the basic concepts for using the DMXControl 3 software is given. This completes the first part of the lectures "Basics, Setup and configuration"
Lecture 7: Summary and Details of Setup
Now we will finalise our first expedition through DMXControl by investigating other generic features.
There are lots of additional buttons in the main menu for operational support:
  • File
    • Here you can create, open and save projects
    • With "project properties" you can assign some notices to the current project
  • Windows
    • Beside some tools that will be explained laterly, here you have a chat tool. It is helpful, if several operators are programmers work in parallel with DMXControl 3. They can exchange some messages here.
    • The "manual beat tool" compares to the corresponding tool in DMXControl 2. By pressing the space key you can generate manual beats
  • Settings
    • Application settings: Double click the icons in order to set configuration options.
On left hand side you have some global icons. here we want to refer to
  • Fog
    • Here you have several operational modes for your DMX-controled fog device
  • Highlight
  • Blackout
    • As the name indicates: Blackout of all devices
The project explorer also contains some general buttons:
  • Edit -
  • Create directory / create device group -
  • Up / Down -
  • Device Manager -
  • Add item list / add Live view
  • Import / export files
This is for administative operations in your device configuration.
One helpful tool is missing for basic checks and settings of DMX channels: the channel overview. Here you get an overview about the current output. With the slider on left hand side you can also modify the value of selected channel.
Excercise
  • Set channel 34 to DMX value 128 with help of channel overview
  • Try the Highlight and Blackout mode (see results in Liveview panel)
Certificate
Great! You have now completed the first part of the DMXControl lecture!
I have understood the topics of this lecture and want to continue with next course: Lesson 8
