Template:Hauptüberschrift Template:NavigationTop-Tut3
- preamble
- lesson 6: Output plugins
- lesson 11: Trigger concepts
- lesson 13: Presets
- lesson 16: Softpult
- lesson 17: Artnet
- lesson 21: free topic
- appendix2: Kernel menu tree
In this lesson we introduce the Project Explorer. This lesson helps you to understand how to create and patch your fixtures (devices) in DMXControl 3. We will also show you how groups of devices are created (automatically).
Lecture 3: Creating and patching fixtures
The starting point for adding devices is the project explorer. Here you can find a tree of directories displaying the equipment and other items such as fixtures, devices, scene lists etc. The administration is intuitive by context menus (right mouse click) or buttons, e.g. for adding or deleting items.
Elements can also be moved by drag and drop or added to other elements. Whether an operation is allowed, is symbolized by the mouse icon.
The project explorer is the central project tree containing all elements of your project. It is primary intended to create and browse your items. For usage in the show programming we refer to "stage view" and other tools. |
Add devices
In the following step we will create 4 moving lights of type "TS-255".
Click either on the button Device Manager in the menu bar of the Project Explorer or choose in the left pane of the Project Explorer the folder Devices and do a right mouse click into the right pane and select device manager. Select your devices and fill in the requested data. Please pay attention to define the correct start addresses.
Device Groups
By setting the hook for "autogenerate group" a group element is created automatically containing all devices of this definition step. You can also create "user defined groups". Therefore you have to select the devices (e.g. in project explorer or in Stage View) and press the "Create Device Group" button. Renaming of groups (and other items) also can be made within the project explorer.
When you do a right mouse click on an item the property menu appears. Here you can set additional properties such as "device id", "enabled flag" etc.
In the Project Explorer you can also rename items by two single clicks on the name or the context menu.
Exercise
- create all devices as shown in the figure above: 4 TS-255, 2 generic dimmer (as front lights) and 8 RGB-PARs
- create two additional groups: all devices on left hand side and all devices on right hand side, rename these groups to "left" and "right"
Certificate
I have understood the topics of this lecture and wnt to continue with next course: Lesson 4 Template:NavigationTop-Tut3
