28 January 2013
- 20:3820:38, 28 January 2013 diff hist +241 Lesson 12 Tut3 corr
23 January 2013
- 08:4308:43, 23 January 2013 diff hist +1 m ToC Manual DMXC3 →Proposal for further discussion current
22 January 2013
- 12:1712:17, 22 January 2013 diff hist 0 m Lesson 11 Tut3 →Use of beat trigger: minor fixes
- 12:1312:13, 22 January 2013 diff hist −94 m Lesson 10 Tut3 minor fixes
- 12:1112:11, 22 January 2013 diff hist −64 m Lesson 8 Tut3 minor fixes part2
- 12:1012:10, 22 January 2013 diff hist −138 m Lesson 8 Tut3 minor fixes
- 12:0612:06, 22 January 2013 diff hist −63 m Lesson 7 Tut3 minor fixes
- 12:0412:04, 22 January 2013 diff hist −61 Lesson 6 Tut3 →Lecture 6: Configuring the output plugins: fixed images
- 11:5511:55, 22 January 2013 diff hist −3 m Template:Bild mit Unterschrift zu loeschen Fixed error from "Datei:" to "File:"
21 January 2013
- 19:2719:27, 21 January 2013 diff hist −169 Lesson 12 Tut3 quick correction of all pictures with subtitle
- 19:2119:21, 21 January 2013 diff hist −31 Lesson 12 Tut3 first corrections
- 19:1719:17, 21 January 2013 diff hist +1,119 N Template:Picture with subtitle Tried to generate an fix template
- 18:5418:54, 21 January 2013 diff hist 0 m Lesson 11 Tut3 →Use of beat trigger
- 18:5118:51, 21 January 2013 diff hist +119 Lesson 11 Tut3 corr
- 18:0818:08, 21 January 2013 diff hist +85 Lesson 10 Tut3 corr
13 January 2013
- 17:3817:38, 13 January 2013 diff hist −100 Lesson 9 Tut3 →Effects and filters: corr
12 January 2013
- 18:4618:46, 12 January 2013 diff hist −16 Lesson 9 Tut3 corrections up to ---Effects and filters--- (not corrected yet)
- 18:1918:19, 12 January 2013 diff hist +39 m Lesson 8 Tut3 No edit summary
- 18:1618:16, 12 January 2013 diff hist +536 Lesson 8 Tut3 →Lecture 8: Scenes (cues) and scene lists: corr
- 16:0116:01, 12 January 2013 diff hist +73 Lesson 7 Tut3 →Lecture 7: Summary and details of setup: Added BoxHint below
- 15:5115:51, 12 January 2013 diff hist +153 Lesson 7 Tut3 →Lecture 7: Summary and Details of Setup: corr
10 January 2013
- 20:0820:08, 10 January 2013 diff hist +15 m Lesson 6 Tut3 →Lecture 6: Configuring the output plugins
- 19:5719:57, 10 January 2013 diff hist −4 m Lesson 6 Tut3 →Lecture 6: Configuring the output plugins
- 19:5619:56, 10 January 2013 diff hist +8 Lesson 6 Tut3 →Lecture 6: Configuring the output plugins: corr
- 19:3619:36, 10 January 2013 diff hist +47 Lesson 5 Tut3 →Lecture 5: Setting properties of fixtures: corr
6 January 2013
- 20:3320:33, 6 January 2013 diff hist +5 m Lesson 4 Tut3 →Certificate
- 20:3220:32, 6 January 2013 diff hist +19 Lesson 4 Tut3 →Excercise: corrections
- 20:2920:29, 6 January 2013 diff hist +345 Lesson 4 Tut3 →Lecture 4: The live view (stage view): corrections
- 19:3119:31, 6 January 2013 diff hist +41 m Lesson 3 Tut3 →Device Groups
- 19:2719:27, 6 January 2013 diff hist +5 m Lesson 3 Tut3 →Certificate
- 19:2619:26, 6 January 2013 diff hist +1 m Lesson 3 Tut3 →Certificate
- 19:2419:24, 6 January 2013 diff hist +1 m Lesson 3 Tut3 →Add devices: corrections
- 19:1519:15, 6 January 2013 diff hist −6 Lesson 3 Tut3 →Lecture 3: Creating and Patching fixtures: corrections
- 19:0519:05, 6 January 2013 diff hist +2 Lesson 3 Tut3 →Overview: corrections
4 January 2013
- 17:2517:25, 4 January 2013 diff hist −1 m Lesson 2 Tut3 →Additional links and references
- 17:2317:23, 4 January 2013 diff hist +152 Lesson 2 Tut3 →Lecture 2: The Panel concepts of DMXControl 3 client: corrections
- 11:0711:07, 4 January 2013 diff hist −10 m Lesson 1 Tut3 →Excercise
- 11:0511:05, 4 January 2013 diff hist −250 Lesson 1 Tut3 →Project Management: corrections and adaption to german description
- 11:0011:00, 4 January 2013 diff hist −15 Lesson 1 Tut3 →The client: corrections
- 10:1910:19, 4 January 2013 diff hist +372 Lesson 1 Tut3 →Lecture: Installation and Configuration: corrections
- 09:4409:44, 4 January 2013 diff hist +26 Lesson 1 Tut3 corrections
3 January 2013
- 14:0514:05, 3 January 2013 diff hist +52 Tutorials DMXControl 3 →Tutorial for DMXControl 3.0: Some corrections
- 13:1313:13, 3 January 2013 diff hist −5 m Lesson 1 Tut3 →Certificate
- 13:1313:13, 3 January 2013 diff hist −4 m Lesson 1 Tut3 →Excercise: Replaces "Shut up" with "exit"
