Program settings DMXC2
Jump to navigation
Jump to search
Program settings DMXC2 |
Hint:
06.11.2013: UPrenner: work-in-progress
06.11.2013: UPrenner article ready, just update of pictures
If you are a native speaker, please Help us and review this
Contents
Essential attitudes can be adapted regarding the unusual features of the computer and/or the light configuration in the window program configuration.
The program configuration is divided up into 5 areas:
- General
- Graphical view
- Cues/Chasers
- Tools
- Output
Description
Tabulator General
Picture 1: Window program settings, tab general |
Setting | Meaning | Default | comment |
Performance | |||
Refresh interval for spectrum analyzer | Time interval after which new audio data are fetched by WinAmp | 50 ms | A larger interval can improve performance at weak computers |
Disable automatic saving of cue library | The cue library is stored periodically, by activation this storage can be put down. | not enabled | At great projects with outstandingly many cues, it can come to delays in the course of the chasers by the automatic storage of the cue library sometimes. |
View | |||
Font size for zoomed views | Type size in the graphical view at zoom | 8 | |
Indication of the DMX values % | Rearrangement between absolute and percent indication | not enabled | |
Program startup | |||
Execute command on programm start | To the start of DMXControl an command which switches on e. g. the Grundlich is executed. | no command defines | The command can about the DMXControl usual commands are defined. (see chapter command overview) |
Deactivating safety query at program end | Deactivating query when ending DMXControl | not enabled | |
Other | |||
Save color and gobo lists globally | The color and gobo lists aren't stored in the project directrory, but in the DMXControl directrory . | not enabled | Farb and Gobolisten can be used in all projects |
Flash "scroll lock" LED on beat | Beat from the beat tool or sound analyzer flashes the "scroll lock" LED. | not enabled |
For large projects with above average many cues, it may cause ever automatic storing of cue library delays in the flow of the chasers. In this case, disable the automatic fuse is advisable at this point. |
Tabulator Graphical view
Picture 2: Window program settings, tab graphical view |
Device-popups | |||
Open when hovering over the icon | DDF devices popups, opens when you move the mouse over it. | not enabled | |
Open after clicking the icon | DDF devices popups, opens when clicking the device icon. | enabled | |
Close after: ms | Time to close the DDF devices popups when the mouse leaves popup. | 1 sec. | |
Icons | |||
Size | Size of the icons in the graphical view in pixels | 32 pixel. | |
Change size when zooming | Information when zooming the graphical view also increase | not enabled | |
Use presetation of color instead of graphic | When enabled a programmed LED color is displayed in LED-RGB devices instead of the icons. | not enabled | |
Show device name and adress | The device names and addresses are displayed in addition to the icons in the graphical view of the stage | not enabled |
Tabulator Cues/Chasers
Picture 3: Window program settings, tab cues/chasers |
Cues | |||
Default set points for non-fading channels | About the slider can be set at what point the channel is switched on. | 50% | |
No warning when all channels should be saved. | When saving from all channels a warning carried DMXControl, since this database is also larger. Here, this warning can be turned off and be darurch more effectively worked. | not enabled | |
Chasers | |||
Start chasers on double click | It enables the start of a cue in the chaser by a double click. | not enabled | |
Threat ungrouped chasers as separate group | All of the chasers associated with any group form a distinct group activation. | not enabled | |
Align group names right hand | Sets the group names right in the chaser window from, rather than directly behind the chaser name. | enabled |
Tabulator Tools
Picture 4: Window program settings, tab tools |
Sound analyzer | |||
Quelle VBVis-Plugin | If the radio button VBVis plugin is enabled are imported the audio data for the BeatTool and the sound Analyzer via this plugin in Winamp after DMXControl. | enabled | |
Quelle AVS-Plugin | If the radio button AVS plugin import the audio data for the BeatTool and the sound Analyzer via this plugin in Winamp after DMXControl is enabled. | not enabled |
Tabulator Output
Picture 5: Window program settings, tab output |
DMX mixer | |||
Disable "Highest takes precendence" (HTP) mixing | With this option, DMX mix can be switched between LTP and HTP. | enabled | |
Use HTP for mixing RGB channels) | If you enable this option, also the RGB channels in the HTP-mode are mixed. | not enabled | |
Handle RGB channels as dimmer | If you enable this option, RGB channels handled devices as dimmer by LED. | not enabled | |
Let DDF's limit channel values (MinValue/MaxValue) | If this option is enabled, which transferred values from the DDF's min and MaxValue and included for the output. | not enabled | |
Apply values from all sources to selected device | If this option is enabled, clustered devices perform the same processes in the graphical view of the stage at the end of cues. | not enabled |
