Appendix 1 Tut3
From English DMXC-Wiki
Revision as of 21:41, 18 June 2011 by Frosch67 (talk | contribs)
DMXControl 3 appendix1
Summary of commands and shortcuts
linear fanning
Syntax Example Description
> 50 > 100 linear interpolation
<> 50 <> 100 linear interpolation: marginal devices: 100, central devices 50
>< 50 >< 100 contrary: marginal devices: 50, central devices 100
alternate fanning
# 50 # 100 alternate values 100/50/100/50 ...
# # 100 # 50 # 0 alternate values 100/50/0/100/50/0 ...
Fanning in property grid with mouse wheel
Key Value Description
no key pressed +1 / -1 dedicated color changes value
Shift +10 / -10 dedicated color changes value
STRG +1 & -1 Fanning / values are changed, z.B.118 > 154
ALT +1 / -1 values are changed
Shift+STRG +10 / -10 values are changed
Shift+ALT +10 & -10 values are changed in block
effect parameters
Attribut Example Description
Amplitude 50 > 100 value interval for selected attribute; can be set to negative value too
Offset [0..100] offset between group elements
Phase [0..1]  ?
Frequency [0..1]  cycle speed
LiveView
key action result
M ("Matrix") press key M and drag mouse a matrix is created from the selected icons
F ("Fanning") press key F and drag mouse icons are proportionally aligned (e.g. in a row)
C ("Circle") press key C and drag mouse icons are aligned in shape of circle
