DMXControl 3 appendix1
Summary of commands and shortcuts
There are some command options in the command line mode for getting detailed information on the status of the kernel:
- shutdown: Shut down the kernel.
- status: Displays information about the status
- menu: Access to control menu
- clear: Clears the console
- notification: Send a notification to all clients
- width: Defines width of console (number of characters)
- help: Help menu (also accessible via "?")
Additional second level menu commands exists for "menu" and "status".
linear fanning
Syntax | Example | Description |
> | 50 > 100 | linear interpolation |
<> | 50 <> 100 | linear interpolation: marginal devices: 100, central devices 50 |
>< | 50 >< 100 | contrary: marginal devices: 50, central devices 100 |
alternate fanning
# | 50 # 100 | alternate values 100/50/100/50 ... |
# # | 100 # 50 # 0 | alternate values 100/50/0/100/50/0 ... |
Fanning in property grid with mouse wheel
Key | Value | Description |
no key pressed | +1 / -1 | dedicated color changes value |
Shift | +10 / -10 | dedicated color changes value |
STRG | +1 & -1 | Fanning / values are changed, z.B.118 > 154 |
ALT | +1 / -1 | values are changed |
Shift+STRG | +10 / -10 | values are changed |
Shift+ALT | +10 & -10 | values are changed in block |
effect parameters
Attribut | Example | Description |
Amplitude | 50 > 100 | value interval for selected attribute; can be set to negative value too |
Offset | [0..100] | offset between group elements |
Phase | [0..1] | ? |
Frequency | [0..1] | cycle speed |
LiveView
key | action | result |
M ("Matrix") | press key M and drag mouse | a matrix is created from the selected icons |
F ("Fanning") | press key F and drag mouse | icons are proportionally aligned (e.g. in a row) |
C ("Circle") | press key C and drag mouse | icons are aligned in shape of circle |
- preamble
- lesson 6: Output plugins
- lesson 11: Trigger concepts
- lesson 13: Presets
- lesson 16: Softpult
- lesson 17: Artnet
- lesson 21: free topic
- appendix2: Kernel menu tree
Language: |
