- preamble
- lesson 6: Output plugins
- lesson 11: Trigger concepts
- lesson 13: Presets
- lesson 16: Softpult
- lesson 17: Artnet
- lesson 21: free topic
- appendix2: Kernel menu tree
Summary of commands and shortcuts
Linear fanning
| Syntax | Example | Description |
| > | 50 > 100 | linear interpolation |
| <> | 50 <> 100 | linear interpolation: marginal devices: 50, central devices 100 (mnemonic trick: In the symbol both signs are directed outside; there the first value is applied; the second value is applied in the center.) |
| >< | 50 >< 100 | contrary: marginal devices: 100, central devices 50 (mnemonic trick: In the symbol both signs are directed inside; there the first value is applied (in the center); the second value is applied at the edge.) |
Alternate fanning
| # | 50 # 100 | alternate values 100/50/100/50 ... |
| # # | 100 # 50 # 0 | alternate values 100/50/0/100/50/0 ... |
Fanning in property grid with mouse wheel
| Key | Value | Description |
| no key pressed | +1 / -1 | dedicated color changes value |
| Shift | +10 / -10 | dedicated color changes value |
| STRG | +1 & -1 | Fanning / values are changed, z.B.118 > 154 |
| ALT | +1 / -1 | values are changed |
| Shift+STRG | +10 / -10 | values are changed |
| Shift+ALT | +10 & -10 | values are changed in block |
Property Panels
| Key | Reaction | Description |
| Double click | zero position | e.g. Color panel, Position panel |
| Simple click to fader | stepwise increasement/decreasement of value | depending on whether one clicks above or below the current position |
Programmer
| Key | Reaktion | Description |
| ENTF | Deletes current line | select line, value is deleted from programmer |
effect parameters
| Attribut | Example | Description |
| Amplitude | 50 > 100 | value interval for selected attribute; can be set to negative value too |
| Phase | [0..1] | offset between group elements |
| Frequency | [0..1] | cycle speed |
Stage View
| key | action | result |
| M ("Matrix") | press key M and drag mouse | a matrix is created from the selected icons |
| F ("Fanning") | press key F and drag mouse | icons are proportionally aligned (e.g. in a row) |
| C ("Circle") | press key C and drag mouse | icons are aligned in shape of circle |
Cue list
| Function | short code | Description | Comment | ||||
| Add | Strg+A | add a new scene to scene list at the end | default | ||||
| Insert | Strg+I | insert a new scene to scenelist before selected scene | |||||
| Replace | Strg+R | replace current scene attributes by the values in the programmer | |||||
| Merge | Strg+M | merges selected scene with programmer values | programmer values with higher priority | ||||
| Append | Strg+P | append new property from programmer to the selected scene | existing scene with higher priority, new values from programmer are added | ||||
| Subtract | Strg+B | removes a property from selected scene | - | Sum (Special) | Inserts current output of devices into Cue List | ||
| PSum (Special) | Similar to Sum, but related to currently selected devices in Stage View | ||||||
| Preset (Special) | Opens a window, where you have the capability to add a Preset to Cue List | ||||||
| Scenelist (Special) | Inserts (similar to commands in DMXControl 2) a entry to impact another cue list |
| Edit in Programmer | Selected cue is loaded into Programmer. Programmer Output Mode is set to All | ||
| Edit in Programmer Blind | Selekted cue is loaded into Programmer. Programmer Output Mode is set to Blind | ||
| Cut | Strg+X | cut the selected scene | like EXCEL "cut row" |
| Copy | Strg+C | copy the selected scene | like EXCEL "copy row" |
| Paste | Strg+V | paste the selected scene | like EXCEL "paste row" |
| Delete | Del(Entf) | delete the selected scene | like EXCEL "delete row" |
| Renumber Cues | Renumber Cues | ||
| Cue Timing Editor | a separate editor is opened
Kernel
There are some command options in the command line mode for getting detailed information on the status of the kernel:
- shutdown: Shut down the kernel.
- status: Displays information about the status
- menu: Access to control menu
- clear: Clears the console
- notification: Send a notification to all clients
- width: Defines width of console (number of characters)
- help: Help menu (also accessible via "?")
Additional second level menu commands exists for "menu" and "status".
