Tutorial for DMXControl 3.0
If you are a user of DMXControl 2 and you want to test the beta version of DMXControl 3, you have to be willing to rethink some things. DMXControl 3 provides fantastic new features that did not fit into the framework of DMXControl 2. Therefore, we have prepared a tutorial as a guide to the new lighting control software DMXControl 3 for you.
During the transition from DMXControl2 to DMXControl 3 many new concepts have been introduced. A so-called HAL (Hardware Abstraction Layer) ensures that the program is independent from the DMX output, i.e. you work primarily with abstract properties such as color, position and beam instead of DMX values. Furthermore, there is now a separation in server and client, so that several people can work on one project at the same time. Great new opportunities in effect programming have been implemented, not inferior to professional DMX programs.
The basic differences between the releases of DMXControl 3 and 2 are described in the german article Übergang von DMXControl 2 zu 3 (german). It should be emphasized that DMXControl 2 will be maintained for some time and is provisionally proposed for usage as your main light control program.
Because of altered concepts the nature of the programming and operation has fundamentally changed. This requires that you start from the beginning again. We encourage you to study the following tutorial of the operating concepts of DMXControl 3 and to accept the changes. If you have understood the concepts, everything will be as common and simple as in DMXControl 2.
This tutorial is split into three parts:
- Lesson 1 to 7: Basic concepts, setup and configuration
- Lesson 8 to 14: Programming your cues and show
- Lesson 15 to 21: Execution of show and add-ons
If you find errrors anywhere or if you are not happy with some parts, please tell it to us by the bugtracker on the website, email or the betatest-thread on the homepage. If you are convinced that the approach of DMXControl 3 is great, please tell it to others via facebook, feedback thread, etc.;)
Thanks to Arne, Dennis, Franky, Mark, Matthias, Stefan (and others) for all the work they have put into DMXControl 3. At this tutorial Carlo, Frank, Jens-Peter, Uwe and some alpha testers were involved. Also, this tutorial is obviously still in beta stage. Please notify the manual team with your suggestions. A 'proper' manual will be created in parallel to the beta phase.
Now have fun in learning DMXControl 3!
Table of content
Links & References
| Videos: | DMXControl 3.0 - Videos (german) |
| FAQs: | DMXControl 3.0 (FAQ) (german) |
| more info: | Übergang von DMXControl 2 zu 3 (german) |
| Getting started with DMXControl 3 (german) |
