Stage Effect (DDF-Syntax) DMXC3
Jump to navigation
Jump to search
Stage Effect (DDF-Syntax) DMXC3 | Article describes DMXControl 3.2.2 |
Stage effects include fog and wind generated by a fan. Control of these functions in DMXControl 3 is exclusively through the Device Control.
Fog
The fog function controls the intensity of fog output, both in simple fog machines and hazers.
Variant | Code |
Standard with continuous increase of fog output | <fog dmxchannel="0" />
Fog output on channel 1 with linearly increasing intensity. |
Fog output adjustable only in a partial range | <fog dmxchannel="0">
<step type="stop" mindmx="0" maxdmx="0" />
<range type="fog" mindmx="32" maxdmx="255" minval="50" maxval="100" />
</fog>
Fog output on DMX channel 1:
Fan
The fan function controls the airflow of a fan. This can be either the fan in a hazer or a DMX-controlled wind machine.
Variant | Code |
Adjustable fan speed | <fan dmxchannel="0" />
Fan on DMX channel 1 with increasing speed from 0% at DMX value 0 to 100% at DMX value 255. |
Switched fan | <fan dmxchannel="0">
<step val="false" mindmx="0" maxdmx="127" />
<step val="true" mindmx="128" maxdmx="255" />
</fan>
Switched fan on DMX channel 1:
