11 November 2025
- 16:3616:36, 11 November 2025 diff hist +1,485 Troubleshooting (General Information) DMXC3 No edit summary current
13 July 2025
- 14:0914:09, 13 July 2025 diff hist 0 Log Files DMXC3 No edit summary current
2 March 2025
- 22:2422:24, 2 March 2025 diff hist −6 Effects and Filters DMXC3 No edit summary current
- 22:2022:20, 2 March 2025 diff hist +27 Template:Image with Caption No edit summary current
- 22:1822:18, 2 March 2025 diff hist −64 Template:BoxAdvanced No edit summary current
- 22:1722:17, 2 March 2025 diff hist −56 Template:BoxImportant No edit summary current
- 22:1622:16, 2 March 2025 diff hist −20 Template:BoxAchtung Removed redirect to Template:BoxAttention current Tag: Removed redirect
- 22:1522:15, 2 March 2025 diff hist −67 Template:BoxAttention No edit summary current
- 22:1522:15, 2 March 2025 diff hist −56 Template:BoxHint No edit summary current
- 22:1422:14, 2 March 2025 diff hist −15 Template:BoxHinweis Removed redirect to Template:BoxHint current Tag: Removed redirect
- 22:1022:10, 2 March 2025 diff hist +245 Matrix (DDF-Syntax) DMXC3 No edit summary current
- 22:0222:02, 2 March 2025 diff hist +233 Template:Manual Value No edit summary current
- 22:0022:00, 2 March 2025 diff hist +710 Radix (DDF-Syntax) DMXC3 No edit summary current
- 21:3521:35, 2 March 2025 diff hist +756 Matrix (DDF-Syntax) DMXC3 No edit summary
- 17:0817:08, 2 March 2025 diff hist +2 MediaWiki:Citizen.css No edit summary current
- 16:5616:56, 2 March 2025 diff hist −671 Intensity (DDF-Syntax) DMXC3 No edit summary current
- 16:5116:51, 2 March 2025 diff hist +412 Position (DDF-Syntax) DMXC3 No edit summary current
- 16:4416:44, 2 March 2025 diff hist −587 Color (DDF-Syntax) DMXC3 No edit summary current
- 16:3716:37, 2 March 2025 diff hist −207 Matrix (DDF-Syntax) DMXC3 No edit summary
- 16:3216:32, 2 March 2025 diff hist −106 Radix (DDF-Syntax) DMXC3 No edit summary
- 16:3016:30, 2 March 2025 diff hist −812 Gobo (DDF-Syntax) DMXC3 No edit summary current
- 16:2516:25, 2 March 2025 diff hist −634 Beam (DDF-Syntax) DMXC3 No edit summary current
- 16:0916:09, 2 March 2025 diff hist +1,183 Blades (DDF-Syntax) DMXC3 No edit summary current
- 16:0016:00, 2 March 2025 diff hist −694 Open Function (DDF-Syntax) DMXC3 No edit summary current
- 15:4115:41, 2 March 2025 diff hist 0 Stage Effect (DDF-Syntax) DMXC3 No edit summary current
- 15:3815:38, 2 March 2025 diff hist −786 Effectwheel (DDF-Syntax) DMXC3 No edit summary current
- 15:1115:11, 2 March 2025 diff hist +541 Template:DMXC3 Manual-Tableheader DDF-Code attributes No edit summary current
- 15:0515:05, 2 March 2025 diff hist +941 Template:DMXC3 Manual-Tableheader DDF-Code attributes No edit summary
- 15:0015:00, 2 March 2025 diff hist +1,326 N Template:DMXC3 Manual-Tableheader DDF-Code attributes Created page with "<includeonly>{{(!}} class="wikitable toptextcells" {{!-}} class="hintergrundfarbe10" {{#ifeq: {{{1}}} | de | ! style="width: 200px {{!}} Attribut {{#switch: {{{2}}} <!-- Block 1 --> | #default = !! style="width: 175px {{!}} type | step-val = !! style="width: 175px {{!}} type !! style="width: 175px {{!}} val | range-range = !! style="width: 175px {{!}} range | range-handler = !! style="width: 175px {{!}} handler | range-temp =}} {{#switch: {{{2}}} <!-- Block 2 --> | #defa..."
- 14:5914:59, 2 March 2025 diff hist +6 Introduction (DDF-Syntax) DMXC3 No edit summary current
- 13:5513:55, 2 March 2025 diff hist −93 Stage Effect (DDF-Syntax) DMXC3 No edit summary
- 13:5213:52, 2 March 2025 diff hist +27 Stage Effect (DDF-Syntax) DMXC3 No edit summary
- 13:4913:49, 2 March 2025 diff hist +32 DDF-Tutorial 4-Spot-Bar DMXC3 No edit summary current
- 13:4713:47, 2 March 2025 diff hist +15 DDF-Tutorial LED-Spotlight DMXC3 No edit summary current
- 13:4313:43, 2 March 2025 diff hist −37 Procedures examples (DDF-Syntax) DMXC3 No edit summary
- 13:4213:42, 2 March 2025 diff hist −39 Procedures functions (DDF-Syntax) DMXC3 No edit summary
- 13:4013:40, 2 March 2025 diff hist +18 Template:DMXC3 Manual-Navigation DDF No edit summary current
- 13:3813:38, 2 March 2025 diff hist −37 Open Function (DDF-Syntax) DMXC3 No edit summary
- 13:3613:36, 2 March 2025 diff hist −6 Stage Effect (DDF-Syntax) DMXC3 No edit summary
- 13:3413:34, 2 March 2025 diff hist −3 Effectwheel (DDF-Syntax) DMXC3 No edit summary
- 13:3313:33, 2 March 2025 diff hist −4 Blades (DDF-Syntax) DMXC3 No edit summary
- 13:3113:31, 2 March 2025 diff hist −4 Beam (DDF-Syntax) DMXC3 No edit summary
- 13:3013:30, 2 March 2025 diff hist +3 Gobo (DDF-Syntax) DMXC3 No edit summary
- 13:2613:26, 2 March 2025 diff hist −5 Radix (DDF-Syntax) DMXC3 No edit summary
- 13:2513:25, 2 March 2025 diff hist −3 Matrix (DDF-Syntax) DMXC3 No edit summary
- 13:2413:24, 2 March 2025 diff hist −1 Color (DDF-Syntax) DMXC3 No edit summary
- 13:2313:23, 2 March 2025 diff hist −5 Color (DDF-Syntax) DMXC3 No edit summary
- 13:2213:22, 2 March 2025 diff hist −4 Position (DDF-Syntax) DMXC3 No edit summary
- 13:2013:20, 2 March 2025 diff hist −10 Intensity (DDF-Syntax) DMXC3 No edit summary
- 13:1913:19, 2 March 2025 diff hist −4 Basic rules (DDF-Syntax) DMXC3 No edit summary current
