| Blades (DDF-Syntax) DMXC3 | Article describes DMXControl 3.2.0 |
| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Unknown user) of this page. | This page was last edited at 01:04, 7 February 2024 (UTC) 867 days ago. |
| Table of contents | ||||||
Shutter blades are superficially comparable to an iris because both systems sharply define the light beam. However, unlike the iris, shutter blades are mechanically much more complex and require up to eight individually controllable actuators to remotely control the numerous individual blades typically installed in the shutter blade module via DMX. With the help of a shutter blade module, the light beam can be shaped into a precise illumination of objects and scenes, for example, in the form of a triangle or rectangle, such as in theater productions. For graphical control, the GUI provides a corresponding Control Panel.
| Variant | Code |
| Blades are retracted via one DMX channel, and the second channel determines the angle | <blades>
<bladetop dmxchannel="0" />
<bladetopangle dmxchannel="1" pointofrotation="center">
<range range="60" mindmx="0" maxdmx="255" />
</bladetopangle>
<bladeright dmxchannel="2"/>
<bladerightangle dmxchannel="3" pointofrotation="center" >
</bladerightangle>
<bladebottom dmxchannel="4" />
<bladebottomangle dmxchannel="5" pointofrotation="center">
<range range="60" mindmx="255" maxdmx="0" />
</bladebottomangle>
<bladeleft dmxchannel="6"/>
<bladeleftangle dmxchannel="7" pointofrotation="center" >
</bladeleftangle>
</blades>
Shutter blade module from DMX channel 1:
| Indexing of the entire shutter blade module | <blades>
<bladeindex dmxchannel="0">
<range range="90" mindmx="0" maxdmx="255" />
</bladeindex>
</blades>
Rotation (indexing) of the entire shutter blade module in a range of +/-45° via DMX channel 1. |
