Matrix (DDF-Syntax) DMXC3
Matrix
Basic Structure
Variant |
Code
RGB matrix with five rows and five columns, automatically patched
<matrix dmxchannel="0" rows="5" columns="5"/>
Matrix with five rows and five columns, where addressing is automatic from top left to bottom right, row by row:
- First pixel on DMX channels 1 to 3, arranged in the upper left corner.
RGB matrix with two rows and three columns, manually patched
<matrix rows="2" columns="3">
<rgb>
<red dmxchannel="0" />
<green dmxchannel="1" />
<blue dmxchannel="2" />
</rgb>
<rgb>
<red dmxchannel="3" />
<green dmxchannel="4" />
<blue dmxchannel="5" />
</rgb>
<!-- and so on -->
</matrix>
Matrix with two rows and three columns, where addressing is manual from top left to bottom right, row by row:
- RGB pixel top left: DMX channels 1 to 3.
- RGB pixel top middle: DMX channels 4 to 6.
- RGB pixel bottom right: DMX channels 16 to 18.
Attribute |
rows |
columns
Description
Number of rows of the matrix
Number of columns of the matrix
Permissible Attribute Value
1 to 256
1 to 256
Additional Attributes
The matrix can be further customized with additional attributes:
matrix
(main tag)
- Color offset: Specifies the DMX channels for the RGB+-colors white, amber, etc.
monochrome
: Matrix as a monochrome matrix
rowfirst
: Changes the automatic patch order
Matrices with RGB+-Colors
Variant |
Code
RGBW matrix with two rows and six columns, automatically patched
<matrix dmxchannel="0" rows="2" columns="6" whiteoffset="3" />
Matrix with two rows and six columns, where addressing is automatic from top left to bottom right, row by row:
- First pixel of the RGBW matrix on DMX channel 1, arranged in the upper left corner.
- Offset for control channel of the white LED at value
3 , since LED color is in the fourth position in the control sequence (RGBW LED type).
Attribute |
whiteoffset
Description
Offset of the white LED
Greater than 3
For the permissible values of the attributes rows
and columns
, see the previous section simple matrix.
Monochrome Matrices
Variant |
Code
Monochrome matrix with five rows and five columns, automatically patched
<matrix dmxchannel="0" monochrome="true" rows="5" columns="5"/>
- First pixel on DMX channel 1, arranged in the upper left corner.
- Attribute
monochrome with the value true generates a matrix with only one color.
Monochrome matrix with one row and four columns, manually patched
<matrix rows="
1" columns="4" monochrome="true" >
<dimmer dmxchannel="0" />
<dimmer dmxchannel="1" />
<dimmer dmxchannel="2" />
<dimmer dmxchannel="3" />
</matrix>
Matrix with one row and four columns, where addressing is manual from left to right:
- Attribute
- 1st pixel (left): DMX channel 1.
- 2nd pixel: DMX channel 2.
- 3rd pixel: DMX channel 3.
- 4th pixel (right): DMX channel 4.
Attribute |
monochrome
Description
Generating a monochrome matrix
true
and columns
