Beam (DDF-Syntax) DMXC3
From English DMXC-Wiki
Revision as of 15:25, 10 February 2024 by Unknown user
Books.png Beam (DDF-Syntax) DMXC3 Article describes
DMXControl 3.2.1
Table of contents
Part 1: Basics
Part 2: Functions
Part 3: Procedures
Part 4: Examples
Focus, Frost, Iris, and Zoom are functions in the DDFs for DMXControl 3, which are assigned to the group Light beam and primarily affect the width of the light beam. The GUI provides a corresponding Control Panel for this purpose.
Focus
The focus function is particularly used for the motorized "sharp focusing" of gobos for moving heads and scanners and can be expanded to a resolution of 16 bits by inserting finedmxchannel="1".
Case Code example
Standard
<focus dmxchannel="0">
</focus>
Focus on DMX channel 1:
  • Linear adjustment of the focus from close at DMX value 255 to far at DMX value 0.
Attribute type mindmx maxdmx minval maxval
Description DMX value for close focus DMX value for far focus Close focus Far focus
Permissible attribute value linear 0 to 255 0 to 255 0 % to 100 % 0 % to 100 %
HAL standard 100 % 0 %
Frost
The frost filter can be used to soften a light beam. Some devices have a so-called linear frost filter, where the light beam can be increasingly softened. Other devices, on the other hand, only insert a disk with a frost filter into the light beam.
Case Code example
Linear frost filter
<frost dmxchannel="0">
  <range mindmx="0" maxdmx="255" minval="0" maxval="100" />
</frost>
Frost on DMX channel 1:
  • Linear adjustment of the frost from no frost filter at DMX value 0 to fully inserted frost filter at DMX value 255.
Simple frost filter
  <step type="open" mindmx="0" maxdmx="127" />
  <range type="linear" mindmx="128" maxdmx="255" minval="100" maxval="100" />
</frost>
  • No frost filter between DMX value 0 and 127.
  • Frost filter fully inserted at DMX value between 128 and 255.
Description DMX value for no frost filter DMX value for frost filter inserted No frost Frost inserted
Permissible attribute value open
0 to 255 0 to 255
Iris
With the iris, the size or projection range of the light beam can be varied. The iris works in lighting technology just like the iris in a camera. Unlike the zoom, the beam angle does not change with the opening and closing of the iris. With the iris almost closed, only a small portion of the light beam is allowed through the aperture.
The iris function can be expanded to a resolution of 16 bits by inserting finedmxchannel="1".
Case Code example
Standard
<iris dmxchannel="0">
</iris>
Iris on DMX channel 1:
  • Linear opening of the iris from fully open (0%) at DMX value 0 to closed or iris fully retracted (100%) at DMX value 128.
Description DMX value for smallest aperture DMX value for largest aperture Smallest aperture (closed) Largest aperture (open)
Zoom
The zoom function changes the beam angle / opening angle of the device's light beam. It should not be confused with the iris. The zoom function can be expanded to a resolution of 16 bits by inserting finedmxchannel="1".
Case Code example
Linear zoom
<zoom dmxchannel="0" >
</zoom>
Zoom on DMX channel 1:
  • Linear reduction of the light beam from 30° at DMX value 0 to 14° at DMX value 255.
Zoom in multiple fixed steps
<zoom dmxchannel="0">
  <step val="15" mindmx="0" maxdmx="85" />
  <step val="20" mindmx="86" maxdmx="171" />
  <step val="25" mindmx="172" maxdmx="255" />
</zoom>
Zoom with three fixed opening angles on DMX channel 1:
  • Zoom angle of 15° at DMX value between 0 and 85.
  • Zoom angle of 20° at DMX value between 86 and 171.
  • Zoom angle of 25° at DMX value between 172 and 255.
Description DMX value for smallest opening angle DMX value for largest opening angle Smallest opening angle Largest opening angle
Permissible attribute value linear 0 to 255 0 to 255 0° to 90° 0° to 90°
