| Article describe DMXControl 3.2.3 Stand: 02.03.2025 |
Matrix (DDF-Syntax) DMXC3 | ||||||||||||||||||||||||||||||
Matrix
Basic structure
| Variant | Code |
| RGB matrix with five rows and five columns, automatically patched | <matrix dmxchannel="0" rows="5" columns="5"/>
Matrix with five rows and five columns, where addressing is automatic from top left to bottom right, row by row:
| RGB matrix with two rows and three columns, manually patched | <matrix rows="2" columns="3">
<rgb>
<red dmxchannel="0" />
<green dmxchannel="1" />
<blue dmxchannel="2" />
</rgb>
<rgb>
<red dmxchannel="3" />
<green dmxchannel="4" />
<blue dmxchannel="5" />
</rgb>
<rgb>
<red dmxchannel="6" />
<green dmxchannel="7" />
<blue dmxchannel="8" />
</rgb>
<rgb>
<red dmxchannel="9" />
<green dmxchannel="10" />
<blue dmxchannel="11" />
</rgb>
<rgb>
<red dmxchannel="12" />
<green dmxchannel="13" />
<blue dmxchannel="14" />
</rgb>
<rgb>
<red dmxchannel="15" />
<green dmxchannel="16" />
<blue dmxchannel="17" />
</rgb>
</matrix>
Matrix with two rows and three columns, where addressing is manual from top left to bottom right, row by row:
| Attribute | rows | columns |
| Description | Number of rows of the matrix | Number of columns of the matrix |
| Permissible Attribute Value | 1 to 256
1 to 256
| If the matrix is defined as an RGBW matrix, the "White Auto Mix" function of the Hardware Abstraction Layer (HAL) takes effect. However, in the Device Control, only entries for red, green, and blue continue to be generated. |
Additional Attributes
The matrix can be further customized with additional attributes:
matrix(main tag)- Color offset: Specifies the DMX channels for the RGB+-colors white, amber, etc.
monochrome: Matrix as a monochrome matrixrowfirst: Changes the automatic patch order
Matrices with RGB+ colors
| Variant | Code |
| RGBW matrix with two rows and six columns, automatically patched | <matrix dmxchannel="0" rows="2" columns="6" whiteoffset="3" />
Matrix with two rows and six columns, where addressing is automatic from top left to bottom right, row by row:
| Attribute | whiteoffset |
| Description | Offset of the white LED |
| Permissible Attribute Value | Greater than 3
For the permissible values of the attributes rows and columns, see the previous section simple matrix.
Monochrome matrices
| Variant | Code |
| Monochrome matrix with five rows and five columns, automatically patched | <matrix dmxchannel="0" monochrome="true" rows="5" columns="5"/>
| Monochrome matrix with one row and four columns, manually patched | <matrix rows="1" columns="4" monochrome="true" >
<dimmer dmxchannel="0" />
<dimmer dmxchannel="1" />
<dimmer dmxchannel="2" />
<dimmer dmxchannel="3" />
</matrix>
Matrix with one row and four columns, where addressing is manual from left to right:
| Attribute | monochrome |
| Description | Generating a monochrome matrix |
| Permissible Attribute Value | true
