| Article describe DMXControl 3.2.1 Stand: 02.03.2025 |
Radix (DDF-Syntax) DMXC3 | ||||||||||||||||||||||||||||||
In a radial matrix (shortly Radix), the controllable pixels are arranged in a circular pattern. Depending on the device's design, either multiple LEDs are grouped together (for example, two half rings) or all LEDs can be addressed individually. For radial matrices, DMXControl 3 provides its own group of effects. For targeted pixel control, the GUI provides a corresponding control panel window.
Radix
Basic structure
| Variant | Code |
| Radial matrix (Radix) with three rings and a total of 19 RGB pixels, automatically patched in sequence | <radix dmxchannel="0">
<ring segments="1" />
<ring segments="6" />
<ring segments="12" />
</radix>
Matrix with three rings, where addressing is automatic from inside to outside:
| Radial matrix (Radix) with two rings and a total of 7 RGB pixels, manually specified pixel positions | <radix dmxchannel="0">
<ring>
<segment nr="0"/>
</ring>
<ring>
<segment nr="1"/>
<segment nr="3"/>
<segment nr="5"/>
<segment nr="2"/>
<segment nr="4"/>
<segment nr="6"/>
</ring>
</radix>
Matrix with two rings, where addressing is automatic based on the pixels:
Note: Additional rings can be addressed by adding the |
| Radial matrix (Radix) with three rings and a total of 19 RGBW pixels, manually specified DMX addresses of the pixels | <radix>
<ring>
<rgb>
<r dmxchannel="0"/>
<g dmxchannel="1"/>
<b dmxchannel="2"/>
<w dmxchannel="3"/>
</rgb>
</ring>
<ring>
<rgb>
<r dmxchannel="4"/>
<g dmxchannel="5"/>
<b dmxchannel="6"/>
<w dmxchannel="7"/>
</rgb>
<rgb>
<r dmxchannel="8"/>
<g dmxchannel="9"/>
<b dmxchannel="10"/>
<w dmxchannel="11"/>
</rgb>
<rgb>
<r dmxchannel="24"/>
<g dmxchannel="25"/>
<b dmxchannel="26"/>
<w dmxchannel="27"/>
</rgb>
</ring>
<ring>
<rgb>
<r dmxchannel="28"/>
<g dmxchannel="29"/>
<b dmxchannel="30"/>
<w dmxchannel="31"/>
</rgb>
<rgb>
<r dmxchannel="32"/>
<g dmxchannel="33"/>
<b dmxchannel="34"/>
<w dmxchannel="35"/>
</rgb>
<rgb>
<r dmxchannel="72"/>
<g dmxchannel="73"/>
<b dmxchannel="74"/>
<w dmxchannel="75"/>
</rgb>
</ring>
</radix>
Matrix with three rings, where addressing of the pixels is manual:
Additional attributes
The radial matrix can be customized using various attributes. These attributes are assigned either to the parent tag radix or to the ring tags.
radix(main tag)- Color offset: Specifies the DMX channels for the RGB+-colors white, amber, etc.
shape:round/honeycomb- Basic arrangement of the pixels
ring(subordinate tag)angleoffset: Positioning of the first pixel of a ring
shape
The shape attribute defines the arrangement of the pixels. Currently, two variants are commonly used:
- Round arrangement: The individual pixels actually describe a circle.
- Honeycomb: The rings are arranged more hexagonally.
angleoffset
| Variant | Code |
| RGB Radix with angular offset between outer two rings, pixels automatically patched in sequence | <radix dmxchannel="0">
<ring segments="6" angleoffset="15" />
<ring segments="12" angleoffset="60" />
</radix>
