| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 12:57, 22 October 2013 (UTC) 4677 days ago. |
Hint:
20.5.2013: JKuehn: create the article page
| Figure 1: DMXControl Program icon |
To the start of DMXControl about the program icon (see figure 1) DMXControl's tax center opens (see figure 2).
This window offers the operator the access to all modules, tools and configurations of DMXControl.
Except over the menu items « File » « Window » « Configuration » and « ? » The possibility of this calling icons about this one in the icon strip is (help), for the most important modules and tools.
Furthermore the status line gives you information about the path and the file of the loaded project as well as the approximate load of the internal message system on the lower window edge of the tax center. In addition, the date, the current system time and the version number are still announced by DMXControl here.
| Figure 2: The control center of DMXControl |
- to open, save and quit your show (menue « Files »)
- to get all your tools from DMXControl (menue « Windows »)
- to setup your system (menue « Setup »)
- to call the support funktions (menue « ? »)
Control elements
The Windows standard menu items are in the menu files.
| Icon | Menue item | Shortcut | Description |
| Neu | Neues Projekt... | n.a. | Erstellen eines neuen Projekts. |
| Öffnen | Öffnen... | n.a. | Projekt Öffnen. |
| Speichern | Speichern... | STRG+S | Überschreibt das aktuell ausgewählte Projekt. |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Speichern unter... | n.a. | Speichert das Projekt im ausgewählten Ordner. |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Pack & Go... | n.a. | Komplettes Projekt archivieren, z.B. für den Umzug auf einen neuen oder zweiten Rechner. (siehe Kapitel 31) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Beenden | n.a. | Beendet DMXControl mit den üblichen Sicherheits- und Speicherabfragen. |
Das Menü Fenster
Gruppierung 1
| Icon | Menüpunkt | Shortcut | Beschreibung |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Geräte | n.a. | Öffnen des Gerätefensters zum Verwalten der Geräte. (siehe Kapitel 6) |
| Grafische Bühnenansicht | Grafische Bühnenansicht | n.a. | Öffnet die grafische Bühnenansicht. (siehe Kapitel 5) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Gruppenauswahl | n.a. | Öffnet das Fenster der Gruppenauswahl. (siehe Kapitel 5) |
| Kanalübersicht | Kanalübersicht | n.a. | Öffnet das Fenster der Kanalübersicht. (siehe Kapitel 8) |
Gruppierung 2
| BeatTool | BeatTool | n.a. | Öffnet das BeatTool Fenster für Sound-to-Light-Steuerung. (siehe Kapitel 15) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | DMXIn-Fernsteuerung | n.a. | Öffnet das Fenster zur Aktivierung der DMXIn-Fernsteuerung. (siehe Kapitel 28) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Joystickfernsteuerung | n.a. | Öffnet das Fenster zur Konfigurierung der Joystickfernsteuerung. (siehe Kapitel 26) |
| Kommandobox | Kommandobox | n.a. | Öffnet das Fenster der Kommandobox. (siehe Kapitel 16) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Kommandozeile | n.a. | Öffnet das Fenster der Kommandozeile. (siehe Kapitel 20) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Midi-Fernsteuerung | n.a. | Öffnet das Fenster zur Aktivierung der Midi-Fernsteuerung. (siehe Kapitel 27) |
| Master | Master | n.a. | Öffnet das Master-Fenster mit den Masterfadern. (siehe Kapitel 13) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | PDA-Fernsteuerung | n.a. | Öffnet das Fenster für die PDA-Konfiguration. (siehe Kapitel 24) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Tastatursteuerung | n.a. | Öffnet das Fenster zur Aktivierung der Tastatursteuerung. (siehe Kapitel 25) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Zeitplaner (Experimentell) |
n.a. | Öffnet das Fenster des Zeitplaners. (siehe Kapitel 21) |
Gruppierung 3
| Audioplayer | Audioplayer | n.a. | Öffnet das Fenster des Audioplayers. (siehe Kapitel 17) |
| Effektsequencer | Effektsequencer | n.a. | Öffnet das Fenster des Effektsequencers. (siehe Kapitel 11) |
| Sound Analyzer | Soundanalyzer | n.a. | Öffnet das Fenster des Sound Analyzers für Sound-to-Light-Konfiguration. (siehe Kapitel 14) |
| Submaster | Submaster | n.a. | Öffnet das Submaster Fenster. (siehe Kapitel 12) |
| Szenenliste | Szenenliste | n.a. | Öffnet das Fenster der Szenenliste. (siehe Kapitel 10) |
| Textbuch | Textbuch | n.a. | Öffnet das Fenster des Textbuches. (siehe Kapitel 19) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Timecode-Player | n.a. | Öffnet das Fenster des Timecode-Players. (siehe Kapitel 18) |
Gruppierung 4
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Szenenbibliothek anzeigen | STRG+B | Öffnet das Fenster der Szenenbibliothek. (siehe Kapitel 9) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Bearbeitungsansicht | STRG+E | Versteckt Konfigurationspunkte für den Live-Betrieb. |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Alle Fenster auf den primären Desktop holen | n.a. | Hat man mit mehreren Monitoren gearbeitet, kann es bei der Rückkehr in den Single-Monitor-Betrieb passieren, dass sich noch Fenster auf einem der dann virtuellen Monitor befinden. Mit dieser Funktion können fehlende Fenster für die Bearbeitung wieder auf den primären Monitor geholt werden. Voraussetzung ist, dass das Fenster geöffnet ist. |
Das Menü Konfiguration
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Ausgabeplugins.. | n.a. | Öffnet das Fenster zum Einstellen und Konfigurieren der Ausgabeplugins. (siehe Kapitel 7) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Plugins.. | n.a. | Öffnet das Fenster zum Einstellen und Konfigurieren der zusätzlichen Plugins. (siehe Kapitel 30) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Programmkonfiguration... | n.a. | Öffnet das Fenster Programmkonfiguration. (siehe Kapitel 29) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Midifernbedienung... | n.a. | Öffnet das Fenster zur Konfiguration der Midifernbedienung. (siehe Kapitel 27) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | DMXIn-Fernbedienung... | n.a. | Öffnet das Fenster zur Konfiguration der DMXIn-Fernbedienung. (siehe Kapitel 28) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Joystickkontrolle... | n.a. | Öffnet das Fenster zur Konfiguration der Joystickkontrolle. (siehe Kapitel 26) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Tastaturkontrolle... | n.a. | Öffnet das Fenster zur Konfiguration der Tastaturkontrolle. (siehe Kapitel 25) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Farblisten... | n.a. | Öffnet das Fenster zur Definition der Farblisten. (siehe Kapitel 6) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Gobolisten... | n.a. | Öffnet das Fenster zur Definition der Gobolisten. (siehe Kapitel 6) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Figureneditor... | n.a. | Öffnet das Fenster des Figureneditors für das Bewegungszenenmodul. (siehe Kapitel 23) |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Englisch Deutsch |
n.a. | Einstellung der Sprache für DMXControl. |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Experimentelle Programmteile zeigen | n.a. | Ist dieser Menüpunkt ausgewählt, dann erscheinen auch die Programmteile, die noch nicht ausgiebig getestet wurden und sich noch im Beta-Stadium befinden. In der 2.12 sind zur Zeit keine experimentellen Programmteile integriert, einzig einige Plugins benötigen diesen Punkt, damit sie angezeigt werden. (z.B. das Plugin BeatDetection) |
Das Menü Hilfe "?"
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | PDF-Handbuch öffen | n.a. | Öffnet dieses Handbuch als PDF auf dem Rechner. Das PDF-Handbuch wird in regelmäßigen Abständen aktualisiert, eine aktuelle Version befindet sich auf der Homepage zum Download und braucht einfach nur ins DMXControl-Programmverzeichnis kopiert werden. |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Online-Handbuch öffen | n.a. | Öffnet dieses Handuch im DMXControl online Wiki. Das Wiki ist soweit möglich immer auf dem aktuellen Stand und wird stetig verbessert bzw. überarbeitet. Handbuchfehler und Verbesserungsvorschläge können im DMXControl Bugtracker unter Handbuch DMXC2 eingetragen werden. |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Homepage besuchen | n.a. | Öffnet den Browser auf dem Rechner und ruft die DMXControl Homepage auf. |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | DMXControl Forum | n.a. | Öffnet den Browser auf dem Rechner und ruft das DMXControl Forum auf, hier erhalten Sie online Hilfe von der Community. |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Info | n.a. | Info-Fenster von DMXControl mit Informationen zur Release- und Buildnummer. Wichtig für Fehlerbeschreibungen. |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Space.png | Debug-Ausgabe anzeigen | n.a. | Hier öffnet sich ein Fenster, in dem Sie die Debug-Ausgabe zur Fehlersuche befindet. |
| Icon | Bezeichnung | Beschreibung |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Blackout.png | Blackout | Bei Betätigen des Icons werden alle Dimmerkanäle auf den DMX-Wert 0 gesetzt, ein erneutes Betätigen gibt wieder die aktuellen Werte der Module in DMXControl aus. |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Freeze.png | Freeze | Bei Betätigen des Icons wird die Ausgabe eingefroren, d.h. die zuletzt ausgegebenen Werte stehen weiterhin am Ausgang an. Änderung, die während der Aktivierung von Freeze gemacht werden, wirken sich erst nach erneuter Betätigung auf das Ausgangssignal aus. Dagegen wirkt sich der Freeze Button in der grafischen Bühnenansicht nur auf die Ausgabe aus der grafischen Bühnenansicht aus. |
| Bild:DMXC2_Manual_Steuerzentrum_Icon-Audioszene.png | Audiowiedergabe | Eine gestartete Audioszene kann mit diesem Button vorzeitig abgebrochen werden, bzw. über das Dropdown-Menü kann eine der 16 Audioszenen manipuliert werden. |
| Bild:DMXC2_Manual_Steuerzentrum_Button_Hinzufuegen.png | Hinzufügen | Der Button Hinzufügen ist in DMXControl in fast allen Fenstern enthalten und dient zum Hinzufügen von Szenen, Erstellen von neuen Listen, Effekten usw. |
| Bild:DMXC2_Manual_Steuerzentrum_Button_Delete.png | Löschen | An allen Stellen, an denen man den Button Hinzufügen findet, gibt es auch den Button Löschen. |
| Bild:DMXC2_Manual_Steuerzentrum_Button_Copy.png | Kopieren | Der Button Kopieren taucht an einigen Stellen auf, um Szenen oder Effekte zu kopieren. |
| Bild:DMXC2_Manual_Steuerzentrum_Button_Umbenennen.png | Umbenennen | Mit diesem Button können Namen von Listen oder auch Effekten umbenannt werden. |
| Bild:DMXC2_Manual_Steuerzentrum_Button_Arrow-UP.png | Verschieben hoch | Dieser Button dient zum nach oben Verschieben von Einträgen in Listen. |
| Bild:DMXC2_Manual_Steuerzentrum_Button_Arrow-DOWN.png | Verschieben runter | Dieser Button dient zum nach unten Verschieben von Einträgen in Listen. |
| Bild:DMXC2_Manual_Steuerzentrum_Button_Edit.png | Bearbeiten | Mit diesem Button kann der ausgewählte Eintrag oder die ausgewählte Szene geändert werden. |
| Bild:DMXC2_Manual_Steuerzentrum_Button_Reset.png | Rücksetzen | Mit dem Rücksetzen Button wird die Ausgabe im aktuellen Fenster auf default zurückgesetzt. |
| Bild:DMXC2_Manual_Steuerzentrum_Button_Play.png | Starten | Der Starten Button taucht an allen Stellen auf, wo eine Sequenz von Szenen zum Ablauf gestartet werden kann. |
Die modulbezogenen Befehle beziehen sich im wesentlichen auf die Buttons Blackout und Freeze.
- Modul: DMX-Ausgabe
| Blackout | Der Blackout-Befehl bezieht sich auf das Blackout-Icon im Steuerzentrum und in der grafischen Bühnenansicht. | Umschalten | Der Befehl Umschalten invertiert den momentanen Zustand der Blackout-Funktion. |
| Ein | Der Befehl Ein aktiviert die Blackout-Funktion. | ||
| Aus | Der Befehl Aus deaktiviert die Blackout-Funktion. | ||
| Freeze | Der Freeze-Befehl bezieht sich auf das Freeze-Icon im Steuerzentrum und in der grafischen Bühneansicht. | Umschalten | Der Befehl Umschalten invertiert den momentanen Zustand der Freeze-Funktion. |
| Ein | Der Befehl Ein aktiviert die Freeze-Funktion. | ||
| Aus | Der Befehl Aus deaktiviert die Freeze-Funktion. |
| T | Umschalt-Modus | Das Flag »Umschalt-Modus« bewirkt, dass die Funktion beim ersten Aufruf ausgeführt wird und beim zweiten Aufruf zurückgesetzt wird. |
| O | Angegebenen Wert verwenden | Das Flag »Angegebenen Wert verwenden« bewirkt, dass der Wert in der Spalte Wert dem entsprechenden Kanal zugeordnet wird. Dieser Wert ist kein DMX-Wert 0 bis 255, sondern ein Prozentwert 0,000 bis 100,000% |
| A | Wert Abfragen | Das Flag »Wert Abfragen« bewirkt, dass sich bei Aufruf des Befehls ein Eingabefenster öffnet, in dem der Prozentwert eingegeben werden kann. |
| I | Wert 0 ignorieren | Das Flag »Wert 0 ignorieren« bewirkt, dass ein Wert von Null ignoriert wird. Wird bei einigen Befehlen benötigt, um eine korrekte Funktion zu gewährleisten. |
