| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 21:28, 22 October 2013 (UTC) 4774 days ago. |
Hint:
20.5.2013: JKuehn: create the article page
22.10.2013: work-in-progress by UPrenner
| Figure 1: DMXControl Program icon |
To the start of DMXControl about the program icon (see figure 1) DMXControl's tax center opens (see figure 2).
This window offers the operator the access to all modules, tools and configurations of DMXControl.
Except over the menu items « File » « Window » « Configuration » and « ? » The possibility of this calling icons about this one in the icon strip is (help), for the most important modules and tools.
Furthermore the status line gives you see chapter about the path and the file of the loaded project as well as the approximate load of the internal message system on the lower window edge of the tax center. In addition, the date, the current system time and the version number are still announced by DMXControl here.
| Figure 2: The control center of DMXControl |
- to open, save and quit your show (menue « File »)
- to get all your tools from DMXControl (menue « Window »)
- to setup your system (menue « Settings »)
- to call the support funktions (menue « ? »)
Control elements
The Windows standard menu items are in the menu files.
| Icon | Menue item | Shortcut | Description |
| New project... | n.a. | Making a new project. | |
| Open project... | n.a. | Open project. | |
| Save project | CTRL+S | Overwrites the currently select project. | |
| Save project as... | n.a. | Save the project in a selected directory. | |
| Pack & Go... | n.a. | Archiving a complete project, e. g. for the move on a new or second computer. (see chapter 31) | |
| Exit | n.a. | Quits DMXControl with the usual safety and loft queries. |
The menu window includes all menu items important to DMXControl to the call of the modules, Plugins installed here in addition as well are shown.
First arrangement
| Channel overview | n.a. | Opens the channel overview window. (see chapter 8) | |
| Devices | n.a. | Opens the device window to managing your equipment. (see chapter 6) | |
| Graphical view | n.a. | Opens the graphical stage view. (see chapter 5) | |
| Group selection | n.a. | Opens the group selection window. (see chapter 5) |
Second arrangement
| BeatTool | n.a. | Opens the BeatTool window for sound-to-light-steering. (see chapter 15) | |
| Command line | n.a. | Opens the command line window. (see chapter 20) | |
| Command Box | n.a. | Opens the command box. (see chapter 16) | |
| File:DMXC2 Manual control center icon-Space.png | DMXIn remote control | n.a. | Opens the DMXIn remote control for activating the DMXIn remote control. (see chapter 28) |
| Joystick control | n.a. | Opens the window for setup the joystick control. (see chapter 26) | |
| Midi remote control | n.a. | Opens the Midi remote control for activating the Midi remote control. (see chapter 27) | |
| Keyboard control | n.a. | Opens the Keyboard control window for activating the Keyboard control. (see chapter 25) | |
| Master | n.a. | Opens the master window with the master fader. (see chapter 13) | |
| PDA remote control | n.a. | Opens the window for PDA setup. (see chapter 24) | |
| Scheduler | n.a. | Opens the scheduler window. (see chapter 21) |
Third arrangement
| Audio player | n.a. | Opens the audio player window. (see chapter 17) | |
| Chasers Tool | n.a. | Opens the chasers tool window. (see chapter 11) | |
| Cue List | n.a. | Opens the cue List window. (see chapter 10) | |
| Sound analyzer | n.a. | Opens the sound analyzer window for sound-to-light setup. (see chapter 14) | |
| Submaster | n.a. | Opens the submaster window. (see chapter 12) | |
| Textbook | n.a. | Opens the textbook window. (see chapter 19) | |
| Timecode player | n.a. | Opens the timecode player window. (see chapter 18) |
Gruppierung 4
| Icon | Menüpunkt | Shortcut | Description |
| Szenenbibliothek anzeigen | STRG+B | Öffnet das Fenster der Szenenbibliothek. (see chapter 9) | |
| Bearbeitungsansicht | STRG+E | Versteckt Konfigurationspunkte für den Live-Betrieb. | |
| Alle Fenster auf den primären Desktop holen | n.a. | Hat man mit mehreren Monitoren gearbeitet, kann es bei der Rückkehr in den Single-Monitor-Betrieb passieren, dass sich noch Fenster auf einem der dann virtuellen Monitor befinden. Mit dieser Funktion können fehlende Fenster für die Bearbeitung wieder auf den primären Monitor geholt werden. Voraussetzung ist, dass das Fenster geöffnet ist. |
Das Menü Konfiguration
| Ausgabeplugins.. | n.a. | Öffnet das Fenster zum Einstellen und Konfigurieren der Ausgabeplugins. (see chapter 7) | |
| Plugins.. | n.a. | Öffnet das Fenster zum Einstellen und Konfigurieren der zusätzlichen Plugins. (see chapter 30) | |
| Programmkonfiguration... | n.a. | Öffnet das Fenster Programmkonfiguration. (see chapter 29) | |
| Midifernbedienung... | n.a. | Öffnet das Fenster zur Konfiguration der Midifernbedienung. (see chapter 27) | |
| DMXIn-Fernbedienung... | n.a. | Öffnet das Fenster zur Konfiguration der DMXIn-Fernbedienung. (see chapter 28) | |
| Joystickkontrolle... | n.a. | Öffnet das Fenster zur Konfiguration der Joystickkontrolle. (see chapter 26) | |
| Tastaturkontrolle... | n.a. | Öffnet das Fenster zur Konfiguration der Tastaturkontrolle. (see chapter 25) | |
| Farblisten... | n.a. | Öffnet das Fenster zur Definition der Farblisten. (see chapter 6) | |
| Gobolisten... | n.a. | Öffnet das Fenster zur Definition der Gobolisten. (see chapter 6) | |
| Figureneditor... | n.a. | Öffnet das Fenster des Figureneditors für das Bewegungszenenmodul. (see chapter 23) | |
| Englisch Deutsch |
n.a. | Einstellung der Sprache für DMXControl. | |
| Experimentelle Programmteile zeigen | n.a. | Ist dieser Menüpunkt ausgewählt, dann erscheinen auch die Programmteile, die noch nicht ausgiebig getestet wurden und sich noch im Beta-Stadium befinden. In der 2.12 sind zur Zeit keine experimentellen Programmteile integriert, einzig einige Plugins benötigen diesen Punkt, damit sie angezeigt werden. (z.B. das Plugin BeatDetection) |
Das Menü Hilfe "?"
| Icon | Bezeichnung | Description |
| Blackout | Bei Betätigen des Icons werden alle Dimmerkanäle auf den DMX-Wert 0 gesetzt, ein erneutes Betätigen gibt wieder die aktuellen Werte der Module in DMXControl aus. | |
| Freeze | Bei Betätigen des Icons wird die Ausgabe eingefroren, d.h. die zuletzt ausgegebenen Werte stehen weiterhin am Ausgang an. Änderung, die während der Aktivierung von Freeze gemacht werden, wirken sich erst nach erneuter Betätigung auf das Ausgangssignal aus. Dagegen wirkt sich der Freeze Button in der grafischen Bühnenansicht nur auf die Ausgabe aus der grafischen Bühnenansicht aus. | |
| File:DMXC2 Manual control center icon-Audioszene.png | Audiowiedergabe | Eine gestartete Audioszene kann mit diesem Button vorzeitig abgebrochen werden, bzw. über das Dropdown-Menü kann eine der 16 Audioszenen manipuliert werden. |
| File:DMXC2 Manual control center Button Hinzufuegen.png | Hinzufügen | Der Button Hinzufügen ist in DMXControl in fast allen Fenstern enthalten und dient zum Hinzufügen von Szenen, Erstellen von neuen Listen, Effekten usw. |
| File:DMXC2 Manual control center Button Delete.png | Löschen | An allen Stellen, an denen man den Button Hinzufügen findet, gibt es auch den Button Löschen. |
| File:DMXC2 Manual control center Button Copy.png | Kopieren | Der Button Kopieren taucht an einigen Stellen auf, um Szenen oder Effekte zu kopieren. |
| File:DMXC2 Manual control center Button Umbenennen.png | Umbenennen | Mit diesem Button können Namen von Listen oder auch Effekten umbenannt werden. |
| File:DMXC2 Manual control center Button Arrow-UP.png | Verschieben hoch | Dieser Button dient zum nach oben Verschieben von Einträgen in Listen. |
| File:DMXC2 Manual control center Button Arrow-DOWN.png | Verschieben runter | Dieser Button dient zum nach unten Verschieben von Einträgen in Listen. |
| File:DMXC2 Manual control center Button Edit.png | Bearbeiten | Mit diesem Button kann der ausgewählte Eintrag oder die ausgewählte Szene geändert werden. |
| File:DMXC2 Manual control center Button Reset.png | Rücksetzen | Mit dem Rücksetzen Button wird die Ausgabe im aktuellen Fenster auf default zurückgesetzt. |
| File:DMXC2 Manual control center Button Play.png | Starten | Der Starten Button taucht an allen Stellen auf, wo eine Sequenz von Szenen zum Ablauf gestartet werden kann. |
Die modulbezogenen Befehle beziehen sich im wesentlichen auf die Buttons Blackout und Freeze.
- Modul: DMX-Ausgabe
- Meaning von Gerät/Funktion und Kanal
| Gerät/Funktion | Description | Kanal | Description |
| Blackout | Der Blackout-Befehl bezieht sich auf das Blackout-Icon im Steuerzentrum und in der grafischen Bühnenansicht. | Umschalten | Der Befehl Umschalten invertiert den momentanen Zustand der Blackout-Funktion. |
| Ein | Der Befehl Ein aktiviert die Blackout-Funktion. | ||
| Aus | Der Befehl Aus deaktiviert die Blackout-Funktion. | ||
| Freeze | Der Freeze-Befehl bezieht sich auf das Freeze-Icon im Steuerzentrum und in der grafischen Bühneansicht. | Umschalten | Der Befehl Umschalten invertiert den momentanen Zustand der Freeze-Funktion. |
| Ein | Der Befehl Ein aktiviert die Freeze-Funktion. | ||
| Aus | Der Befehl Aus deaktiviert die Freeze-Funktion. |
Meaning der Flags:
