| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 22:04, 23 October 2013 (UTC) 4668 days ago. |
Hint:
20.5.2013: JKuehn: create the article page
23.10.2013: work-in-progress by UPrenner
The graphical view offers the possibility of adding to the project and addressing equipment exactly like the module device list. One can to end you about that the project already in the front-end, in dependence on the later real construction abgebilden (approximate positioning). The wallpaper is freely eligible for office and can have the formats . gif, . bmp or . jpg. In addition, it offers the possibility of checking all real equipment for heart and kidneys shortly after the construction. This is particularly very helpful at DDFs made newly.
| Figure 1: The graphical view |
Description
The graphical view lets himself over the menu « Window » Menu item « Graphical view » as well as calling about the accompanying symbol in the control center.
| Figure 2: The module symbol |
The individual equipment icons are established tightly on her position and can be worked and moved only about the context menu. A link click on a device opens the DDF-window (see figure 3), which shows all DMX channels assigned to the device with graphic manipulators. The example shows the DDF of the Generic dimmer which has a dimmer channel. A double click on the icon of the DDFs puts the value of the dimmer of the device on 0 or 100%. This has to be changed as the only channel also directly under the icon with the mouse without opening the DDF.
The DDF is the device description file, including the channel assignment of the equipment, similary like it is, in DMXControl are at hardware consoles the Fixtures You find detailed information about the DDF construction in chapter 32 DDF basics as well as in the chapter 33 The DDFCreator.) |
For a very big set one can, however, lose the summary fast on one single view. DMXControl therefore offers the possibility of dividing the equipment up on several tab or page tabs views. Over the adding, editing, and deleting badge, on right above, be able to be several tabs made or managed. Any tab view produced newly can take a wallpaper of its own and therefore permits to subdivide the stage into different sections. If a device shall be visible on several tabs, then a new DDF must be inserted for everybody. The start addresses of the DDFs must be the same.
| Figure 3: Graphical view with several tabs |
New background image simply find in the directory "...\DMXControl\Resources\Stage Images" to be stored and used. A choice is in this list already after the installation:
pyramid_top
flying_top
The stage view has the highest priority regarding the control. Channel changes are therefore suppressed by a change in other modules, such as in the sound Analyzer, in the graphic stage view. Only a pressure on the « Reset » This one lifts over-spelling the S2L button or the adjust renewed of the other module (here: deactivate and activate again) again. |
Controls
The window of the graphic stage view provides operating devices still following apart from the standard icons:
Except of the icons, there are also two context menu that appear by clicking with the right mouse button in the graphical view. A context menu will appear with the right click on the background image, the other context menu when right clicking on a device icon.
- Context menu by right clicking on background image.
| Menu item | Description |
| Change background picture | When selecting this menu item opens a file dialog where the image of the background image can be selected. Open is confirmed with the button loads the image in the selected tab view. Images can be loaded in . gif, . bmp or . jpg format. |
| Add Device | Opens the 'Add device' dialog window. (see Add Device section) |
| Device positioning mode | Turn on the equipment positioning mode. Devices can be moved now directly with the left mouse button and positioned. (This mode should be quit after use) |
| Align to grid | All devices will be align by the internal grid of the graphical view. |
- Context menu by right clicking on a Device.
| Prefer graphical view | When selecting this menu item for the selected device, the graphical view of the stage generally has higher priority, as the other modules. This means that the output for the device will not be changed E. g. by ongoing effects. |
| Move | After selecting this menu item, the selected device with the left mouse button on the current tab view can be positioned. |
| Tab | The Create tab views are displayed in the submenu. When selecting the device on the selected tab view is moved. |
| Delete | Deletes the selected device from the graphical view. |
| Configure | Opens the settings window from the selected device. (see Device configuration) |
Add device
| Figure 4: Gerät hinzufügen |
Nach dem Auswählen des Menüeintrags « Gerät hinzufügen » im Kontexmenü der grafischen Bühneansicht öffnet sich das Fenster « Gerät hinzufügen ». Hier kann man aus einer Liste von Herstellern (Ordner) den Hersteller seines Gerätes durch Öffnen des Ordner auswählen. Im Ordner befinden sich die, in DMXControl schon vorhandenen, Geräte. Sollte das gesuchte Gerät sich nicht in der Liste befinden, so besteht noch die Möglichkeit, in der Gerätebibliothek [1] auf der DMXControl-Hauptseite oder im DMXControl-Forum[2] nachzusehen bzw. nachzuhören. Eine weitere Möglichkeit an ein Geräte-DDF zu kommen ist, sich die Anleitung zur DDF-Erstellung im Kapitel 32 DDF Grundlagen und Kapitel 33 Der DDF-Creator durchzulesen, und sich ein Geräte-DDF selbst zu erstellen.
- Name: Name des Geräte-DDFs.
Nach einem Klick auf den « O.K. » bzw. « Abbrechen » fügt DMX-Control die Geräte in die grafische Bühnenansicht ein bzw. verwirft die Auswahl. Wurde das Fenster mit « O.K. » beendet, erscheinen die Geräte auch im Geräte-Fenster (siehe nächstes Kapitel).
Werden neue DDF-Dateien in den Ordner Devices eingefügt, so wird die DDF-Auswahlliste erst bei einem Programmneustart aktuallisiert. Wird ein DDF z.B. mit dem DDFCreator aktualisiert, so hängt es davon ab, wie gravierend die Änderung ist. Bei Änderungen an der DDF-Oberfläche, dem Verhalten eines DDF-Steuerelementes oder der Proceduren genügt es, das DDF-Fenster zu schließen und wieder zu öffnen. Wird die Anzahl der Kanäle verändert, so muss DMXControl neu gestartet werden. |
Gerät konfigurieren
| Figure 5: Gerät konfigurieren |
Nach dem Auswählen des Menüeintrags « Gerät konfigurieren » im Kontextmenü der grafischen Bühnenansicht, öffnet sich das Fenster « Gerät konfigurieren ». In diesem Fenster lassen sich diverse Einstellungen ändern.
| Einstellung | Beschreibung |
| Symbol: Bild ändern | Beim Klick auf den Button öffnet sich eine Liste, aus der man ein anderes Icon-Bild aus dem DMXControl-Icon-Verzeichnis für das Gerät hinterlegen kann. Die Icons befinden sich im DMXControl Programmverzeichnis \DMXControl\Devices\Images\. |
| Symbol: Bild zurücksetzen | Beim Klick auf den Button wird das Icon-Bild wieder auf das Standardbild, das im Gerätedefinitionsfile festgelegt wurde, zurückgesetzt. |
| Name | Hier kann der Name des Gerätes geändert werden. |
| Adresse | Hier lässt sich die DMX-Adresse nachträglich ändern. |
| Farbliste | An dieser Stelle kann eine der vordefinierten Farblisten ausgewählt werden. |
| Farbfilter | Hier kann für PAR-Scheinwerfer ein Farbfilter ausgewählt werden. Wird benötigt, wenn man in der Programmkonfiguration im Reiter grafische Bühnenansicht die Option Darstellung der Farbe statt Grafik ausgewählt hat. |
| Goboliste | An dieser Stelle kann eine der vordefinierten Gobolisten ausgewählt werden. |
| Dimmer | Bei Auswahl dieser Option wird der Dimmer nicht dem Grand Master, sondern dem sekundären Grand Master zugeordnet. |
| Pan/Tilt: Invertieren | Wenn das Gerät ein Scanner oder Movinghead ist, können hier, wenn nötig, die Pan- bzw. Tiltachsen invertiert werden. |
| Pan/Tilt: Verschieben | Hier lassen sich die Pan- und Tiltachsen verschieben, um z.B. ein bestehendes Projekt auf eine ähnliche Location anzupassen. |
| Pan/Tilt: Skalieren | Hier lassen sich die Pan- und Tiltachsen skalieren, um z.B. ein bestehendes Projekt auf eine ähnliche aber kleinere Location anzupassen. |
Durch einen Klick auf « O.K. » bzw. « Abbrechen » wird die Konfiguration gespeichert bzw. verworfen.
Geräte gruppieren
| Figure 6: Gerät konfigurieren |
Wie im Abschnitt Bedienelemente beschrieben, besteht die Möglichkeit der Mehrfachselektierung von gleichen Geräten mittels der STRG-Taste oder dem Button « Auswahlmodus ».
Im Fenster Gruppenauswahl kann der Guppe ein Name zugewiesen werden und die Auswahl dann mit dem « Hinzufügen » Button gespeichert werden. Bei Auswahl mit der Maus werden nun die Geräte in der grafischen Bühnenansicht selektiert.
- Modul: Gerät
| Sonstige Einträge | Unterhalb von Ausgewähltes Gerät befinden sich alle Geräte, die dem aktuellen Projekt hinzugefügt wurden. Hier kann man dierekt ein Gerät auswählen, auf das die weiteren Parameter angewendet werden. | Selektieren | Das entsprechende Gerät wird in der grafischen Bühnenansicht ausgewählt. |
| Sonstige Kanalbezeichungen | Für das ausgewählte Gerät kann der entsprechende Kanal ausgewählt werden. Hierbei werden die, im DDF angegebenen, Namen der Kanäle angezeigt. | ||
- Modul: Gruppenauswahl
| O | Angegebenen Wert verwenden | Das Flag « Angegebenen Wert verwenden « bewirkt, dass der Wert in der Spalte Wert dem entsprechenden Kanal zugeordnet wird. Dieser Wert ist kein DMX-Wert 0 bis 255, sondern ein Prozentwert 0,000 bis 100,000% |
| A | Wert Abfragen | Das Flag « Wert Abfragen « bewirkt, dass sich bei Aufruf des Befehls ein Eingabefenster öffnet, in dem der Prozentwert eingegeben werden kann. |
| I | Wert 0 ignorieren | Das Flag « Wert 0 ignorieren « bewirkt, dass ein Wert von Null ignoriert wird. Wird bei einigen Befehlen benötigt, um eine korrekte Funktion zu gewährleisten. |
- ↑ Gerätebibliothek von DMXControl: http://www.dmxcontrol.de/Geraetedefinitionen/Geraetebibliothek.html Zur Zeit nicht Online
