| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 23:03, 24 October 2013 (UTC) 4715 days ago. |
Hint:
20.5.2013: JKuehn: create the article page
24.10.2013: work-in-progress by UPrenner
The device list contains all devices (DDF's) selected for the project like the graphical view and lists these openly with several parameters.
| Figure 1: Die Geräteliste |
Description
The most important data of everyone already become available equipment as well as their graphic position on the graphical view shown in the device list (figure 1) in the project. The data are column-wise arbitrarily sortable. The device list lets himself exclusively over the menu « Window » Menu item « Device » calls and can over the button « Copy to clipboard » be copied as tab-separate text into the intermediate file to be used further so in other programs.
The device names can be renamed to the better re-reconnaissance and the DMX address can comfortably in the decimal and be binary system entered (DIP switch). In addition, have the x and y positions of the icons read in the graphic stage view to themselves. Should these are untraceable on the graphic stage view.
Further attitudes of the device selected can over the button « Configure » at highlighted equipment over the window « Configure device » being carried out. A detailed description is in the chapter 4 graphic one stage view.
Adding equipment is carried out via the button « Add », in which himself as in the case of the graphical view the window « Add device » opens.
Color and Gobo lists
Die Erstellung einer neuen Farb- bzw. Goboliste erfolgt im Menü « Konfiguration » mit den beiden Menüeinträgen « Farblisten » und « Gobolisten ». Die Zuordnung der erstellten Listen erfolgt in der Gerätekonfiguration, in der man, an den entsprechenden Punkten, die Farb- bzw. Goboliste per Dropdown auswählt.
