| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 12:10, 25 October 2013 (UTC) 4772 days ago. |
Hint:
20.5.2013: JKuehn: create the article page
25.10.2013: work-in-progress by UPrenner
In the lighting engineering scenes are basic elements. A scene represents a light atmosphere, that is both the brightness values of headlights, like also the positioning, colors or motives (so-called Gobos) etc. , of Moving Heads or scanners. Scenes save information about DMX values, audio files or scanner or Moving Head movements, in DMXControl. Every project is built up from a combination from different self-definable scenes and scene combinations.
Working with cues
(Except for the instructions) DMXControl 2 has a name of his own every scene in DMXContol 2 which can be chosen individually. Empty and special signs are also permitted in the scene name. However, it should be taken care of on this that this name is self-explanatory such as song X, solo song share or LED PAR1 red. On the one hand, this ensures that the function of a scene still can be recognized after quite a long time, too. On the other hand, a scene so also can be found quite simple (see below) in the cue library if one liked to reuse her in another place.
In the textbook, scenes behave a little differently than in DMXControl's rest. Although scenes also have a one dazzling time but no length in the script. Scenes cannot be further switched or ended after a certain time either through this.
Scenes become in every module about the button « Add » added to a project. By a click on the button « Add » a menu (see figure 1) about the one in the individual scene ways, orders, the cue library or on which opens « Submenu produced automatically » can grasped it be.
| Figure 1: Menue add for cues |
For the faster scene construction do the button « Add & raquo; by simultaneous hold of the button « Shift » being accessed the menu item you selected in the last time. |
Cue types
Quick overview
| Type | Description |
| Einfache Szene | Speichert die DMX-Werte mehrerer auswählbarer Gerätekanäle. So können Lichtstimmungen recht einfach gespeichert werden, z.B. die Farb- und Dimmerwerte von LED-Scheinwerfern. |
| Befehl | Dienen zur Steuerung gewisser Parameter im Projekt, wie z.B. das Starten bzw. Stoppen eines Effektes durch einen anderen, die Übergabe eines Wertes an ein Gerät oder die Steuerung des Grandmasters. |
| Audioszene | Mit ihr können auf einfache Weise Audiodateien in das Projekt eingebunden und abgespielt werden. |
| Bewegungsszene | Speichert Bewegungsabläufe für Scanner und Moving Heads, wie z.B. die Kreisfigur eines Moving Heads. |
| Kompositionsszene | Kombiniert mehrere Szenen zu einer Gesamtszene. Mit ihr können z.B. mehrere Befehle gleichzeitig gestartet werden. |
Simple cue
Eine Einfachen Szene repräsentiert in DMXControl eine in der Lichttechnik auch als CUE bezeichnete Lichtstimmung. In ihr wird eine benutzerdefinierte Auswahl von Kanalwerten der im Projekt vorhandenen Geräte gespeichert. Dabei besitzt jede Szene je eine Einblend- und eine Haltezeit (Dauer). Die Einblendzeit kommt beim Starten einer Szene zum tragen. DMXControl blendet in der angegebenen Einblendzeit von der aktuellen Lichtstimmung in die gestartete Szene über. Mit der Haltezeit kann die Dauer eingestellt werden, die DMXControl wartet, bevor z.B. im Effektsequencer die nachfolgende Szene eingeblendet wird.
Um eine neue Einfache Szene in einem Modul zu erstellen, stellt man zuerst die gewünschte Lichtstimmung z.B. über die Kanalübersicht oder den Submaster ein. Anschließend klickt man in dem entsprechenden Modul auf den Button « Hinzufügen « und wählt im folgenden Popup-Menü « Einfache Szene » aus. Es erscheint der Dialog « Szene speichern » (Abb. 1)
| Figure 2: Dialog zum Speichern einer Szene |
Die Auswahl sollte wohlüberlegt sein. Wenn mehrere Szenen gleichzeitig ablaufen sollen, dürfen Kanäle nur in maximal einer der entsprechenden Szenen ausgewählt sein. Auf der anderen Seite sollte für Theateranwendungen möglichst alle Dimmerkanäle gespeichert werden, damit jede Szene unabhängig von anderen Szenen gestartet werden kann. Hierfür ist die Funktion « Alle Speichern (nicht empfohlen) ». |
- « - » alle Kanäle zuklappen
- « + » alle Kanäle aufklappen
- « / » nur Kanäle anzeigen, die einen von 0 verschiedenen Wert haben
Die Buttons unter dem Suchfenster erlauben eine einfachere Markierung der Kanäle. Mit « Clear » wird die Kanalauswahl gelöscht, « All » markiert alle Kanäle, « Store » speichert die aktuelle Auswahl zwischen und « Recall » läd die mit dem Button « Store » gespeicherte Auswahl. Gerade die letzten beiden Button vereinfachen die Auswahl bei immer wiederkehrenden Kanalzuordnungen.
Um ein schnelleres Arbeiten beim Erstellen von Szenen zu gewährleisten, kann man sich durch Halten der Taste SHIFT und einem gleichzeitigen Klick auf den Button « OK », der vorherigen Klick auf den Button « Recall » sparen. |
| Figure 3: Die Suche im Dialog « Szene speichern « |
Wählt man einen Kanal im linken Fenster an (einschliesslich Häkchen setzen), kann man den zu speichernden DMX-Wert auch mit den beiden Eingabefeldern Wert[Byte] (als Zahlenwert zwischen 0 und 255) oder gleichberechtigt mit Wert[Prozent] (in ganzzahliger Prozentangabe) im unteren Teil des Fensters verändern.
| Figure 4: Manuelle Eingabe eines Kanalwertes |
Auf der rechten Seite des Fenster können sie der zuvor eingestellten Lichtstimmung einen Namen geben und die Einblendzeit sowie ihre Dauer definieren. Durch Einstellen der Zeit auf Null und Reduzierung um einen weiteren Schritt können Sie die Dauer auch auf « manuell » stellen. Dadurch führt DMXControl z.B. in der Szenenliste die nächste Szene erst aus, wenn der Button « GO « gedrückt wird. Darüber hinaus können Sie den Überblendpunkt einstellen, also der Zeitpunkt beim Einblenden, zu dem Switch-Kanäle umgeschaltet werden, einen Kommentar zu der Szene speichern und die Szene in eine selbstdefinierbare Kategorie einteilen. Dazu trägt man einfach den Namen der Kategorie in das entsprechende Feld ein. Existiert diese noch nicht, so wird automatisch eine neue Kategorie angelegt.
Die Legende-Box rechts unten im Dialogfenster ist nur eine Legende zur Erklärung. In ihr kann man nichts verändern, auch wenn es den Anschein hat. |
Instruction
| Figure 5: Dialog zum Speichern eines Befehls |
Im Dialog « Befehl bearbeiten » können sie den entsprechenden Befehl zusammenstellen. Ein Befehl hat die Grundstuktur:
| Type | Beschreibung | Schaltfläche |
| <Modul> | Ziel-Modul, in dem der Befehl eine Einstellung vornehmen soll | linkes Dropdown |
| <Funktion> | Von dem ausgewählten Modul bereitgestellte Metoden, Aktionen oder Objekte. Auswahl ist abhängig vom gewähltem Modul. | mittleres Dropdown |
| <Attribut> | Entweder ein Atribut oder bei Unterobjekten die Operation. Auswahl ist abhängig von der gewählten Funktion. | rechtes Dropdown |
Audio cue
| Figure 6: Dialog zur Konfiguration einer Audioszene |
Im Dialog « Audioszene » können sie eine neue Audioszene erstellen. Im Feld Audiodatei wird der Pfad der Audiodatei eingetragen. Über den Button « Datei öffnen » rechts neben dem Feld wird die Audiodatei geladen und kann mit dem Button « Play » vorgehört werden. Über die Dauer stellen Sie die Zeit ein, bis die nachfolgende Szene in einem Szenenablauf ausgeführ wird. Zudem können Sie wählen, ob die Wiedergabe nach Ablauf der Zeitdauer beendet wird.
Da eine Szene im Textbuch per Definition keine Dauer hat, kann hier eine Audiodatei auch nicht nach einer gewissen Zeitdauer abgebrochen werden, sondern wird sofort beendet. Um trotzdem einen zeitgesteuerten Abbruch der Audiowiedergabe realisieren zu können, müssen sie die Audioszene mit vorgegebener Zeitdauer und aktiver Abbruchoption in einen Effekt einfügen. Anschließend starten Sie diesen vom Textbuch aus per Befehl. |
Darüber hinaus können Audioszenen einem von insgesamt 16 Soundkanälen zugeteilt werden. Diese Kanäle können jeweils per Befehl aus anderen Modulen heraus beendet werden. Dabei können auch mehrere Audioszenen auf einem Kanal liegen. Mit der Option Wiedergabe wiederholen wird die Audioszene in einer Endlosschleife wiedergegeben.
Um eine Auflistung aller aktiven Audioszenen sehen zu können, müssen Sie im Steuerzentrum auf den Pfeil neben dem Icon « Audiowiedergabe » klicken. |
Moving cue
| Figure 7: Dialog zur Erstellung einer Bewegungsszene |
Composition cue
Kompositionsszenen bieten die Möglichkeit, mehrere Szenen zu einer zusammenzufassen. Dies ist vorallem für Befehle und mehrere Szenen mit gleicher Einblendzeit und Länge gedacht. Szenen mit unterschiedlicher Einblenddauer und Haltezeit (Dauer) können auf diese Weise nicht zusammengefasst werden.
| Figure 8: Dialog zur Konfiguration einer Kompositionsszene |
Auf der linken Seite des Fensters befindet sich eine Liste mit allen in der Szenenliste enthaltenen Szenen. Über die Buttons « Hinzufügen », « Bearbeiten » und « Löschen » können Sie diese Liste bearbeiten. Auf der rechten Seite können Sie den Namen der Kompositionsszene anpassen, die Einblend- und Haltezeit (Dauer) für alle in der Komositionsszene vorhandenen Szenen einstelleun und den Übergangspunkt wählen, ab wann Szenen ohne Einblendzeit wie z.B. Befehle aktiviert werden. Darunter können Sie eine kurze Beschreibung zur Kompositionsszene schreiben, um auch nach längerer Zeit noch zu wissen, wofür die Szene dient.
Cue libary
In der Szenenbibliothek sind alle im Projekt verwendeten Szenen aufgeführt und global in vielen Modulen verfügbar. Wird eine Szene neu erstellt, so wird auch automatisch ein neuer Eintrag in der Szenenbibliothek erstellt. Bereits existierende Szenen können ganz einfach über den Button « Hinzufügen » der entsprechenden Module über den Menüeintrag « Aus Szenenbibliothek » eingefügt werden. Die sich nun öffnende Szenenbibliothek stellt die Szenen nach ihrem Typ und nach der weiter oben erwähnten Kategorisierung strukturiert dar.
| Figure 9: Die Szenenbibliothek |
Im oberen Teil des Fensters befindet sich die Suche und zwei Optionsfelder um die Anzeige in der Szenenbibliothek zu beeinflussen. Auf der rechten Seite befinden sich vier Buttons, um einzelne Szenen zu verwalten. Sie können Szenen neu hinzufügen, genau so wie bereits existierende Szenen bearbeiten oder löschen. Darüber hinaus bietet Ihnen die Szenenbibliothek auch die Möglichkeit, einzelne Szenen zu kopieren. Dies ist besonders wichtig vor dem Hintergrund, das Szenen beim Einfügen aus der Szenenliste nicht kopiert werden, sondern sich, wie Eingangs beschrieben, immer auf die entsprechende Szeneninstanz in der Szenenbibliothek beziehen.
Werden Szenen aus der Szenenbibliothek in einem Modul hinzugefügt, so werden diese nicht kopiert, sondern es wird eine Verknüpfung zur entsprechenden Szene in der Szenenbibliothek erstellt. Damit wird erreicht, dass eine Änderung dieser Szene (z.B. für Korrektur oder Verbesserung) auch global an allen verwendeten Stellen in Kraft tritt. Daher sollte man eine Szene nur dann mehrfach verwenden, wenn die Szene an allen Stellen gleich sein muss. Andernfalls ist es angebracht, eine neue Szene zu erstellen.
Cue and chaser generator
In Version 2.12 enthält DMXControl insgesamt vier Szenen- und Lauflichtgeneratoren. Diese Assistenten ermöglichen es Ihnen, in jeweils drei Schritten automatisch Szenen und Lauflichter zu erstellen. Überall, wo eine Szene über den Button « Hinzufügen » erzeugt werden kann, können Sie die Assistenten über das Untermenü « Automatisch erzeugt » erstellen lassen. Es werden unabhängige Szenen erstellt, wobei alle generierten Szenen auch in der Szenenbibliothek erscheinen.
| Figure 10: Automatische Szenenerstellung |
Cue import from CSV
Eine weitere Möglichkeit der Szenenerstellung bietet der Untermenüpunkt « Import aus CSV «. Hierbei kann man in Excel oder ähnlichen Programmen, die einen CSV-Export anbieten, durch Eingabe der Kanäle und der Kanalwerte mehrere Szenen auf einmal erstellen.
Hierzu schreibt man in einen Excel Tabelle in die oberste Zeile die benötigten Kanaladresse und in die Zeilen unterhalb die zu den Kanälen zugeodneteten Kanalwerte. In nachfolgender Tabelle wird ein 4 Kanal Lauflicht über 4 Generic Dimmer dargestellt. Die erste Spalte dient nur der Information und wird nicht mit eingegeben.
| Channel adress | 1 | 2 | 3 | 4 |
| Cue 1 | 255 | 0 | 0 | 0 |
| Cue 2 | 0 | 255 | 0 | 0 |
| Cue 3 | 0 | 0 | 255 | 0 |
| Cue 4 | 0 | 0 | 0 | 255 |
Bei Aufruf des Menüeintrag « Imoprt aus CSV » öffnet sich der Dialog « Assistent für den Import von Szenen aus CSV » hier lässt sich über den Button « Datei öffnen » die CSV-Datei in DMXControl importieren (siehe Bild 11).
| Figure 11: Import aus CSV: Schritt 1 |
Je nach dem welches CSV-Trennzeichen genutzt wurde, kann es sein das wie in Bild 12 eine Fehlermeldung erscheint. Um trotzdem eine korrekte Anzeige zu erhalten, kann man im oberen Teil zwischen vier CSV-Trennzeichen auswählen (Komma, Semikolon, Leerzeichen, Tabstopp).
| Figure 12: Import aus CSV: Schritt 2 mit Fehler |
In unserem Fall wird nach Auswahl des CSV-Trennzeichen (Tabstopp) die importierte Tabelle korrekt dargestellt (siehe Bild 13).
| Figure 13: Import aus CSV: Schritt 2 ohne Fehler |
Durch einen Klick auf die Checkbox erste Zeile ist Kanalnummer werden die Kanalnummern aus der ersten Zeile übernommen (siehe Bild 14).
| Figure 14: Import aus CSV: Schritt 2 (Kanalnummern eingelesen) |
Im Schritt 3 Kann nun die Einblend- und Haltezeit (Dauer) für alle Szenen festgelegt werden, auserdem kann den Szenen ein Namen gegeben werden der fortlaufend nummeriert ist.
| Figure 15: Import aus CSV: Schritt 3 |
Durch einen Klick auf den Button « Fertigstellen » werden die Szenen erstellt und in das entsprechende Modul übernommen aus dem der « Import aus CSV « aufgerufen wurde.
- Modul: Audioszene
| Kanal 1-16 | Auswahl eines der 16 Audiokanäle auf die der weitere Befehl angewendet wird. | Pause | Hält den unter Gerät/Funktion ausgewählten Kanal an, nach erneuten Aufruf wird die Kanalausgabe forgesetzt. |
| Zurückspulen | Spult das Soundfile zum Anfang zurück. | ||
| Stop | Stoppt das Soundfile. | ||
| Lautstärke setzen | setzt die Lautstärke duch Übernahme des angegebenen Werts. |
- Modul: Szenenbibliothek
| Alle Einträge | Die Einträge im Dropdown Gerät/Funktion, sind alle Szenen innerhalb der Szenenbibliothek. Bei Auswahl eines Eintrags kann der Befehl im Dropdown Kanal auf die Szene angewendet werden. | Ausführen | Führt die gewählte Szene direkt aus. |
| Einblenden | Führt die gewählte Szene, mit der in der Szene abgespeicherten Einblendzeit, aus. |
Meaning of the Flags:
- Manuelle Erstellung eines Lauflichtes (DMXControl 2)
- Automatische Erstellung eines Lauflichtes (DMXControl 2)
