| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 19:45, 25 October 2013 (UTC) 4773 days ago. |
Hint:
25.5.2013: UPrenner: create the article page
25.10.2013 UPrenner: work-in-progress
With the cue list several scenes can be summarized by light atmospheres to a sequence. This offers you the possibility of organizing the individual cues at an event with a firmly predefined expiry of the light atmospheres. This module is similarly suitable for theater events and comparable event forms with that like the script also.
| Figure 1: Create a new cue |
Per cue which takes effect however only within the cue list or an effect a one dazzling time as well as a duration you (describe in the Effektsequencer) as hold time can be indicated. Values of a cue remain active on the version until they are overwritten explicitly, for example by another cue.
All cues are managed in the cue library and can be chosen and reused from there.
Description
One or several cues form a cue list. The maximum number of cues per cue list is only limited by the resources of your computer. Playing a cue list means the sequential execution of all individual cues under consideration of the the one dazzling time and duration (hold time). The cues can also manually be further switched. Several cue lists can expire at the same time (parallel operation).
E. g. you use the cue tool at theater applications and everywhere there where it suffices, simple cues after a particular duration (hold time) further add-on. The scene tool works resource loading substantially less than the chaser tool. The cue list is always worked off sequentially and to be more precise as of the cue which is just highlighted. For the beginning of the play, so the first entry must be highlighted.
Controls
| Figure 2: The cue list |
So that the button « GO & raquo; the manual further wiring can work, the following conditions must be filled for:
- The scene list must be represented (Button » play « is clicked).
- The respective cue must have manually as a duration (hold time) (adjust time to zero and one then still reduce tenths). If a duration (hold time) is adjusted, this is taken into account which yes also can be quite practical (to let e.g. a sequence of light atmospheres go with firm times and switch to the next scene manually only later again).
- The cues must be marked with the checking box (hook), they otherwise are deactivated.
At a right click on the cue name opens himself a context menu with the menu item « Set color . . . « a color palette window opens where a color can be selected for the scene name.
If HTP is not necessary, so HTP turn it off in the program settings (depends on the cue definition). |
Module commands
- Modul: Cue list
| Select | The further order is applied to the currently select cue list. (The Command selects at this function the makes no sense) |
Start/Stop | The command Start/Stop starts/stops the select scene list at automatic expiry. (The command should be used in connection with the T flag.) |
| Start | The command Start starts the select scene list at automatic expiry. | ||
| Stop | The command Stop stops the select scene list at automatic expiry. | ||
| G O ! | The command G O! executes the next scene from the Szeneliste. | ||
| Scroll to current cue | The command scroll to current cue, forces the current scene to scroll to the visible window area. | ||
| Next Previous Other entries |
Der weitere Befehl wird auf die aktuell nächste, vorherige oder im Dropdown benannte Szeneliste angewendet. | Select | Selects the next (previous) cue list or the one selected in the dropdown device/function. |
| Start/Stop Start Stop G O ! Scroll to current cue |
see above |
Tip(s)
- Folgendermaßen kann man Szenenlisten so konfigurieren, dass beim Erreichen des Endes einer Liste die nachfolgende aktiviert und gestartet wird:
Am Ende jeder Szenenliste ist eine Befehlsszene mit dem Befehl Szenenliste -> Nächste -> Start einzufügen. - Für längere Szenenlisten gibt es seit der Version 2.12 eine Akkumulation der Fade- und Dauerzeiten, um die Liste mit einem Timecode zu synchronisieren.
