| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 22:42, 30 October 2013 (UTC) 4768 days ago. |
Hint:
25.5.2013: UPrenner: create the article page
30.10.2013 UPrenner: work-in-progress
With the audio player audio tracks can be accompanied by scenes, chasers and commands. The audio player in principle only offers another surface that for a cue list, like the script and the time code player the possibility is here establishing the scenes for the course of the song point exactly. Through this individual Lightshows can be made for some songs.
Description
The two audio traces are, the stereo traces of a music track present which a striking feature of the audio player (left channel: green, right channel: red). In this the temporal course with the corresponding amplitudes of the song and the sedate cues are shown to window area. At inefficient computers it recommends himself not to load the waveform graphic with the checking box to suppress the indication of the amplitude course, through what CPU performance is saved.
| Figure 1: The Audio player |
<br\>
The audio player serves the crown transparency of wave files. If it is merely about playing wave files, the audio scene has to be preferred. Several also can play audio channels (up to 16 pieces) parallel there. |
Controls
| Icon | Bezeichnung | Beschreibung |
| DMXControl | With the button DMXControl in the audio player you adjust, that the sound file and the audio cue list are started and played about DMXControl. | |
| WinAmp | With the button WinAmp in the audio player you adjust, that the sound file and the audio cue list are started and played about the external program WinAmp. (Synchronization with WinAmp) | |
| Play | The play button starts the sound file and the audio cue list if the DMXControl button is operated. | |
| Rewind | With this button the audio cursor is placed again on the beginning of the song. (This works also when playing the sound file) | |
| Repeat | If this button is operated, then the sound file is played from the front after ending again. | |
| Prefade listening | With the pre-hearing button the sound file becomes audio cursor position wornly as of the current one. At a renewed click on the button the player stops and the audio cursor returns into his starting point. | |
| Zoom | With the zoom lens drop down the audio trace can be extended. | |
| File:DMXC2 Manual audio player button do not load waveform.png | Do not load waveform | If the checking box is highlighted, the audio trace graphic isn't loaded. Through this the performance can be increased at slow computers. |
| Clock | With the clock badge the straight highlighted cue is moved on the current audio cursor position in the audio cue list. |
Die restlichen Buttons sind Standard-Buttons bzw. selbsterklärend.
Audio track
- Ein gelber senkrechter Strich in der Audiospur stellt die aktuelle Positionsmarkierung des Audio-Cursors dar.
- Ein weißer senkrechter Strich in der Audiospur zeigt die Szenen-Markierung mit bereits zugeordneten Positionen an.
- Die blauer senkrechter Strich in der Audiospur wird angezeigt, wenn der Audio-Cursor auf einer zugeordneten Szene-Markierung steht.
Wenn man mit dem Maus-Cursor auf einer Szenen-Markierung ist, verwandelt sich der Mauszeiger in einen Doppel-Pfeil. Außerdem wird ein Tooltip mit dem Namen der Szene angezeigt. Durch Klicken und festhalten der linken Maustaste, kann die Szenen-Markierung positioniert werden.
Befindet sich der Mauszeiger auf der Audiospur und nicht auf einer Szenen-Markierung, dann wird ein ToolTip angezeigt, der lediglich einen Bindestrich enthält. Dieser ToolTip ist ohne weitere Bedeutung. |
Manage audio project
- Button « Hinzufügen »: Durch diesen Button lässt sich ein neues Audiotrack-Projekt erstellen.
- Button « Öffnen »: Mit diesem Button weist man dem Audiotrack-Projekt ein Audiofile zu. Mögliche Audiofiles müssen vom Typ mp3, mp2, mp1, wav oder ogg sein.
- Button « Verwalten »: Hinter diesem Button verbergen sich die Menüpunkte « Hinzufügen », « Kopieren », « Umbenennen », « Löschen » und « Verwalten ». Mit ihnen können die Audiolisten verwaltet werden.
Bei Audiodateien mit variabler Bitrate (VBR) gibt es Probleme mit einem gewissen Zeitversatz. Daher ist es am besten, Audiodateien mit konstanter Bitrate (z.b. 128kBit oder 320kBit) zu verwenden. |
Serve
Beim Klick mit der Maustaste in das Audiofenster erscheint an dieser Stelle der Audio-Cursor (gelber Strich). Damit lässt sich z.B. im « Play »-Mode (Drücken des Play-Buttons) an eine beliebige Stelle springen, um diese zu hören. Ein Doppel-Klick ins Audiofenster startet den « Play »-Mode an der entsprechenden Stelle. Ein erneuter Doppel-Klick stoppt den « Play »-Mode.
Neue Szenen können folgendermaßen zugewiesen werden:
- Hören Sie den Titel und achten Sie in der Grafik auf markante Stellen im Song, wo Sie Szenen, Effekte oder Befehle positionieren wollen. Diese Aktion erfolgt genau wie in anderen DMXControl-Tools durch Drücken des Buttons « Hinzufügen ».
- Besonders fixe Nutzer schaffen das sogar im « Play »-Mode. Normalerweise stoppt man aber den Titel und positioniert den Cursor exakt an der gewünschten Stelle. Um das ganz genau hinzubekommen, gibt es zwei Möglichkeiten:
- Man vergrößert das Audioplayer-Fenster über die Breite des gesamten Bildschirms oder
- man kann einen Zoom-Faktor für die grafische Darstellung der Amplituden einstellen.
- Erstellen Sie eine neue Szene, wählen Sie eine aus der Szenenbibliothek oder definieren Sie einen Befehl.
- Sie können übrigens die Position eines Befehls im Audiotrack verändern, indem Sie den zugeordneten blauen Balken mit der Maus verschieben (Doppelpfeilcursor). Die neue Position wird in der Befehlsliste aktualisiert. Durch einen Klick auf den Tabellenkopf « Position » werden die Befehle aufsteigend oder absteigend sortiert.
- Die Fade-In-Zeit kann durch Anklicken der entsprechenden Zelle in der Tabelle angepasst werden.
- Wenn Sie die Häkchen vor den Befehlsnamen ausschalten, wird der entsprechende Befehl deaktiviert, verbleibt aber in der Trackdefinition. Dies kann man in der Erstellungsphase nutzen, um die Wechselwirkung einzelner Effekte zu testen, bis man die richtige Kombination gefunden hat.
- Modul: Audiotrack
Start/Stopp | Der Befehl Start/Stopp startet und stoppt den ausgewählten Audiotrack zur Wiedergabe. (Der Befehl sollte im Zusammenhang mit dem T-Flag eingesetzt werden.) |
| Stopp | Der Befehl Stopp stoppt den ausgewählten Audiotrack zur Wiedergabe. | ||
| zurück Spulen | Durch den Befehl zurück spulen Springt der Audio-Cursor wieder an den Anfang des Soundfiles. | ||
Der weitere Befehl wird auf den nächsten, vorherigen oder im Dropdown benannten Audiotrack angewendet. | Auswählen | Wählt den nächsten, vorherigen bzw. den im Dropdown Gerät/Funktion benannten Audiotrack aus. |
| Start/Stopp Start Stopp zurück spulen |
siehe oben |
- Der « DMXControl »-Button stellt den normalen Audioplayer-Mode ein.
- Der Audioplayer kann sich mit der Playliste des Winamp-Players synchronisieren, wenn Sie den Winamp-Button aktivieren. In diesem Fall sucht der Audioplayer, ob der gerade in der Playlist gespielte Song auch ein Audioplayer-Track ist und startet dann die entsprechenden Szenen und Effekte. Die Musiksteuerung (z.B. auch das Springen zu bestimmten Stellen) obliegt dann Winamp.
Der Vorteil dieses Betriebskonzeptes liegt darin, dass man dann natürlich synchrone Beats vom Beattrigger erhält, die musikgesteuerte Effekte triggern können. Dazu muss das Winamp AVS-Plugin installiert sein. Die Trackliste und die Winamp-Playlist synchronisieren sich über den in Winamp angezeigten Titel, meist dem mp3-ID3-tag des Songs. Diesen kann man z.B. in Winamp im Menü File->View file.info ... einsehen und auch verändern (siehe folgendes Bild). Natürlich geht das auch mit anderen mp3-Editoren. Der angezeigte Titel ist in Winamp bei Einstellungen /Titel/Erweiterte Titelformatierung veränderbar.
| Figure 2: Trackinformationen in Winamp |
Um diesen Modus zu starten, muss der Winamp-Button aktiviert sein (siehe Punkt 1 im folgenden Bild). Ganz wichtig ist, dass der Trackname mit dem angezeigten Titel des Songs übereinstimmt (siehe Punkt2 im Bild). Ob die Synchronisation erfolgreich ist, erkennt man daran, ob im Feld Audiodatei (wo der Songdateiname angegeben ist) ein (X) für erfolgreich oder ein (-) für nicht gefunden erscheint (siehe Punkt 3 im Bild).
| Figure 3: Synchronisisation des Audioplayers mit Winamp |
