| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 09:48, 31 October 2013 (UTC) 4769 days ago. |
Hint:
25.5.2013: UPrenner: create the article page
30.10.2013 UPrenner: work-in-progress
With the audio player audio tracks can be accompanied by cues, chasers and commands. The audio player in principle only offers another surface that for a cue list, like the script and the time code player the possibility is here establishing the cues for the course of the song point exactly. Through this individual Lightshows can be made for some songs.
Description
The two audio traces are, the stereo traces of a music track present which a striking feature of the audio player (left channel: green, right channel: red). In this the temporal course with the corresponding amplitudes of the song and the sedate cues are shown to window area. At inefficient computers it recommends himself not to load the waveform graphic with the checking box to suppress the indication of the amplitude course, through what CPU performance is saved.
| Figure 1: The Audio player |
<br\>
The audio player serves the crown transparency of wave files. If it is merely about playing wave files, the audio cue has to be preferred. Several also can play audio channels (up to 16 pieces) parallel there. |
Controls
| Icon | Bezeichnung | Beschreibung |
| DMXControl | With the button DMXControl in the audio player you adjust, that the sound file and the audio cue list are started and played about DMXControl. | |
| WinAmp | With the button WinAmp in the audio player you adjust, that the sound file and the audio cue list are started and played about the external program WinAmp. (Synchronization with WinAmp) | |
| Play | The play button starts the sound file and the audio cue list if the DMXControl button is operated. | |
| Rewind | With this button the audio cursor is placed again on the beginning of the song. (This works also when playing the sound file) | |
| Repeat | If this button is operated, then the sound file is played from the front after ending again. | |
| Prefade listening | With the pre-hearing button the sound file becomes audio cursor position wornly as of the current one. At a renewed click on the button the player stops and the audio cursor returns into his starting point. | |
| Zoom | With the zoom lens drop down the audio trace can be extended. | |
| File:DMXC2 Manual audio player button do not load waveform.png | Do not load waveform | If the checking box is highlighted, the audio trace graphic isn't loaded. Through this the performance can be increased at slow computers. |
| Clock | With the clock badge the straight highlighted cue is moved on the current audio cursor position in the audio cue list. |
The remaining buttons are standard buttons.
Audio track
- A yellow vertical line in the audio trace represents the current position marking of the audio cursor.
- A white vertical line in the audio trace shows the cue marking with positions already assigned.
- Line blue more vertically is shown on the audio trace this one if the audio cursor stands on an assigned cue marking.
If one is with the mouse cursor on a cue marking, the mouse pointer converts himself to a double arrow. In addition, a tool tip is shown to the cue with the name. The cue marking can be placed by clicking and hold tight this one con mouse button.
The mouse pointer is on the audio trace and not on a cue marking, a tool tip which contains merely a hyphen is then shown. This tool tip is without broader meaning. |
Manage audio project
- Button « Add »: By this button a new lets himself make Audiotrack project.
- Button « Open »: With this Button one assigns an audio file to the audio track project. Possible audio files must be for mp3, mp2, mp1, wav or ogg of the type.
- Button « Manage »: The menu items hide: behind this Button « Add », « Copy », « Rename », « Delete » and « Manage ». The audio lists can be also managed with them.
There are problems with a certain skew at wave files with a variable bit rate (VBR). It is therefore the best to use wave files with a constant bit rate (e. g. 128 Kbit or 320 Kbit). |
Serve
At the click with the mouse button into the audio window the audio cursor (yellow line) appears in this place. E.g. the lets himself in with that « Play » mode (click of the play button) jumps to an arbitrary place to hear these. A double click into the audio window starts this one « Play »-mode in the appropriate place. A renewed double click stops this one « Play »-mode.
New cues can be assigned as follows:
- Hear the title and think highly of you in the graphic on prominent places in the song where you want to place cues, effects or commands. This action is exactly like in other DMXControl tools made by clicking the button « Add ».
- Besonders fixe Nutzer schaffen das sogar im « Play »-Mode. Normalerweise stoppt man aber den Titel und positioniert den Cursor exakt an der gewünschten Stelle. Um das ganz genau hinzubekommen, gibt es zwei Möglichkeiten:
- Man vergrößert das Audioplayer-Fenster über die Breite des gesamten Bildschirms oder
- man kann einen Zoom-Faktor für die grafische Darstellung der Amplituden einstellen.
- Erstellen Sie eine neue Szene, wählen Sie eine aus der Szenenbibliothek oder definieren Sie einen Befehl.
- Sie können übrigens die Position eines Befehls im Audiotrack verändern, indem Sie den zugeordneten blauen Balken mit der Maus verschieben (Doppelpfeilcursor). Die neue Position wird in der Befehlsliste aktualisiert. Durch einen Klick auf den Tabellenkopf « Position » werden die Befehle aufsteigend oder absteigend sortiert.
- Die Fade-In-Zeit kann durch Anklicken der entsprechenden Zelle in der Tabelle angepasst werden.
- Wenn Sie die Häkchen vor den Befehlsnamen ausschalten, wird der entsprechende Befehl deaktiviert, verbleibt aber in der Trackdefinition. Dies kann man in der Erstellungsphase nutzen, um die Wechselwirkung einzelner Effekte zu testen, bis man die richtige Kombination gefunden hat.
- Modul: Audiotrack
Start/Stopp | Der Befehl Start/Stopp startet und stoppt den ausgewählten Audiotrack zur Wiedergabe. (Der Befehl sollte im Zusammenhang mit dem T-Flag eingesetzt werden.) |
| Stopp | Der Befehl Stopp stoppt den ausgewählten Audiotrack zur Wiedergabe. | ||
| zurück Spulen | Durch den Befehl zurück spulen Springt der Audio-Cursor wieder an den Anfang des Soundfiles. | ||
Der weitere Befehl wird auf den nächsten, vorherigen oder im Dropdown benannten Audiotrack angewendet. | Auswählen | Wählt den nächsten, vorherigen bzw. den im Dropdown Gerät/Funktion benannten Audiotrack aus. |
| Start/Stopp Start Stopp zurück spulen |
siehe oben |
- Der « DMXControl »-Button stellt den normalen Audioplayer-Mode ein.
- Der Audioplayer kann sich mit der Playliste des Winamp-Players synchronisieren, wenn Sie den Winamp-Button aktivieren. In diesem Fall sucht der Audioplayer, ob der gerade in der Playlist gespielte Song auch ein Audioplayer-Track ist und startet dann die entsprechenden Szenen und Effekte. Die Musiksteuerung (z.B. auch das Springen zu bestimmten Stellen) obliegt dann Winamp.
Der Vorteil dieses Betriebskonzeptes liegt darin, dass man dann natürlich synchrone Beats vom Beattrigger erhält, die musikgesteuerte Effekte triggern können. Dazu muss das Winamp AVS-Plugin installiert sein. Die Trackliste und die Winamp-Playlist synchronisieren sich über den in Winamp angezeigten Titel, meist dem mp3-ID3-tag des Songs. Diesen kann man z.B. in Winamp im Menü File->View file.info ... einsehen und auch verändern (siehe folgendes Bild). Natürlich geht das auch mit anderen mp3-Editoren. Der angezeigte Titel ist in Winamp bei Einstellungen /Titel/Erweiterte Titelformatierung veränderbar.
| Figure 2: Trackinformationen in Winamp |
Um diesen Modus zu starten, muss der Winamp-Button aktiviert sein (siehe Punkt 1 im folgenden Bild). Ganz wichtig ist, dass der Trackname mit dem angezeigten Titel des Songs übereinstimmt (siehe Punkt2 im Bild). Ob die Synchronisation erfolgreich ist, erkennt man daran, ob im Feld Audiodatei (wo der Songdateiname angegeben ist) ein (X) für erfolgreich oder ein (-) für nicht gefunden erscheint (siehe Punkt 3 im Bild).
| Figure 3: Synchronisisation des Audioplayers mit Winamp |
