| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 00:16, 1 November 2013 (UTC) 4683 days ago. |
Hint:
25.5.2013: UPrenner: create the article page
31.10.2013 UPrenner: work-in-progress
At theater and musical events it is decisive that light atmospheres and effects are exactly used on a keyword straight. For this the script module is integrated in DMXControl. With this you can light or movement scenes but also sound effects (as thunder, barking of dogs or similar) as well as start orders to certain passages in a theater or musical piece. The field of application of the script module doesn't remain restricted to theater and musical because this module is suitable also for other events with a firm expiry like choir or carnival events.
| Figure 1: The textbook module |
Description
The window of the textbook module is divided into three areas:
- the text field area with text editor functions in the upper part of the module
- the control area with buttons for the control of the performance in the middle part of the module
- the direction area with a cue overview and cue processing functions in the lower part of the module
Text field area
The text field area contains a text editor with which you can scroll in the textbook (described) as a script in the following without influencing the cue expiry. In addition, you can simple customizations with the editor, like the change of the color or the size of the script text carry out. This suffices, around e.g. keyword to underline or to ink direction entries of one's own task-related in different colors. However, e.g. the editor of the module isn't designed for it the script write or carry out comprehensive customizations in this editor. A customary text editor is suitable for it better.
To be able to open script files in DMXControl, these must in the Rich Text Format[1] (file extension .rtf) to be available. In the text field the text not too extensively becomes, if the script should be divided up into several parts, preferably every break so that a subdivision. The part script arisen so can correspondingly, explained still more exactly in the article below, options display be loaded separately in the breaks about one. In addition, the text structure of the script isn't provided in the script module. This means you can adapt the script to her requirements individually and don't have to adapt themselves to a DMXControl-specific text structure.
A small progress bar is under the text field. This shows the current Fortschitt in the script using which one can assess approximately how long the current piece already is on and how much text follows still until the next break or the end of the play.
So that DMXControl recognizes at which ones scenes corresponding to places in the script are, scene references are made with references to the corresponding scenes. These reprimands are always inserted by DMXControl at the beginning of a new line in the Textskript. One leaves one line each the best above and below the reference freely so that the script remains as open as possible.
The string # # # mustn't happen in the normal text of the script since DMXControl uses this character string as a marking for the prepared reference entries. If this character string is used, it can come to serious faults! |
Cue references
Cue references are stressed by DMXControl so that these are readable better. You have format always following:
### <Cue-ID> - <Cue name> ### <Director comment>
The cue ID is a four-digit reference number produced by DMXControl automatically. This number is needed so that DMXControl finds the right cue in the internal database for the cue reference. The scene name corresponds to the cue name allocated in DMXControl and can be chosen individually at the construction of the cue. Here it should be taken care of on this to use apt names so that at a search the corresponding cues can be found fast again. Additional information, like the way of the light atmosphere, can stand as a management comment at the end of a cue reference. E.g. a cue reference can look as follows:
###0002 – thunder storm ### thunder(audio)
All cue types like simple cue or audio cue supported by DMXControl can be used in the script. Since the made cue references are also only character strings, these can be processed with an external editor exactly like the remaining text of the script. DMXControl leads therefore a consistency check through, whether at every start all scenes indicated in the script are available in the internal database. If a cue was found in the database, then a green rhombus is shown to the corresponding scene besides the name in the management area. If a scene entry doesn't refer to any existing scene, then the rhombus is colored red besides the name.
It should absolutely be taken care of on this that the scene references aren't changed when working with an external text editor since scene references can be lost through this and it can come to inconsistencies |
Controls
Control area
| Figure 2: The control area |
Four button are in the control area. This one is the greatest of them « GO » button. He starts the select cue and selects the following cue automatically. So the will on by clicking repeatedly « GO » button the row after all cues started in the script.
Two navigation buttons are on the left besides it « Prev » and « Next ». With them one can navigate between the cues without executing her. So one can skip single cue references if a keyword was missed and the next scene shall be selected now.
On the right besides the « GO » button this one is « AutoScroll » button. With this the AutoScroll function of the script can be activated or deactivated. At the AutoScroll function a red harvest line is shown and the harvest line and the script always scrolls the script up to the next scene reference. The scrolling up speed is derived from the indicated delta time to the next scene in the management area, as a rule, through what a manual customization is required.
| Figure 3: The control area in search mode |
The control block also contains a small search function since DMXControl's version 2.11. With the help of the key combination ctrl' '+' 'f the search function is activated. Sie durchsucht das Skript bei einem Klick auf « Next hit » as of the current cursor position after the entered search text. If the search text is found in the script, then the script jumps to this position and marks the corresponding passage. The left button in the search view closes the search function and shows the control view again.
Direction area
The management area contains a script administration in the upper section. With the drop down menu the different Teilskripte can be selected and can with the button « Managing » being laid out, copied, renamed or deleted. With « Open » the fitting text file can be opened to every part script.
A list is in the lower part with all scenes contained in the script which are sorted after her appearance in the script. In this list different parameters get shown every single scene, the partial ones by clicking slowly, twice (no-one double-click) you can process:
| Figure 4: Part from the cue list of the text book |
| Function | Description | Workable | |
| 1 | Cue aktiv | Here you can select, whether the scene is taken into account or left out in the expiry | Yes |
| 2 | green / red diamond | If cue reference and cue agree on the database, the diamond is green, otherwise red | No |
| 3 | Name | Name of the corresponding cue entry | Yes |
| 4 | Line | The line number is shown to the cue reference here | No |
| 5 | Delta-T | Time between the last and the current cue. The value indicated here has influence on the scrolling up speed of the AutoScroll function | Yes |
| 6 | catchword | As small help a passage at which the cue shall be started can be indicated here | Yes |
| 7 | Comment | A note can be indicated with additional information about the cue which appears in the script at the end of the corresponding cue reference here | Yes |
| 8 | Fade time | The fade time determines how long the fade of the last cue shall last to the current cue | Yes |
Single cue entries are on the left of the cue list these confessed button for making, working and deleting from other modules. You find details for her operation control center DMXC2 in the article to the Control center.
The cue progress bar is below the cue list. This shows graphically how long the current cue is already displayed in proportion to her one fade duration.
If several cues which contain the same devices are started at the same time, then the DMX version starts to jump and the light begins to flicker. In addition, scene injections cannot be broken off. It must therefore be taken care of on this that the fade times aren't chosen too greatly! |
- Modul: Textbuch
| Go-Button | Auf den Go-Button wird der weitere Befehl angewendet. | Auswählen | Der Button wird bei Ausführen des Befehls betätigt. |
| Zurück-Button | Auf den Zurück-Button wird der weitere Befehl angewendet. | Auswählen | Der Button wird bei Ausführen des Befehls betätigt. |
| Vor-Button | Auf den Vor-Button wird der weitere Befehl angewendet. | Auswählen | Der Button wird bei Ausführen des Befehls betätigt. |
| Textbuch auswählen | Der weitere Befehl wählt das entsprechende Textbuch aus. | Nächstes | Wählt das nächste Textbuch aus. |
| Vorheriges | Wählt das vorherige Textbuch aus. | ||
| Textbuch-Name | Wählt das Textbuch mit dem Namen aus der Dropdown-Liste. |
- ↑ Wikipedia: http://de.wikipedia.org/wiki/Rich_Text_Format
