| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 11:33, 2 November 2013 (UTC) 4768 days ago. |
Hint:
25.5.2013: UPrenner: create the article page
01.11.2013 UPrenner: work-in-progress
With keyboard control DMXControl has steered modules in everyone by keyboard for itself, e.g. DMX channels can be put, started effects/stopped, the audio player start/stop, changed etc. attitudes of the Soundanalyzers on predefined values of devices so. By the free programming of the individual buttons lets themselves, one to the claims of one's own make conformist keyboard operation for DMXControl. This is primarily because one can access corresponding actions with respect to hardwares over single buttons advisable at events. E.g. the command line can be used or also assigned different chasers to the individual buttons by the connection of an external USB numeric keypad very comfortably. Till now, is for the banks concept at the keyboard control, not implemented yet unlike the command box, DMXIn and midi remote control.
Description and configuration
Configuring keyboard control
| Figure 1: Opens the configuration window |
For the configuration of keyboard control you have to open the keyboard control configuration window over the menu « Configuration » Menu item « Keyboard control » first (see figure 1). All buttons are listed on the left side, the control elements in the configuration window. Since DMXC 2.12 the F1 button also can be covered with orders. This wasn't possible at earlier versions.
| Figure 2: The Configuration_window |
You store project-relatedly, the order assignment the file name is in the project list: PROJECTNAME.keyboard |
The other table columns have following meaning and functions.
| Module: | At the click to the field module a drop down list from which one can select one of the modules available in DMXControl opens.
The following modules can be selected: Disabled: Audio: Audiotrack: BeatTool: Chasers: Command line: Command box: Cue libary: Cue list: Devices: DMX output: DMXIn remote: Group selection: Joystick: Master: Midi Remote: OSC receiver: Sound Analyzer: Submaster: Textbook: |
Plugins which support a control by the command box also seem additional here. This shall exemplarily be called MadMaxOne plugin here. |
| MadMaxOne Plug-In: Using command on the plugin MadMaxOne. | ||
| Device/Function: | The corresponding functions of the module are selected by a click in this field be able to depending on select module, or the device to be mentioned. | |
| Channel: | By a click in this field an appropriate channel for a device can be adjusted or depending on module and function a corresponding action can be assigned. | |
| Flags: | At a click on the field flags a dropdown list with which the corresponding flags can be put or deleted opens.
The following flags can be selected: Toggle mode (T): Use specified value (O): Ask for value (A): Ignore value 0 (I): | |
| Value: | By a click in this field a corresponding value can be deposited quickly for a device or a function. |
Both at ' '“Using indicated value“and“Questioning on value“the entered value is a per cent value in the area of 0. 000% to 100. 000% ' '. A input of values 0 to 255 or 0 to 65535 isn't possible here. |
You find the administration part in the menu « Window » in the menu item « Keyboard control».
In the administration part you can adjust, whether keyboard control is active the depressed buttons are intercepted and whether keyboard control also works if exactly another program has the focus.
Controls
| Figure 3: Keyboard control aktivating window |
The configuration of the control elements is carried out this one elements almost analogously to the MIDI control. Every control element corresponds to a DMX channel whose value is used for the configured command. Another this one lets himself on the right side « Softpatch » configuring. Values of the DMX can into be distributed on arbitrary other DMX out channels with that. This is useful to e.g. only steer a certain devices with an external light desk.
| Start the chaser | Stop the chaser | Start/Stop the chaser | |||
| Module: | Chasers | Module: | Chasers | Module: | Chasers |
| Device/Function: | Selected | Device/Function: | Selected | Device/Function: | Selected |
| Channel: | Start | Channel: | Stop | Channel: | Start/Stop |
| Value: | - | Value: | - | Value: | - |
Programs can no longer globally question or intercept on button petitions by the new safety policy of Microsoft since Windows sight at an active user accounts control system (UAC). This speaks in it that at the activation this one « Global ». A fault appears attitude in the administration part. It therefore isn't possible in sight and Windows 7 with an active user accounts control system to steer DMXControl about keyboard control if exactly another program has the focus. |
Tip(s)
It is valid for DMXControl 2.11 and more smally:So that these attitudes also are realized, the window must « DMXIn remote control » open and there the checking box « DMXIn remote control active » being active. For DMXControl 2.12 is no longer required. |
