| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 16:42, 2 November 2013 (UTC) 4720 days ago. |
Hint:
02.11.2013 UPrenner: work-in-progress
The joystick control gives you the possibility of steering DMXControl's functions with a joystick or gamepad.
| Figure 1: Window for the activation of the joystick control |
The activation window of the joystick control must remain opened in DMXControl in the versions up to and including 2.11 so that the joystick control works. This is no longer necessary as of version 2.12. |
Description
Template:Bild mit Unterschrift In the joystick control you can assign orders to the axes X, Y and Z and maximum 12 buttons each of four joysticks to thus e.g. steer scanner or MovingHeads directly. The operation of dimmer channels and assignment of arbitrary orders to the axes or buttons is also possible. This happens just like the attitude at the other controls/remote controls keyboard control, MIDI remote control, DMXIn remote control.
The number of supported joysticks is limited on 4 at the moment, there exists the possibility, however, of not a solid device but the respectively select device influencing graphcal view in this one. About the group choice a fast change of the device to be steered is possible.
Die Modi
- Relativ (die Auslenkung der Achsen bestimmt nur die Richtung und Geschwindigkeit der Bewegung, nicht ihre genaue Position)
- Absolut (die Position der Achsen bestimmt die Position des Lichtkegels (beim loslassen schnappt der Kegel zurück))
sind pro Achse einstellbar. Im Relativmodus können zusätzlich der « Deaktivierte Bereich » (bei schlechter Rückstellung des Joysticks nützlich) und die Beschleunigung zum Rand hin eingestellt werden.
- Modul: Joystick
| Steuerung | Auf die Joysticksteuerung wird der nächste Befehl (Kanal) angewendet. | Ein/Aus | Die Joysticksteuerung wird Ein-bzw. Ausgeschaltet (T-Flag). |
| Aktivieren | Die Joysticksteuerung wird aktiviert. | ||
| Deaktivieren | Die Joysticksteuerung wird deaktiviert. |
