| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 21:29, 2 November 2013 (UTC) 4668 days ago. |
Hint:
02.11.2013 UPrenner: work-in-progress
02.02.2013: UPrenner article ready, just update of pictures
02.02.2013: UPrenner pictures updated
If you are a native speaker, please Help us and review this
The joystick control gives you the possibility of steering DMXControl's functions with a joystick or gamepad.
| Figure 1: Window for the activation of the joystick control |
The activation window of the joystick control must remain opened in DMXControl in the versions up to and including 2.11 so that the joystick control works. This is no longer necessary as of version 2.12. |
Description
| Figure 2: Window for the configuration of the joystick control |
In the joystick control you can assign commands to the axes X, Y and Z and maximum 12 buttons each of four joysticks to thus e.g. steer scanner or hoving heads directly. The operation of dimmer channels and assignment of arbitrary commands to the axes or buttons is also possible. This happens just like the attitude at the other controls/remote controls keyboard control, MIDI remote control, DMXIn remote control.
The number of supported joysticks is limited on 4 at the moment, there exists the possibility, however, of not a solid device but the respectively select device influencing graphcal view in this one. About the group choice a fast change of the device to be steered is possible.
Modes
- Relativ (the deflection of the axes determines only the direction and speed of the movement, not her exact position relative)
- Absolut (the position of the axes determines the position of the cone of light (let off the ninepin snaps back))
per axis are adjustable.. In the relative mode this one can in addition « Area deactivated » at (useful to a bad provision of the joystick) and be the acceleration adjusted to to the edge.
Module commands
- Modul: Joystick control
| Device | Description | Channel | Description |
| Control | The next command (channel) is applied to the joystick control. | On/Off | The joystick control will be turned on or off (T-Flag). |
| Activate | The joystick control will be activate. | ||
| Deactivate | The joystick control will be deactivate. |
Meaning of the Flags:
