| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 18:49, 6 November 2013 (UTC) 4738 days ago. |
Hint:
04.11.2013: UPrenner: work-in-progress
Essential attitudes can be adapted regarding the unusual features of the computer and/or the light configuration in the window program configuration.
The program configuration is divided up into 5 areas:
- General
- Graphical view
- Cues/Chasers
- Tools
- Output
Description
Tabulator General
| Figure 1: Window program settings, tab general |
| Setting | Meaning | Default | comment |
| Performance | |||
| Update interval of the Spectrum Analyzer | Time interval after which new audio data are fetched by WinAmp | 50 ms | A larger interval can improve performance at weak computers |
| Deactivating an automatic securing of the scene library | The scene library is stored periodically, by activation this storage can be put down. | not active | At great projects with outstandingly many scenes, it can come to delays in the course of the effects by the automatic storage of the cue library sometimes. |
| View | |||
| Type size for extended view | Type size in the graphical view at extension | 8 | |
| Indication of the DMX values % | Rearrangement between absolute and percent indication | not active | |
| Program startup | |||
| Execute of a command at the start of DMXControl | To the start of DMXControl an command which switches on e. g. the Grundlich is executed. | no command defines | The command can about the DMXControl usual commands are defined. (see chapter command overview) |
| Deactivating safety query at program end | Deactivating query when ending DMXControl | not active | |
| Other | |||
| Save color and gobo lists globally | The color and gobo lists aren't stored in the project directrory, but in the DMXControl directrory . | not active | Farb and Gobolisten can be used in all projects |
| Flash "scroll lock" LED on beat | Beat from the beat tool or sound analyzer flashes the "scroll lock" LED. | not active | |
Registerreiter Grafische Ansicht
| Figure 2: Window program settings, tab graphical view |
| Geräte-Popups | |||
| Beim Überstreichen mit der Maus öffen | DDF-Geräte-Popups öffnen sich nicht, wenn man mit der Maus darüber fährt. | nicht aktiviert | |
| Nach Mausklick auf das Symbol öffnen | DDF-Geräte-Popups öffnen sich bei Klick auf das Geräte-Icon. | aktiviert | |
| Schließen nach: ms | Zeit bis zum Schließen der DDF-Geräte-Popups nachdem die Maus das Popup verlassen hat. | 1 sec. | |
| Symbole | |||
| Symbolgrösse in der grafischen Ansicht | Größe der Icons in der gafischen Bühnenansicht in Pixeln | 32 pixel. | |
| Beim Zoomen ebenfalls vergrößern. | Ions beim Zoomen der grafischen Ansicht ebenfalls vergrößern | nicht aktiviert | |
| Darstellung der Farbe statt Grafik verwenden | Bei Aktivierung wird bei LED-RGB-Geräten statt des Icons ein Kreis in der eingestellten LED-Farbe dargestellt. | nicht aktiviert | |
| Gerätenamen & -adresse anzeigen | Die Gerätenamen und -adressen werden zusätzlich zu den Icons in der grafischen Bühnenansicht angezeigt | nicht aktiviert | |
Registerreiter Szenen/Effekte
| Figure 3: Window program settings, tab cues/chasers |
| Szenen | |||
| Standard-Einsprungpunkt bei nicht-fadenden Kanälen | Über den Slider kann festgelegt werden ab welchem Punkt der Kanal eingeschaltet wird. | 50% | |
| Nicht warnen wenn alle Kanäle gespeichert werden. | Beim Speichern von allen Kanälen erfolgt durch DMXControl eine Warnung, da hierdurch die Datenbank auch größer wird. Hier kann diese Warnung abgestellt werden und darurch effektiver gearbeitet werden. | nicht aktiviert | |
| Effekte | |||
| Effekte durch Doppelklick startbar. | Er möglicht das starten im Effektsequencer durch einen Doppelklick. | nicht aktiviert | |
| Ungruppierte Effekte als eigenständige Guppe behandeln | Alle Effekte die keiner Gruppe zugeordnet sind bilden bei Aktivierung eine Eigenständige Gruppe. | nicht aktiviert | |
| Gruppennamen rechstbündig ausrichten | Richtet, bei Aktivierung, die Gruppennamen rechtsbündig im Effktsequencer-Fenster aus, statt direkt hinter die Effektnamen | aktiviert | |
Registerreiter Tools
| Figure 4: Window program settings, tab tools |
| Sound Analyzer | |||
| Quelle VBVis-Plugin | Wenn der Radiobutton VBVis-Plugin aktiviert ist werden die Audiodaten für das BeatTool und den Sound Analyzer über dieses Plugin in Winamp nach DMXControl importiert. | aktiviert | |
| Quelle AVS-Plugin | Wenn der Radiobutton AVS-Plugin aktiviert ist werden die Audiodaten für das BeatTool und den Sound Analyzer über dieses Plugin in Winamp nach DMXControl importiert. | nicht aktiviert | |
Registerreiter Ausgabe
| Figure 5: Window program settings, tab output |
| DMX-Mixer | |||
| Highest takes precendence-Mischung (HTP) deaktivieren | Mit dieser Option, kann zwischen LTP und HTP DMX-Mischung umgeschaltet werden. | aktiviert | |
| DDFs können Kanalwerte begrenzen (MinValue/MaxValue) | Bei Aktivierung dieser Option werden die Min- und MaxValue Werte aus den DDF's übernommen und für die Ausgabe mit einbezogen. | nicht aktiviert | |
| Werte aus allen Quellen auf gewählten Geräte anwenden | Wenn diese Option aktiviert ist, führen gruppierte Geräte in der grafischen Bühnenansicht beim Ablauf von Szenen die gleichen Abläufe aus. | nicht aktiviert | |
