| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 19:52, 6 November 2013 (UTC) 4740 days ago. |
Hint:
04.11.2013: UPrenner: work-in-progress
Essential attitudes can be adapted regarding the unusual features of the computer and/or the light configuration in the window program configuration.
The program configuration is divided up into 5 areas:
- General
- Graphical view
- Cues/Chasers
- Tools
- Output
Description
Tabulator General
| Figure 1: Window program settings, tab general |
| Setting | Meaning | Default | comment |
| Performance | |||
| Refresh interval for spectrum analyzer | Time interval after which new audio data are fetched by WinAmp | 50 ms | A larger interval can improve performance at weak computers |
| Disable automatic saving of cue library | The cue library is stored periodically, by activation this storage can be put down. | not active | At great projects with outstandingly many scenes, it can come to delays in the course of the effects by the automatic storage of the cue library sometimes. |
| View | |||
| Font size for zoomed views | Type size in the graphical view at zoom | 8 | |
| Indication of the DMX values % | Rearrangement between absolute and percent indication | not active | |
| Program startup | |||
| Execute command on programm start | To the start of DMXControl an command which switches on e. g. the Grundlich is executed. | no command defines | The command can about the DMXControl usual commands are defined. (see chapter command overview) |
| Deactivating safety query at program end | Deactivating query when ending DMXControl | not active | |
| Other | |||
| Save color and gobo lists globally | The color and gobo lists aren't stored in the project directrory, but in the DMXControl directrory . | not active | Farb and Gobolisten can be used in all projects |
| Flash "scroll lock" LED on beat | Beat from the beat tool or sound analyzer flashes the "scroll lock" LED. | not active | |
For large projects with above average many scenes, it may cause ever automatic storing of scene library delays in the flow of the effects. In this case, disable the automatic fuse is advisable at this point. |
Tabulator Graphical view
| Figure 2: Window program settings, tab graphical view |
| Device-popups | |||
| Open when hovering over the icon | DDF devices popups, opens when you move the mouse over it. | not enabled | |
| Open after clicking the icon | DDF devices popups, opens when clicking the device icon. | enabled | |
| Close after: ms | Time to close the DDF devices popups when the mouse leaves popup. | 1 sec. | |
| Icons | |||
| Szize | Size of the icons in the graphical view in pixels | 32 pixel. | |
| Change size when zooming | Information when zooming the graphical view also increase | not enabled | |
| Use presetation of color instead of graphic | When enabled a programmed LED color is displayed in LED-RGB devices instead of the icons. | not enabled | |
| Show device name and adress | The device names and addresses are displayed in addition to the icons in the graphical view of the stage | not enabled | |
Registerreiter Szenen/Effekte
| Figure 3: Window program settings, tab cues/chasers |
| Szenen | |||
| Standard-Einsprungpunkt bei nicht-fadenden Kanälen | Über den Slider kann festgelegt werden ab welchem Punkt der Kanal eingeschaltet wird. | 50% | |
| Nicht warnen wenn alle Kanäle gespeichert werden. | Beim Speichern von allen Kanälen erfolgt durch DMXControl eine Warnung, da hierdurch die Datenbank auch größer wird. Hier kann diese Warnung abgestellt werden und darurch effektiver gearbeitet werden. | nicht aktiviert | |
| Effekte | |||
| Effekte durch Doppelklick startbar. | Er möglicht das starten im Effektsequencer durch einen Doppelklick. | nicht aktiviert | |
| Ungruppierte Effekte als eigenständige Guppe behandeln | Alle Effekte die keiner Gruppe zugeordnet sind bilden bei Aktivierung eine Eigenständige Gruppe. | nicht aktiviert | |
| Gruppennamen rechstbündig ausrichten | Richtet, bei Aktivierung, die Gruppennamen rechtsbündig im Effktsequencer-Fenster aus, statt direkt hinter die Effektnamen | aktiviert | |
Registerreiter Tools
| Figure 4: Window program settings, tab tools |
| Sound Analyzer | |||
| Quelle VBVis-Plugin | Wenn der Radiobutton VBVis-Plugin aktiviert ist werden die Audiodaten für das BeatTool und den Sound Analyzer über dieses Plugin in Winamp nach DMXControl importiert. | aktiviert | |
| Quelle AVS-Plugin | Wenn der Radiobutton AVS-Plugin aktiviert ist werden die Audiodaten für das BeatTool und den Sound Analyzer über dieses Plugin in Winamp nach DMXControl importiert. | nicht aktiviert | |
Registerreiter Ausgabe
| Figure 5: Window program settings, tab output |
| DMX-Mixer | |||
| Highest takes precendence-Mischung (HTP) deaktivieren | Mit dieser Option, kann zwischen LTP und HTP DMX-Mischung umgeschaltet werden. | aktiviert | |
| DDFs können Kanalwerte begrenzen (MinValue/MaxValue) | Bei Aktivierung dieser Option werden die Min- und MaxValue Werte aus den DDF's übernommen und für die Ausgabe mit einbezogen. | nicht aktiviert | |
| Werte aus allen Quellen auf gewählten Geräte anwenden | Wenn diese Option aktiviert ist, führen gruppierte Geräte in der grafischen Bühnenansicht beim Ablauf von Szenen die gleichen Abläufe aus. | nicht aktiviert | |
