| This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page. | This page was last edited at 21:30, 6 November 2013 (UTC) 4698 days ago. |
Hint:
04.11.2013: UPrenner: work-in-progress
Essential attitudes can be adapted regarding the unusual features of the computer and/or the light configuration in the window program configuration.
The program configuration is divided up into 5 areas:
- General
- Graphical view
- Cues/Chasers
- Tools
- Output
Description
Tabulator General
| Figure 1: Window program settings, tab general |
| Setting | Meaning | Default | comment |
| Performance | |||
| Refresh interval for spectrum analyzer | Time interval after which new audio data are fetched by WinAmp | 50 ms | A larger interval can improve performance at weak computers |
| Disable automatic saving of cue library | The cue library is stored periodically, by activation this storage can be put down. | not active | At great projects with outstandingly many scenes, it can come to delays in the course of the effects by the automatic storage of the cue library sometimes. |
| View | |||
| Font size for zoomed views | Type size in the graphical view at zoom | 8 | |
| Indication of the DMX values % | Rearrangement between absolute and percent indication | not active | |
| Program startup | |||
| Execute command on programm start | To the start of DMXControl an command which switches on e. g. the Grundlich is executed. | no command defines | The command can about the DMXControl usual commands are defined. (see chapter command overview) |
| Deactivating safety query at program end | Deactivating query when ending DMXControl | not active | |
| Other | |||
| Save color and gobo lists globally | The color and gobo lists aren't stored in the project directrory, but in the DMXControl directrory . | not active | Farb and Gobolisten can be used in all projects |
| Flash "scroll lock" LED on beat | Beat from the beat tool or sound analyzer flashes the "scroll lock" LED. | not active | |
For large projects with above average many scenes, it may cause ever automatic storing of scene library delays in the flow of the effects. In this case, disable the automatic fuse is advisable at this point. |
Tabulator Graphical view
| Figure 2: Window program settings, tab graphical view |
| Device-popups | |||
| Open when hovering over the icon | DDF devices popups, opens when you move the mouse over it. | not enabled | |
| Open after clicking the icon | DDF devices popups, opens when clicking the device icon. | enabled | |
| Close after: ms | Time to close the DDF devices popups when the mouse leaves popup. | 1 sec. | |
| Icons | |||
| Size | Size of the icons in the graphical view in pixels | 32 pixel. | |
| Change size when zooming | Information when zooming the graphical view also increase | not enabled | |
| Use presetation of color instead of graphic | When enabled a programmed LED color is displayed in LED-RGB devices instead of the icons. | not enabled | |
| Show device name and adress | The device names and addresses are displayed in addition to the icons in the graphical view of the stage | not enabled | |
Tabulator Cues/Chasers
| Figure 3: Window program settings, tab cues/chasers |
| Szenen | |||
| Default set points for non-fading channels | About the slider can be set at what point the channel is switched on. | 50% | |
| No warning when all channels should be saved. | When saving from all channels a warning carried DMXControl, since this database is also larger. Here, this warning can be turned off and be darurch more effectively worked. | not enabled | |
| Effekte | |||
| Start chasers on double click | It enables the start of a cue in the chaser by a double click. | not enabled | |
| Threat ungrouped chasers as separate group | All of the effects associated with any group form a distinct group activation. | not enabled | |
| Align group names right hand | Sets the group names right in the chaser window from, rather than directly behind the effect name. | enabled | |
Tabulator Tools
| Figure 4: Window program settings, tab tools |
| Sound analyzer | |||
| Quelle VBVis-Plugin | If the radio button VBVis plugin is enabled are imported the audio data for the BeatTool and the sound Analyzer via this plugin in Winamp after DMXControl. | enabled | |
| Quelle AVS-Plugin | If the radio button AVS plugin import the audio data for the BeatTool and the sound Analyzer via this plugin in Winamp after DMXControl is enabled. | not enabled | |
Tabulator Output
| Figure 5: Window program settings, tab output |
| DMX mixer | |||
| Disable "Highest takes precendence" (HTP) mixing | With this option, DMX mix can be switched between LTP and HTP. | enabled | |
| Use HTP for mixing RGB channels) | Bei Aktivierung dieser Option werden die Min- und MaxValue Werte aus den DDF's übernommen und für die Ausgabe mit einbezogen. | not enabled | |
| Handle RGB channels as dimmer | Bei Aktivierung dieser Option werden die Min- und MaxValue Werte aus den DDF's übernommen und für die Ausgabe mit einbezogen. | not enabled | |
| Let DDF's limit channel values (MinValue/MaxValue) | Bei Aktivierung dieser Option werden die Werte aus den DDF's übernommen und für die Ausgabe mit einbezogen. | not enabled | |
| Apply values from all sources to selected device | Wenn diese Option aktiviert ist, führen gruppierte Geräte in der grafischen Bühnenansicht beim Ablauf von Szenen die gleichen Abläufe aus. | not enabled | |
