DDF DMXC2
From English DMXC-Wiki
Revision as of 11:56, 9 November 2013 by Steiny (talk | contribs)
Template:Chaptertitle DMXC
VLC icon.png This section is actively undergoing a major edit for a while. To help avoid edit conflicts, please do not edit this section while this message is displayed or contact the editor (Steiny) of this page.
Hint:
07.11.2013 UPrenner: work-in-progress
Table of contents
Figure 1:Grafische Bühnenansicht mit DDF-Icon
Figure 1: Grafische Bühnenansicht mit DDF-Icon
Figure 2:Geöffnetes DDF-Fenster mit Steuerelementen
Figure 2: Geöffnetes DDF-Fenster mit Steuerelementen
DDF is the abbreviation of Device Definition File. The DDF are the device description (Fixtures) in DMXControl, they serve to inform DMXControl about the functions of the attached DMX device to this. In the DDF the number becomes this one how channels of the DMX device defined and as well these use possible control elements:
  • Position input control element e.g. at Movingheads and Scanners.
  • RGB or CMY color choice control element to the color mixture at e.g. LED headlight or color mixed units at Movingheads.
  • Dropdown control elements
  • Button control elements.
Become the DDF in the « graphical view » with an icon of the device shown (see figure 1), then also can here be accessed the icon, the DDF window by a click with the control elements (see figure 2). XML format which is translated by DMXControl into the internal device description is carried out the description the DMX equipment in one. The DDF are found the DMXControl main directory in the sub-folder DEVICEs. The accompanying icon pictures, which one in the & laquo; Graphic stage view & raquo; be, lie in another sub-folder named shown images.
You get prefabricated DDFs, which weren't enclosed at the installation, can you perhaps of the DMXControl home page in the device library[1]. DDF can be made in a simple way with a XML editor (e. g. PSPad[2]) or also with the DDFCreator. There are advantages and disadvantages with the DDFCreator as also the construction of a DDF with a XML editor. With a XML editor, paraphrasing an existing DDF can be managed considerably faster than with the DDFCreator, against this one is fundamentally faster with the DDFCreator at the construction of a new DDF surface with slidern, button etc.
At both one needs a corresponding knowledge to make an operating DDF no matter whether one now the DDFCreator preferred or the XML editor. Shall the following chapters be conveyed for you, this knowledge among other things the language reference serves as a reference book
Description
A very common language syntax which e.g. is also used in the other dialects at web pages or WAP in the Internet sides is XML (eXtensible Markup Language). But you don't have to be an expert to make a new device description too manually. The following simple notes suffice:
Please take care that your editor doesn't store any (invisible) control characters. There won't be any problems at the Windows editor or PSPad. If you want to use Word or similar software, you should save the file in the raw document format (*.txt).
  • The DMXControl dialect of XML requires for every opening tag always one (<tag>) closing (</tag>) tag. Only this one gets the last level completed just by implication day (e. g. <item caption= "white" value="0" />).
  • The final signs /> and </tag> are semantically equivalent, also <item caption="white" value="0" > </item> is valid in this case.
  • Every day can have attributes which you find professed in the table below. Every attribute value is started with an equals sign and the value must always be included in double apostrophes.
  • All day and attribute identifiers are noted down at DMXControl in a small letter.
  • The day has to be defined hierarchically. They also should make this recognizable about corresponding indents.
  • As a rule, not cares about the order of the attributes of a day. Where it for once depends on the order anyway, you describe below explicitly.
  • Comment are noted down in the form <!- This is a comment —>.
  • E.g. you can have a look at xml files (therefore also the DMX DEVICEs files) in open form with the Internet Explorer.
So it was already this - we have a look at a simple example.
Example: dimmed spotlight
Every device should get an apt icon to receive an adapted representation in stage representation. This icon will be find in the subdirectory Images (Root:\Programme\DMXControl\Devices\Images).
Template unused
The preceding line numbers of the following XML example file cannot be inserted; they serve only the description of the example:
3   <channels>
4     <function channel="0" minvalue="0" maxvalue="255" name="Intensity" fade="yes" />
5   </channels>
11  </form>
12 </device>
Row   1 the Parser will informed about the used XML version.
Row   2 the global description of the new type of device defines inclusive reference to the icon to be put and one ( initialization of the device the optional initsequence was demonstrated here, is but at a headlight only conditionally appropriately. The dimmer channel is (50%) ) put on DMX value 128 at the initialization here.
Row   3 the DMX channels of the device are defined between line 3 and 5.
Row   4 the channel description of the first channel is. This is always the channel numbers at zero important begin, i. e. the first channel is channel="0". In addition, other parameters as well as the channel name are still put here.
Row   6 the lines 6-9 describe the form, that is this one, to graphic coordinates in the context menu for the device picture, names and start address in the unity „Pixel“.
Row 10 here the operating devices follow a slider with his graphic coordinates and the assignment to the channel in question with her qualities, in this example now. Operating devices like radio badges also could, drop down or badges are declared for other types of device here.
miniatur|200px|Bild 3: Dimmer-DDF
Figure 3:Dimmer-DDF
Figure 3: Dimmer-DDF
Three button become Pinup button, Move button, Close button will be generatedly per default generatedly on the top right side (see figure 3).
Create a DDF
Syntax overview
  • Beschreibung globaler Eigenschaften device (im Beispiel Gedimmter Scheinwerfer Zeile 1-2)
  • Beschreibung der einzelnen DMX-Kanäle channels (im Beispiel Gedimmter Scheinwerfer Zeile 3-5)
  • Beschreibung des grafischen Kontextmenüs form (im Beispiel Gedimmter Scheinwerfer Zeile 6-11)
Figure 4:Grundsätzlicher DDF-Aufbau
Figure 4: Grundsätzlicher DDF-Aufbau
Graphical elements
Figure 5:Grafische Elemente
Figure 5: Grafische Elemente
Figure 6:Grafische Koordinaten der Steuerelemente
Figure 6: Grafische Koordinaten der Steuerelemente
Functional elements
Konzept Beschreibung Beispiel
  caption="Sternenhimmel"
  value="165"
- Wertebereich des
  Schiebereglers
  startvalue="0"
  endvalue="255"
“set 1 75; set 2 100“
Template unused
Figure 7:Interaction der Steuerelemente
Figure 7: Interaction der Steuerelemente
Template unused
Syntax
Generic attributs
Template unused
wert. Erklärender Name für
eine Einstellung.
string Dimmer,
Strobe,
usw.
Elementes von der linken
oberen Ecke
integer top=“150“
oberen Ecke.
integer left=“100“
Template unused
Device description
<device> Level 1
einzelnen DMX-Kanäle des
Gerätes
set 7 128;
<information> Level 2
Ergänzender Kommentar.
<name> Level 3
Beliebiger Text
Custom Scanner
<vendor> Level 3
Beliebiger Text
(Hersteller)
optional Showtec
<deviceidentifier> Level 3
Beliebiger Text
(Herstellerbezeichnung)
optional TG-3
<author> Level 3
Beliebiger Text
(Ersteller)
optional
<comment> Level 3
Beliebiger Text
(Kommentar).
optional
<help> Level 2
Hilfetext (ASCII).
optional
Channel description
<channels> Level 2
Pro DMX-Kanal
ist ein “<function>”-Teil zu
definieren
<function> Level 3
Subtag von “<channels>“
Kanalnr. müssen immer
von 0 aufsteigend ohne
Unterbrechung für die
einzelnen Kanäle definiert
werden
integer
name Beschreibender Name
für den Kanal
string Helligkeit
type Kanal-Typ
verarbeitung
string dimmer, r,g,b,
pan, panfine,
tilt, tiltfine,
color, gobo
Änderung des Kanalwerts
string
optional
<virtual> Level 3
<channel> Level 4
Subtag von “<virtual>“
Der drei dem virtuellen
Dimmer zugeordneten Kanäle
integer
Template unused
r,g,b reserviert für Kanäle von RGB LED-Geräten, r für den roten Kanal, g für den grünen Kanal, b für den blauen Kanal.
Die type's r, g, b werden zum einen für die HAL in DMXControl benötigt. Das bedeutet, das in der grafischen Bühnenansicht auch die Farben der Scheinwerfer angezeigt werden.
Eingestellen kann man dies in der Programmkonfiguration unter « Grafische Bühnenansicht » und dann bei « Symbole » « Darstellung der Farben statt Grafik verwenden ».
Zum anderen werden die types auch für den in der 2.12 neuen LED Lauflichtgenerator benötigt.
a,w reserviert für Kanäle von (RGB)A und (RGB)W LED-Geräten, a für den amber Kanal, w für den weißen Kanal.
Die types a und w werden noch nicht von DMXControl unterstützt sind aber sinnvoll, da die Geräte mit zusätzlichen Amber oder Weiß Kanal einen immer größeren Anteil am Markt haben und deshalb eventuell auch bald von DMXControl unterstützt werden.
color, gobo Können den entsprechenden Farb- und Goborad Kanälen zugeordnet werden (wichtig für Farb- & Gobolisten)
Template unused
Menue description
<form> Level 2
Subtag von “<device>“
width
height
Siehe Generische Attribute
GP5; GP6
integer
<deviceimage> 'Level 3
Subtag von “<form>“;
Absolute Position des
angezeigten Bildes
top
left
width
height
GP3 bis GP6
integer
<devicename> 'Level 3
angezeigten Namens
top
left
width
height
GP3 bis GP6
integer
<deviceaddress> 'Level 3
angezeigten Basisadresse
top
left
width
height
GP3 bis GP6
integer
Control elements
Position control
Bild:DMXC2_Manual_DDF_Positionsfeld_kartesisch.png  Bild:DMXC2_Manual_DDF_Positionsfeld_polar.png
<position> Level 3
Erzeugt ein Positionierungs-
feld zur Positionierung von
Scannern oder Movingheads.
kartesischer und polarer
top
left
width
height
GP3 bis GP6
integer
Template unused
Slider
<slider> Level 3
Erzeugt einen Schieberegler
top
left
width
height
GP3 bis GP6
integer
channel Zugeordneter Kanal
alternativ zu action
integer
optional
startvalue Wertebereich des
Schiebers (unterer Wert)
integer startvalue="0"
endvalue Wertebereich des
Schiebers (oberer Wert)
integer endvalue="255"
Skalenunterteilung
integer tickfreq="32"
Pfeiltastenscrollen
integer
(VB-Eigenschaft)
smallchange="20"
Mausklicken (nicht ziehen)
integer
(VB-Eigenschaft)
largechange="50"
code (Variablenname)
string
optional
StrobeSpeed
Änderung am Slider
alternativ zu channel
string
optional
SetSpeed
Dropdown
<dropdown> Level 3
Erzeugt ein Dropdown-Menü.
top
left
width
GP3 bis GP5
integer
integer
optional
string
optional
Gobo
Aufruf eines Dropdown-
string
optional
SetGobo
<item> Level 4
Subtag von “<dropdown>“
minvalue
maxvalue
Wertebereich zu caption zur
Anzeige des Dropdown-Eintrags.
integer minvalue="10"
maxvalue="26"
ordneten Farbe vor caption an
hex color="#ff0000"
Farbe Rot
<colorlist> Level 4
Fügen alle Einträge der
dem Gerät zugewiesenen
Colorliste ein.
optional Ersatz/
Ergänzung für
Item
<gobolist> Level 4
Goboliste ein.
optional Ersatz/
Ergänzung für
Item
Options
<options> Level 3
Erzeugt ein Radiobuttonfeld
top
left
GP3 & GP4
integer
integer
optional
Auswahl eines Radiobuttons,
optional SetGoboSpeed
string
optional
GoboSpeed
<option> Level 4
Subtag von “<options>“
GP2
string off
top
left
GP3 & GP4, relative Position
zur Position von “<options>“
integer left="0"
top="0"
On/Off-Button
<onoff> Level 3
Erzeugt einen Button als Schalter
top
left
width
height
GP3 bis GP6
integer
integer
optional
betätigen des Buttons
string
optional
SetLampOnOff
string
optional
LampOnOff
color Hex RGB-Farbwert des Button hex color="#00ff00"
Farbe Grün
onvalue DMX-Wert für Button ON integer onvalue="150"
offvalue DMX-Wert für Button OFF integer offvalue="0"
ausgeführt wird
string "set 0 230;
set 1 25"
ausgeführt wird
string "set 0 0;
set 1 0"
Command-Button
<command> Level 3
Erzeugt Button’s als Taster
top
left
width
height
GP3 bis GP6
integer
string
optional
SetReset
string
optional
Reset
caption Erklärender Name string Reset
color Hex RGB-Farbwert des Button string color="#0000ff"
Farbe Blau
startende Aktivität ist im
Attribut spezifiziert
string "save 0;
set 0 230;
hold 5500;
restore 0"
string "save 0;
set 0 230;
hold 5500;
restore 0"
upsequence Beim Loslassen zu
string "save 0;
set 0 230;
hold 5500;
restore 0"
Colorpicker
<colorpicker> Level 3
Erzeugt einen Colorpicker.
top
left
width
height
GP3 bis GP6
integer
Rot oder Cyan,
integer
optional
Grün oder Magenta,
integer
optional
Blau oder Yellow,
integer
optional
string
optional
ColRGB
Änderung einer Farbe,
alternativ zu channel1-3
string
optional
SetColRGB
oder CMY
string mode=“cmy“
layout Auswahl von zwei
verschiedenen Layouts des
Colorpickers
integer layout="1"
Beispiel:
Template unused
Passive design elements
<line> Level 3
Gestaltungselement;
Erzeugt eine Linie.
x1; y1 Startkoordinate der Linie integer
x2; y2 Endkoordinate der Linie integer
<label> Level 3
Gestaltungselement;
zusätzliche Beschreibung
eines Bedienelementes.
top
left
width
height
GP3 bis GP6
integer
caption Anzuzeigender Text string CMY Mischung
Beispiel: miniatur|zentriert|600px|Bild 8: DDF Giotto Spot 400
Template:BoxReferenz
Help
miniatur|zentriert|600px|Bild 9: Hilfemenü eines DDF's
Sequences
Operation Bedeutung Beispiel
save >channel< Zwischenspeichern des aktuellen Kanal-
"save 0; set 0 230; hold 5500; restore 0"
>value<
hold >time< Timer (wartet >time< in msec.) "save 0; set 0 230; hold 5500; restore 0"
Procedurs (advanced programming options)
General principles
Basic syntax elements and conventions
Operation Bedeutung
! beginnt einen Befehl
 $ beendet einen Befehl
Operation Bedeutung
 + Addition
 - Subtraktion
 * Multiplikation
 / Division
 mod Modulo-Operation
Operation Bedeutung
den Wert des Ausdruckes >val<
> > |gt| größer
< < |lt| kleiner
= &eq; |eq| gleich
Template unused
XML syntax of the procedure code
<code> Level 2
Subtag von "<device>"
enthält alle Proceduren
<procedure> Level 3
Subtag von "<code>"
enthält den Code der Procedure
An example prozedure
Dieses Beispiel zeigt eine Prozedure, die die Werte der Steuerungselemente „color_color“ und „color_speed“ eines Movingheads in Abhängigkeit vom aktuellen DMX-Wert des Kanals 2 (Farbwechsler) setzt. Der Mac 250+ hat 4 Möglichkeiten für das Farbrad:
action="GetColor"/>
<procedure name='GetColor'>
Procedure GetColor( )
!if|{channel_2} &lt; 208|
  !set_control|color_color|
  {channel_2}$
  !set_control|color_speed|0$
({channel_2} &lt; 227)|
  !set_control|color_color|-1$
  (226-{channel_2})$
({channel_2} &lt; 246)|
  !set_control|color_color|-2$
  ({channel_2}-227)$
({channel_2} &lt; 256)|
  !set_control|color_color|-3$
  ((255-{channel_2}) * 2)$
begin
if channel_2 < 208 then
  color_color := channel_2;
  color_speed := 0;
(else)
if (channel_2 > 207)  and
(channel_2 < 227) then
  color_color := -1;
  color_speed := 226-channel_2;
(else)
if (channel_2 > 226) and
(channel_2 < 246) then
  color_color := -2;
  color_speed :=channel_2-227
(else)
if (channel_2 > 245) and
   (channel_2 < 256) then
  color_color := -3;
</procedure>
end
Tip(s)
Links and references
Table of contents
